Pipe with profile seems to be broken
simsiem
Post by simsiem »
if I add a profile to a pipe, I get the error
Pipe: 'FeaturePython' object has no attribute 'Profile'
on the pipe object. This already worked in the past. Attached you find a minimal example file.
Do you observe the same?
Thanks for your support.
Simon
OS: Ubuntu 14.04.5 LTS
Version: 0.17.10356 (Git)
Build type: None
Hash: cd1f010fe75ee672b0afe684c95736d850c01c93
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
pipe_with_profile.fcstd
Minimal example of a pipe with a rectangular profile
(6.53 KiB) Downloaded 40 times
Re: Pipe with profile seems to be broken
Post by NormandC »
Hello Simon,
Your pipe appears fine until I do a force recompute using the Macro ForceRecompute. Then I get a similar error, but there's more to it, here's the output of the Report view:
File "/usr/lib/freecad-daily/Mod/Arch/ArchPipe.py", line 209, in execute
p = self.getProfile(obj)
File "/usr/lib/freecad-daily/Mod/Arch/ArchPipe.py", line 261, in getProfile
if not obj.Base.Profile.Wires[0].isClosed():
<type 'exceptions.AttributeError'>: 'FeaturePython' object has no attribute 'Profile'
There have been changes to the code base to add compatibility to Python3, but the freecad-daily package from the PPA still runs on Python2. I think this may be a consequence of the py3 changes.
simsiem
Post by simsiem »
Hi NormandC,
yes, this error appears when I force recomputation. I do so, when I change the underlying dwire.
Switching to Python 3 is a good thing. Any idea, whether this is easy to fix and when? From reading the code, it looks reasonable without any dependency on Python 2 or 3. But I have no insights into the underlying FreeCAD code.
Best regards
Simon
Post by NormandC »
Hello Simon,
Unfortunately python might as well be Mandarin to me. The best person to answer that would be yorik, the Arch workbench developer. I'm hoping quoting his handle will bring him here. ;)
Cheers,
Norm
simsiem
Post by simsiem »
I created a bug report and attached a patch to it.
https://www.freecadweb.org/tracker/view.php?id=2954
Can someone please review the patch and merge it so it is in future daily builds?
Thanks a lot
Simon
simsiem
Post by simsiem »
Hi yorik,
any chance to get the linked patch integrated?
Best regards
Simon
kkremitzki
Post by kkremitzki »
simsiem wrote:Hi yorik,
Best regards
Simon
Hi simsiem, are you familiar with git/github at all? We usually do our development through that rather than via patches in bug tracker. Also if you don't quote Yorik directly he's unlikely to see this thread. If you like I can submit your patch as a pull request in Github to get things moving along.
Post by Kunda1 »
Best regards
Simon
I submit the patch for simsiem in https://github.com/FreeCAD/FreeCAD/pull/612
simsiem
Post by simsiem »
Sorry I was not aware of your workflow guidelines. Actually I worked with Git a while in project and created the patch with it. But I did not work with GitHub and pull requests so far. Thanks kunda1 for starting the pull request.
What are the next steps now? How will things go on until the integration on master and in the next daily release?
sgrogan
Post by sgrogan »
simsiem wrote:What are the next steps now? How will things go on until the integration on master and in the next daily release?
In the next days one of the main devs will review the pull request and merge if it's acceptable. Otherwise they will comment on the pull request. If you have a GitHub account you can subscribe to the pull request and get notifications when there is activity. Thanks for the patch!
"fight the good fight"
