PartDesign Feature Request: multi face sketch extrudes
triplus
Re: PartDesign Feature Request: multi face sketch extrudes
Post by triplus »
Maybe a more direct question:
Why face shouldn't be created in Body? What are the downsides? Or it just comes down to the fact nobody has added the feature yet and there are basically no other fundamental issues involved?
DeepSOIC
Post by DeepSOIC »
This leads to a question, why can't one add anything from other workbenches to bodies. If you think about it a bit further, out comes the equivalent of Part-o-magic's Module container :mrgreen:
HoWil
Post by HoWil »
triplus wrote:Maybe a more direct question:
+5 It would also make work easier for subdividing faces for FEM ... see e.g. https://forum.freecadweb.org/viewtopic. ... ts#p149467
HoWil
Post by HoWil »
DeepSOIC wrote:This leads to a question, why can't one add anything from other workbenches to bodies. If you think about it a bit further, out comes the equivalent of Part-o-magic's Module container :mrgreen:
Yes you are right. Would love to see support for "boolean fragments" from Part-wb in PDN-wb!
The question left for me is ... are there any barriers to include sketches/faces and boolean fragments or other wb-stuff step-by-step in PDN-wb!
triplus
Post by triplus »
I see. Therefore i am guessing at some point in the future this feature likely could be added. As on how it will be added. Some possible scenarios are:
  • Add ability to use Draft Upgrade tool on Sketch or any 2D geometry that is located in PartDesign Body directly.
  • Add a new PartDesign feature to create faces from 2D geometry in PartDesign Body.
  • Create new workbench and reimplement features from PartDesign NEXT by lifting current limitations.
Some real challenges ahead i guess. But i am guessing they are still resolvable one way or another. ;)
kkremitzki
Post by kkremitzki »
The idea here is to let the thing you're including in the container implement what the container needs using ickby's extensions, right? I have only started studying your Part-o-magic stuff.
P.S. Why the name Module? It is a very overloaded term already.
DeepSOIC
Post by DeepSOIC »
kkremitzki wrote:P.S. Why the name Module? It is a very overloaded term already.
If you have better suggestion, throw one in here: https://forum.freecadweb.org/viewtopic.php?t=15869
