I do not know if this is already known, thats why I ask here first before entering it into the bug-tracker.
I get a "Segmentation fault (core dumped)" when applying a subtractive-sphere in part-desing onto a specially placed additive-box.
Here the steps to reproduce:
Start FreeCAD-daily
change to Part-Design-wb
Create body
Create additive box
Select XY-Plane and Z-Axis for Attachment (does also work with XZ and Y)
Extra placement: X: -5mm, Y: -5mm, Z: -5mm
Leave dialogue with OK
Select Subractive-Sphere (Subtractive-Box is working)
voilà... it is gone
I did test this several times and sometimes I get only
sometimes I get something like:
*** Error in `freecad-daily': double free or corruption (fasttop): 0x00007f69e00819f0 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x777e5)[0x7f6a11c647e5]
/lib/x86_64-linux-gnu/libc.so.6(+0x7fe0a)[0x7f6a11c6ce0a]
/lib/x86_64-linux-gnu/libc.so.6(cfree+0x4c)[0x7f6a11c7098c]
/usr/lib/x86_64-linux-gnu/libstdc++.so.6(+0x8d88f)[0x7f6a1225988f]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN24BRepMesh_FastDiscretFace3addERK13TopoDS_Vertex+0x562)[0x7f69dbd90a62]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN24BRepMesh_FastDiscretFace17initDataStructureEv+0x91a)[0x7f69dbd913ca]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN24BRepMesh_FastDiscretFace3addERKN11opencascade6handleI22BRepMesh_FaceAttributeEE+0xae)[0x7f69dbd91fce]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN24BRepMesh_FastDiscretFace7PerformERKN11opencascade6handleI22BRepMesh_FaceAttributeEE+0x9)[0x7f69dbd92b19]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZNK20BRepMesh_FastDiscret7ProcessERK11TopoDS_Face+0x125)[0x7f69dbd839b5]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN3tbb10interface98internal24balancing_partition_typeINS1_13adaptive_modeINS1_19auto_partition_typeEEEE12work_balanceINS1_9start_forINS_13blocked_rangeI23NCollection_StlIteratorISt26random_access_iterator_tagN18NCollection_VectorI11TopoDS_FaceE8IteratorESD_Lb0EEEENS_8internal26parallel_for_each_body_forI20BRepMesh_FastDiscretSG_EEKNS_16auto_partitionerEEESH_EEvRT_RT0_+0x4ec)[0x7f69dbd9a65c]
/usr/lib/x86_64-linux-gnu/libTKMesh.so.7(_ZN3tbb10interface98internal9start_forINS_13blocked_rangeI23NCollection_StlIteratorISt26random_access_iterator_tagN18NCollection_VectorI11TopoDS_FaceE8IteratorES7_Lb0EEEENS_8internal26parallel_for_each_body_forI20BRepMesh_FastDiscretSA_EEKNS_16auto_partitionerEE7executeEv+0x1ef)[0x7f69dbd9ab7f]
/usr/lib/x86_64-linux-gnu/libtbb.so.2(+0x26fdd)[0x7f69d71b8fdd]
/usr/lib/x86_64-linux-gnu/libtbb.so.2(+0x200dc)[0x7f69d71b20dc]
/usr/lib/x86_64-linux-gnu/libtbb.so.2(+0x1efd3)[0x7f69d71b0fd3]
/usr/lib/x86_64-linux-gnu/libtbb.so.2(+0x1aa91)[0x7f69d71aca91]
/usr/lib/x86_64-linux-gnu/libtbb.so.2(+0x1acf9)[0x7f69d71accf9]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x76ba)[0x7f6a107806ba]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x6d)[0x7f6a11cf382d]
======= Memory map: ========
00400000-00407000 r-xp 00000000 08:02 2667921 /usr/lib/freecad-daily/bin/FreeCAD
00606000-00607000 r--p 00006000 08:02 2667921 /usr/lib/freecad-daily/bin/FreeCAD
00607000-00608000 rw-p 00007000 08:02 2667921 /usr/lib/freecad-daily/bin/FreeCAD
01dd5000-09d9d000 rw-p 00000000 00:00 0 [heap]
7f6970000000-7f6970021000 rw-p 00000000 00:00 0
7f6970021000-7f6974000000 ---p 00000000 00:00 0
7f6974000000-7f6974297000 rw-p 00000000 00:00 0
7f6974297000-7f6978000000 ---p 00000000 00:00 0
7f697aedd000-7f697aeed000 rw-s 00000000 00:05 293379 /drm mm object (deleted)
7f697aeed000-7f697aefd000 rw-s 102d45000 00:06 357 /dev/dri/card0
7f697b0ed000-7f697b0fd000 rw-s 10739e000 00:06 357 /dev/dri/card0
7f697b1cd000-7f697b1d5000 rw-s 102a5c000 00:06 357 /dev/dri/card0
7f697b1d5000-7f697b1dd000 rw-s 00000000 00:05 294464 /drm mm object (deleted)
7f697b1e5000-7f697b1ed000 rw-s 00000000 00:05 292797 /drm mm object (deleted)
7f697b1ed000-7f697b1f5000 rw-s 102a54000 00:06 357 /dev/dri/card0
7f697b1fd000-7f697b205000 rw-s 102a44000 00:06 357 /dev/dri/card0
7f697b215000-7f697b515000 rw-s 1074cd000 00:06 357 /dev/dri/card0
7f697b515000-7f697b7ef000 r-xp 00000000 08:02 2624350 /usr/lib/freecad-daily/lib/SketcherGui.so
7f697b7ef000-7f697b9ee000 ---p 002da000 08:02 2624350 /usr/lib/freecad-daily/lib/SketcherGui.so
7f697b9ee000-7f697b9f9000 r--p 002d9000 08:02 2624350 /usr/lib/freecad-daily/lib/SketcherGui.so
7f697b9f9000-7f697b9ff000 rw-p 002e4000 08:02 2624350 /usr/lib/freecad-daily/lib/SketcherGui.so
7f697b9ff000-7f697bb23000 r-xp 00000000 08:02 2627268 /usr/lib/x86_64-linux-gnu/libTKFeat.so.7.1.0
7f697bb23000-7f697bd22000 ---p 00124000 08:02 2627268 /usr/lib/x86_64-linux-gnu/libTKFeat.so.7.1.0
7f697bd22000-7f697bd25000 r--p 00123000 08:02 2627268 /usr/lib/x86_64-linux-gnu/libTKFeat.so.7.1.0
7f697bd25000-7f697bd27000 rw-p 00126000 08:02 2627268 /usr/lib/x86_64-linux-gnu/libTKFeat.so.7.1.0
7f697bd27000-7f697bdf2000 r-xp 00000000 08:02 2625617 /usr/lib/freecad-daily/lib/_PartDesign.so
7f697bdf2000-7f697bff1000 ---p 000cb000 08:02 2625617 /usr/lib/freecad-daily/lib/_PartDesign.so
7f697bff1000-7f697bffc000 r--p 000ca000 08:02 2625617 /usr/lib/freecad-daily/lib/_PartDesign.so
7f697bffc000-7f697bfff000 rw-p 000d5000 08:02 2625617 /usr/lib/freecad-daily/lib/_PartDesign.so
7f697bfff000-7f697c000000 rw-p 00000000 00:00 0
7f697c000000-7f697c082000 rw-p 00000000 00:00 0
7f697c082000-7f6980000000 ---p 00000000 00:00 0
7f6980000000-7f698029a000 rw-p 00000000 00:00 0
7f698029a000-7f6984000000 ---p 00000000 00:00 0
7f6984000000-7f6984036000 rw-p 00000000 00:00 0
7f6984036000-7f6988000000 ---p 00000000 00:00 0
7f6988004000-7f698800c000 rw-s 00000000 00:05 292553 /drm mm object (deleted)
7f698801c000-7f6988024000 rw-s 00000000 00:05 292546 /drm mm object (deleted)
7f6988034000-7f698803c000 rw-s 00000000 00:05 293266 /drm mm object (deleted)
7f698803c000-7f6988044000 rw-s 102a3c000 00:06 357 /dev/dri/card0
7f6988044000-7f698804c000 rw-s 00000000 00:05 294433 /drm mm object (deleted)
7f6988064000-7f698806c000 rw-s 102a34000 00:06 357 /dev/dri/card0
7f698806c000-7f6988074000 rw-s 105bf5000 00:06 357 /dev/dri/card0
7f6988074000-7f698807c000 rw-s 00000000 00:05 293157 /drm mm object (deleted)
7f698807c000-7f6988084000 rw-s 105bed000 00:06 357 /dev/dri/card0
7f6988084000-7f6988094000 rw-s 105bd5000 00:06 357 /dev/dri/card0
7f6988094000-7f698809c000 rw-s 102a04000 00:06 357 /dev/dri/card0
7f698809c000-7f69880a4000 rw-s 00000000 00:05 292589 /drm mm object (deleted)
7f69880b4000-7f69880c4000 rw-s 00000000 00:05 293283 /drm mm object (deleted)
7f69880c4000-7f69882e3000 r-xp 00000000 08:02 2622933 /usr/lib/freecad-daily/lib/PartDesignGui.so
7f69882e3000-7f69884e3000 ---p 0021f000 08:02 2622933 /usr/lib/freecad-daily/lib/PartDesignGui.so
7f69884e3000-7f69884f2000 r--p 0021f000 08:02 2622933 /usr/lib/freecad-daily/lib/PartDesignGui.so
7f69884f2000-7f69884f6000 rw-p 0022e000 08:02 2622933 /usr/lib/freecad-daily/lib/PartDesignGui.so
7f69884f6000-7f698863b000 r-xp 00000000 08:02 2624529 /usr/lib/freecad-daily/lib/Sketcher.so
7f698863b000-7f698883a000 ---p 00145000 08:02 2624529 /usr/lib/freecad-daily/lib/Sketcher.so
7f698883a000-7f698883f000 r--p 00144000 08:02 2624529 /usr/lib/freecad-daily/lib/Sketcher.so
7f698883f000-7f6988843000 rw-p 00149000 08:02 2624529 /usr/lib/freecad-daily/lib/Sketcher.so
7f6988843000-7f6988844000 rw-p 00000000 00:00 0
7f6988844000-7f6988886000 rw-s 00000000 00:05 28049439 /SYSV00000000 (deleted)
7f6988887000-7f698888f000 rw-s 00000000 00:05 294432 /drm mm object (deleted)
7f698888f000-7f6988897000 rw-s 00000000 00:05 294273 /drm mm object (deleted)
7f69888a7000-7f69888af000 rw-s 102a2c000 00:06 357 /dev/dri/card0
7f69888af000-7f69888b7000 rw-s 00000000 00:05 292541 /drm mm object (deleted)
7f69888b7000-7f69888bf000 rw-s 1029dc000 00:06 357 /dev/dri/card0
7f69888bf000-7f69888c7000 rw-s 1029d4000 00:06 357 /dev/dri/card0
7f69888c7000-7f69888cf000 rw-s 00000000 00:05 293190 /drm mm object (deleted)
7f69888cf000-7f69888d7000 rw-s 102a0c000 00:06 357 /dev/dri/card0
7f69888d7000-7f69888df000 rw-s 1029c4000 00:06 357 /dev/dri/card0
7f69888df000-7f69888e7000 rw-s 1029f4000 00:06 357 /dev/dri/card0
7f69888e7000-7f69888ef000 rw-s 105be5000 00:06 357 /dev/dri/card0
7f69888ef000-7f69888f7000 rw-s 00000000 00:05 292588 /drm mm object (deleted)
7f69888f7000-7f698891d000 rw-s 00000000 00:05 28606498 /SYSV00000000 (deleted)
7f698891d000-7f6988925000 rw-s 1029a4000 00:06 357 /dev/dri/card0
7f6988925000-7f698892d000 rw-s 106d3b000 00:06 357 /dev/dri/card0
7f6988935000-7f698893d000 rw-s 00000000 00:05 293408 /drm mm object (deleted)
7f698893d000-7f6988945000 rw-s 105c3f000 00:06 357 /dev/dri/card0
7f6988945000-7f698894d000 rw-s 105c37000 00:06 357 /dev/dri/card0
7f698894d000-7f6988955000 rw-s 00000000 00:05 296201 /drm mm object (deleted)
7f6988955000-7f698895d000 rw-s 00000000 00:05 296048 /drm mm object (deleted)
7f698895d000-7f6988986000 r--p 00000000 08:02 4195320 /usr/share/fonts/truetype/liberation/LiberationSans-Italic.ttf
7f6988986000-7f6988c86000 rw-p 00000000 00:00 0
7f6988c86000-7f6988c8b000 r-xp 00000000 08:02 1062796 /lib/x86_64-linux-gnu/libnss_dns-2.23.so
7f6988c8b000-7f6988e8b000 ---p 00005000 08:02 1062796 /lib/x86_64-linux-gnu/libnss_dns-2.23.so
7f6988e8b000-7f6988e8c000 r--p 00005000 08:02 1062796 /lib/x86_64-linux-gnu/libnss_dns-2.23.so
7f6988e8c000-7f6988e8d000 rw-p 00006000 08:02 1062796 /lib/x86_64-linux-gnu/libnss_dns-2.23.so
7f6988e8d000-7f6988e95000 rw-s 105c2f000 00:06 357 /dev/dri/card0
7f6988e95000-7f6988e9d000 rw-s 1029cc000 00:06 357 /dev/dri/card0
7f6988e9d000-7f6988ea5000 rw-s 105c1f000 00:06 357 /dev/dri/card0
7f6988ea5000-7f6988ec5000 rw-p 00000000 00:00 0
7f6988ec5000-7f6988ecd000 rw-s 00000000 00:05 294431 /drm mm object (deleted)
7f6988ecd000-7f6988ed5000 rw-s 00000000 00:05 291590 /drm mm object (deleted)
7f6988ed5000-7f6988ed6000 ---p 00000000 00:00 0
7f6988ed6000-7f69896d6000 rw-p 00000000 00:00 0
7f69896d6000-7f69896d7000 ---p 00000000 00:00 0
7f69896d7000-7f6989ed7000 rw-p 00000000 00:00 0
7f6989ed7000-7f6989ed8000 ---p 00000000 00:00 0
7f6989ed8000-7f698a6d8000 rw-p 00000000 00:00 0
7f698a6d8000-7f698a6f7000 rw-p 00000000 00:00 0
7f698a6f7000-7f698a777000 rw-s 00000000 00:05 28016670 /SYSV00000000 (deleted)
7f698a777000-7f698a7d7000 rw-s 00000000 00:05 27983901 /SYSV00000000 (deleted)
7f698a7d7000-7f698af8e000 rw-s 00000000 00:05 27951132 /SYSV00000000 (deleted)
7f698af8e000-7f698afbf000 r-xp 00000000 08:02 2762622 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqnmbearer.so
7f698afbf000-7f698b1be000 ---p 00031000 08:02 2762622 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqnmbearer.so
7f698b1be000-7f698b1bf000 r--p 00030000 08:02 2762622 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqnmbearer.so
7f698b1bf000-7f698b1c0000 rw-p 00031000 08:02 2762622 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqnmbearer.so
7f698b1c0000-7f698b1cf000 r-xp 00000000 08:02 2762623 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqgenericbearer.so
7f698b1cf000-7f698b3cf000 ---p 0000f000 08:02 2762623 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqgenericbearer.so
7f698b3cf000-7f698b3d0000 r--p 0000f000 08:02 2762623 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqgenericbearer.so
7f698b3d0000-7f698b3d1000 rw-p 00010000 08:02 2762623 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqgenericbearer.so
7f698b3d1000-7f698b413000 r-xp 00000000 08:02 2762624 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqconnmanbearer.so
7f698b413000-7f698b613000 ---p 00042000 08:02 2762624 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqconnmanbearer.so
7f698b613000-7f698b615000 r--p 00042000 08:02 2762624 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqconnmanbearer.so
7f698b615000-7f698b616000 rw-p 00044000 08:02 2762624 /usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqconnmanbearer.so
7f698b616000-7f698b617000 ---p 00000000 00:00 0
7f698b617000-7f698be17000 rw-p 00000000 00:00 0
7f698be17000-7f698bed0000 r--p 00000000 08:02 4195278 /usr/share/fonts/truetype/dejavu/DejaVuSans.ttf
7f698bed0000-7f698bf7c000 r--p 00000000 08:02 4195277 /usr/share/fonts/truetype/dejavu/DejaVuSans-Bold.ttf
7f698bf7c000-7f698c07c000 rw-p 00000000 00:00 0
7f698c07c000-7f698c5b2000 rw-p 00000000 00:00 0
7f698c5b2000-7f698c5b3000 ---p 00000000 00:00 0
7f698c5b3000-7f698cdb3000 rw-p 00000000 00:00 0
7f698cdb3000-7f698cdb4000 ---p 00000000 00:00 0
7f698cdb4000-7f69ccdb4000 rwxp 00000000 00:00 0
7f69ccdb4000-7f69ccdb5000 ---p 00000000 00:00 0
7f69ccdb5000-7f69cceb5000 rw-p 00000000 00:00 0
7f69cceb5000-7f69ccebb000 r-xp 00000000 08:02 2623740 /usr/lib/freecad-daily/lib/Start.so
7f69ccebb000-7f69cd0bb000 ---p 00006000 08:02 2623740 /usr/lib/freecad-daily/lib/Start.so
7f69cd0bb000-7f69cd0bc000 r--p 00006000 08:02 2623740 /usr/lib/freecad-daily/lib/Start.soAborted (core dumped)
BR,
HoWil
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10476 (Git)
Build type: None
Hash: b6150097e9cf4d7b0f5ad71f2f8750f2e7aac0d9
Python version: 2.7.12
OCC version: 7.1.0
