Meshing .... Error : Unknown string option 'Solver.Extension0'
HoWil
Post by HoWil »
Hello,
Just to report it.....
When meshing for instance a simple box on the daily-ppa I get the following Error message in the GMSH-dialog:
Error : Unknown string option 'Solver.Extension0' Error : Unknown string option 'Solver.Extension1' Error : Unknown string option 'Solver.Extension2' Error : Unknown string option 'Solver.Extension3' Error : Unknown string option 'Solver.Extension4' Error : Unknown string option 'Solver.Extension5' Error : Unknown string option 'Solver.Extension6' Error : Unknown string option 'Solver.Extension7' Error : Unknown string option 'Solver.Extension8' Error : Unknown string option 'Solver.Extension9'
Screenshot from 2017-03-16 21-29-00.png (174.3 KiB) Viewed 1513 times
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10490 (Git)
Build type: None
Hash: 378f99f1b318202db3bc89b45d691a0376d07512
Python version: 2.7.12
OCC version: 7.1.0
Re: Meshing .... Error : Unknown string option 'Solver.Extension0'
Post by bernd »
Which version of gmsh? Does it happen if you run gmsh with the geo and brep too?
Post by bernd »
We had it here too. I never had this problem. viewtopic.php?f=18&t=21147
joha2
Post by joha2 »
I just built the latest FreeCAD source on my thinkpad with
OS: Linux Mint 17.1 Rebecca
Version: 0.17.10492 (Git)
Build type: Unknown
Hash: 58ed7c3688beb98ef89994919eddd9a4d0dd55e2
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
which uses also a very old version of gmsh (2.8.3) coming from some outdated Ubuntu repo and I got nearly the same error.
I also tested bernds suggestion and loaded the geometry as a brep file directly into this old gmsh and I also got those messages.
~ $ gmsh blub.brep
Error   : Unknown string option 'General.ExecutableFileName'
Error   : Unknown string option 'General.RecentFile5'
Error   : Unknown string option 'General.RecentFile6'
Error   : Unknown string option 'General.RecentFile7'
Error   : Unknown string option 'General.RecentFile8'
Error   : Unknown string option 'General.RecentFile9'
Error   : Unknown number option 'General.FltkColorScheme'
Error   : Unknown string option 'Solver.OctaveInterpreter'
Error   : Unknown string option 'Solver.PythonInterpreter'
This error vanishes if you download the latest gmsh 2.16.0 version from gmsh.info and use this as the binary for meshing in FreeCAD.
(See Preferences -> FEM -> GMSH -> binary path.)
I hope this helps.
Best wishes
Johannes
Edit: I checked also the ability to use recombination elements (making quads from tets) and it seems that shown quad mesh meshed with gmsh 2.8.3 is not perturbed, in contrast to the same geometry meshed with 2.16.0 (like in https://forum.freecadweb.org/viewtopic.php?f=18&t=21349)
HoWil
Post by HoWil »
bernd wrote:Which version of gmsh? Does it happen if you run gmsh with the geo and brep too?
I used the standard version 2.10.1 from Ubuntu 16.04 respository.
I have downloaded 2.16.0 from gmsh.info, changed settings form gmsh-path and the error vanishes. Changed settings back to sytem-standard-gmsh and cant reproduce the problem. :o Strange!
Cound run standard-gmsh with the geo files in tmp without problems
/tmp$ gmsh shape2mesh.geo -format unv
Delaunizing vertices...
Delaunay seconds:  0.003757
Creating surface mesh ...
Surface mesh seconds:  0.000922
Recovering boundaries...
Boundary recovery seconds:  0.001003
Removing exterior tetrahedra ...
Exterior tets removal seconds:  0.000121
Recovering Delaunayness...
Delaunay recovery seconds:  0.001274
Optimizing mesh...
Optimization seconds:  0.000444
Writing nodes.
Writing elements.
Writing faces.
Writing edges.
Output seconds:  0.00059
Total running seconds:  0.008249
Statistics:
  Input points: 314
  Input facets: 624
  Input segments: 936
  Input holes: 0
  Input regions: 0
  Mesh points: 314
  Mesh tetrahedra: 880
  Mesh faces: 2072
  Mesh edges: 1505
  Mesh faces on facets: 624
  Mesh edges on segments: 936
Loading the geometry with gmsh Box_Geometry.brep works without problems.
@Bernd: which version of gmsh do you use?
BR,
HoWil
HoWil
Post by HoWil »
joha2 wrote: Edit: I checked also the ability to use recombination elements (making quads from tets) and it seems that shown quad mesh meshed with gmsh 2.8.3 is not perturbed, in contrast to the same geometry meshed with 2.16.0 (like in https://forum.freecadweb.org/viewtopic.php?f=18&t=21349)
Thanks for pointing this out!
BR
HoWil
Post by bernd »
HoWil wrote:@Bernd: which version of gmsh do you use?
$ gmsh --version
2.13.3
