jmaustpc wrote:Hi LukeLots of improvements, but I have some new bugs nowmrlukeparry wrote:Okay everyone, I've push a lot of changes through that I've worked on the past week.
distance, horizontal and vertical all don't display the arrows and lines in the correct place,
diameter seems to work properly but radius does not. Radius forgets the placement of the text, i.e. after each move it goes back to its default location.
Jim
P.s. here is a picture showing the display problems with the dimensions
I've made an improvement so that for straight line edges it uses a simpler projection algorithm. This doesn't remove the issue entirely because there's an underlying problem with OpenCascade's memory management which I believe is the culprit behind this.
For now it should happen rarely. Or atleast I hope so now.
TI've noticed an issue with projected type for dimensions on 3D projections.
