(Solved)Assembly2 in Version: 0.16.5602 (Git)
Does Assembly2 work in the environment listed below; or is this my installation problem ?
Assembly2 does not appear in "Switch Between WBs" dropdown menu!
Works fine in .15 for me!
OS: Windows Vista
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Hash: 037ec5be789d52b2f82cc18a4b8e37b6cdc25e6b
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
OS: Windows Vista
Qt version: 4.8.6
Re: Assembly2 in Version: 0.16.5602 (Git)
It should work, but the 0.16.xxxx versions are standalone so you will need to copy the assembly2 folder from the MOD folder in you 0.15 to the MOD folder of the 0.16. If it doesn't show up in the dropdown try restarting FreeCAD and go to Tools>Customize..>Workbenches and make sure it is enabled.
"fight the good fight"
Report View: After FreeCAD launched -->
During initialization the error DLL load failed: The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log for more detail. occurred in C:\Users\willy\Desktop\FreeCAD_0.16.5602_x86_dev_bin\Mod!\assembly2\InitGui.py -->
multiarray.pyd problem again! Have seen this before!
What is/was the resolution?
Re: (Solved)Assembly2 in Version: 0.16.5602 (Git)
NUMPHY file again; just like .15
Try to delete the folder assembly2 and after do a fresh install of assembly2 module (new download). And i noticed ! in Mod!\ path.
Should that be there?
It is not in the real path; it appeared when I cut and pasted the error message!triplus wrote:And i noticed ! in Mod!\ path.
I downloaded the numphy folder as suggested by peterl94 in
Okay, so it must be that multiarray.pyd is somehow compiled in a way that is not compatible with XP. I would try replacing the numpy folder with the one form the official numpy installer. I think that is how microelly2 got it to work. For your convenience, I've uploaded the numpy folder from the installer, so that you don't need to use the installer yourself.
1. Delete D:\Test\FreeCAD_0.15.4527_x86_WinXP_dev_bin\bin\lib\site-packages\numpy
2. Replace with the numpy folder from this zip: https://drive.google.com/open?id=0Bx4ov ... authuser=0
This worked !
Good to hear that.
Thanks a lot. I had a similar problem and your solution worked well.
Great!!! Now works fine.
weasel_face : Marco Silveira
This only affects Windows 32-bit, or also affects Linux 32-bit?
Renato
Renato
