Hi guys,
I'm a bit unhappy with our edit workflow for while now. I would like to do some changes now and want your opinion.
First I would move the edit mode stuff from the document to the Controller, since its a Application wide mode.
Then I would make it mandatory that a edit action always open a TaskDialog to give the user more feedback and
control. Even if its a pure 3D interaction. (yes Yorik, that would mean a interface for python and the TaskView ).
Also I would activate the undo in edit again. The sketcher e.g. is able to undo insert and deletion of geometry and
constraints, but its turned of at the moment. We have only to take care that the user not undo further back then
the edit mode started. There he can undo e.g. the SketchObject he edits...
Further a GuiCommand which end all kind of editing and bring the application back to normal mode. (like ESC).
And if no objections rise I would remove the SketchFlat code, since its GPL3 and there fore a threat to our license integrity.
What do you mean?
Edit Control
Edit Control
Stop whining - start coding!
Re: Edit Control
this would be nice but I am curious to know if its license is the only reason that we steered away from sketchflat?jriegel wrote: And if no objections rise I would remove the SketchFlat code, since its GPL3 and there fore a threat to our license integrity.
Re: Edit Control
No, the other reason is that the solver code is mixed up with all the GUI stuff so that is almost impossible to have a clean code basis., i.e. the pure solver code. Jürgen worked on hat in the past but then gave up at a certain point.this would be nice but I am curious to know if its license is the only reason that we steered away from sketchflat?
Re: Edit Control
Actually the solver is really good. Better than sketchsolve, but....
The author abandoned the open source version and made a commercial only version available.
Interesting is the paper he wrote. If we ever want to implement our own solver I would
say thats the way to go:
http://cq.cx/dl/sketchflat-internals.pdf
He use a neat trick by using pre-coded derivatives to speed up the newton solver, which is
blazing fast!
blazing fast!
