[Solved] Question about FEM examples - mutlimaterial bending beam 5 faces
johnwang
Post by johnwang »
Tried it.
The model is Fusion face1+face2+face3+face4+face5. The value of the FemMaterial1's References is 'Face3[Face1]'. How do I read it? Does it mean:
1. Face3's materrial is FemMaterial1
2. Face1's materrial is FemMaterial1
3. Both are FemMaterial1
4. The face between Face3 & Face1 (which is Fcae2) is FemMaterial1
Any of these true?
Regards,
John
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
johnwang
Re: Question about FEM examples - mutlimaterial bending beam 5 faces
Post by johnwang »
From FreeCAD\Mod\Fem\femexamples\material_multiple_bendingbeam_fivefaces.py:
Looks like that "Face1" is a bit confusing.
bernd
Post by bernd »
johnwang wrote: Sat Nov 21, 2020 10:33 am From FreeCAD\Mod\Fem\femexamples\material_multiple_bendingbeam_fivefaces.py:
better to post a link to the code. but use the commit link to keep it even after a change ... https://github.com/FreeCAD/FreeCAD/blob ... es.py#L136
    material_object1.References = [(doc.Face3, "Face1")]
I will have a look.
The time beeing. If you double cklick in the gui in the FEM Material and select a face in the task panel the face should be hightlighted if the body is visible.
bernd
Post by bernd »
yep select the face in tree view material task panel and the face gets hightligthed in 3D-Scene. If not you need to switch visibilities of some objects.
bernd
Post by bernd »
seams all good to me ...
- document object "FemMaterial1": element "Face1" of the document object "Face3"
- document object "FemMaterial2": element "Face1" of the document object "Face2 and element "Face1" of document object "Face4"
- document object "FemMaterial3": since references are empty take all the rest
johnwang
Post by johnwang »
bernd wrote: Mon Nov 23, 2020 11:40 am seams all good to me ...
All good. Just at the beginning, hard to understand 'face1 of face1'.
It's pretty smart if no reference specified, it will pick the rest objects. I was thinking It applies to all, but wondering why it is at the end.
If I want to retrieve the material values with script, it seems I have to leave the one with no reference at the end.
