error in FreeCAD units system: Density unit is not returned in Python
Postby bernd » Tue Feb 12, 2019 6:32 am
code:
from FreeCAD import Units
Units.Unit('500 GPa')
Units.Pressure
Units.Unit('500 kg/m^3')
Units.Density
output:
Unit: kg/(mm*s^2) (-1,1,-2,0,0,0,0,0) [Pressure]
>>> Units.Pressure
Unit: kg/mm^3 (-3,1,0,0,0,0,0,0) [Density]
>>> Units.Density
AttributeError: module 'Units' has no attribute 'Density'
OS: Debian GNU/Linux buster/sid
Version: 0.18.15836 (Git)
Build type: Unknown
Hash: 51b32d75b411eaf5e75761be99e41a1b16f85943
Python version: 3.7.2+
Qt version: 5.11.3
Locale: German/Switzerland (de_CH)
Re: error in FreeCAD units system: Density unit is not returned in Python
Postby bernd » Tue Feb 12, 2019 6:56 am
a question in this regard ... Is it possible to return the Unit signature tuple by Python?
Units.Pressure
returns all unit informations.
Units.Pressure.Type
returns the name as string.
but I only need the signature tuple.
EDIT: I do not need this anymore. See next post. I could reduce this to much simpler expression.
Postby bernd » Tue Feb 12, 2019 7:48 am
I have the following string:
'Pressure'
and I would like to have the return of:
Units.Pressure
Does someone know how to do that with FreeCAD unit system?
Postby bernd » Tue Feb 12, 2019 7:57 am
'Pressure'
Units.Pressure
Found one myself, but it needs the FreeCADGui ...
myunittype = 'Pressure'
FreeCADGui.doCommand("myunit = Units." + myunittype)
myunit
output:
>>> myunit = Units.Pressure
>>> myunit
without FreeCADGui would be way smarter ...
Postby bernd » Tue Feb 12, 2019 8:30 am
again found it myself ...
getattr(FreeCAD.Units, "Pressure")
sorry for all the noise ...
The origin of the topic, the missing Density unit is still there ...
Postby wmayer » Tue Feb 12, 2019 2:13 pm
Postby bernd » Tue Feb 12, 2019 4:46 pm
:D
