Appveyor is timing out
Re: Appveyor is timing out
Ok. I will them substitute mine with yours when I rebase :
https://github.com/FreeCAD/FreeCAD/pull ... f16cb2e57b
This is the first failing file:
https://github.com/FreeCAD/FreeCAD/blob ... athPost.py
I do not see anything that may be disturbing Travis.
This is the log without it:
https://travis-ci.org/FreeCAD/FreeCAD/jobs/534190818
This is the log with it:
https://travis-ci.org/FreeCAD/FreeCAD/jobs/534151312
When it is included, the output of previous Path tests is not even there, it shows the error:
Any idea is very much welcome.
TestPathApp (unittest.loader._FailedTest) ... ERROR
I made a mistake yesterday during the search for the tests that failed. I enabled one test that is commented out in master.
I am doing a kind of binary search of this tests:
The first "paragraph" passes. The second paragraph (including all four tests) fails. I am running the build with the first two tests of this second paragraph enabled here:
https://travis-ci.org/FreeCAD/FreeCAD/jobs/534406889
from PathTests.TestPathLog import TestPathLog
from PathTests.TestPathCore import TestPathCore
#from PathTests.TestPathPost import PathPostTestCases
from PathTests.TestPathGeom import TestPathGeom
from PathTests.TestPathOpTools import TestPathOpTools
from PathTests.TestPathUtil import TestPathUtil
from PathTests.TestPathDepthParams import depthTestCases
from PathTests.TestPathDressupHoldingTags import TestHoldingTags
from PathTests.TestPathDressupDogbone import TestDressupDogbone
#from PathTests.TestPathStock import TestPathStock
#from PathTests.TestPathTool import TestPathTool
#from PathTests.TestPathTooltable import TestPathTooltable
#from PathTests.TestPathToolController import TestPathToolController
#from PathTests.TestPathSetupSheet import TestPathSetupSheet
#from PathTests.TestPathDeburr import TestPathDeburr
This test is failing in Travis Windows:
https://github.com/FreeCAD/FreeCAD/blob ... ingTags.py
Any idea why it could be?
I think I am becoming insane.
This:
https://github.com/FreeCAD/FreeCAD/blob ... PathApp.py
does not fail.
This:
fails.
To me it is the same content.
I do not know Python enough, but these tests do not provide much information when they fail. That is not very convenient...
This:
does not fail.
This:
fails.
I don't see the difference, but python is sensitive to tabs/spaces.
You might want to weigh in on these threads
https://forum.freecadweb.org/viewtopic.php?f=18&t=35428
https://forum.freecadweb.org/viewtopic.php?f=10&t=36515
"fight the good fight"
Thanks for weighing in.sgrogan wrote: ↑Tue May 21, 2019 9:50 pmI don't see the difference, but python is sensitive to tabs/spaces.
I am going to continue doing tests, but I go blind...
I think I might have found the culprit of the Path tests failing. Indirectly loading the Gui.wmayer wrote:...ping...
The test that now fails:
imports:
PathScripts.PathDressupHoldingTags
which imports:
import PathScripts.PathDressup
https://github.com/FreeCAD/FreeCAD/blob ... Dressup.py
which imports and uses the GUI:
import FreeCAD
import FreeCADGui
import PathScripts.PathJob as PathJob
def selection():
'''isActive() ... return True if a dressup command is possible.'''
if FreeCAD.ActiveDocument:
sel = FreeCADGui.Selection.getSelectionEx()
if len(sel) == 1 and sel[0].Object.isDerivedFrom("Path::Feature") and PathJob.Instances():
return sel[0].Object
return None
def hasEntryMethod(path):
'''hasEntryDressup(path) ... returns true if the given object already has an entry method attached.'''
if 'RampEntry' in path.Name or 'LeadInOut' in path.Name:
return True
if 'Dressup' in path.Name and hasattr(path, 'Base'):
return hasEntryMethod(path.Base)
return False
I am not sure if we should only execute the tests in Gui mode (which makes them quite worthless for CI testing), or if we should think in rewritten them... what do you think?
I think the test should be adjusted to be callable from command line mode.
