shadows in the freecad viewport
Re: shadows in the freecad viewport
Postby Kunda1 » Thu Sep 24, 2020 12:25 pm
What about the ladybug solar analysis integration that yorik implemented recently (that deprecated pysolar)
Need to find the link
saso
Postby saso » Thu Sep 24, 2020 12:40 pm
aang89 wrote:
Wed Sep 23, 2020 7:56 am
Given a surface, is there a way to measure the ratio of shadowed areas vs the lighted up areas on that surface?
User microelly2 created a script that can possibly do this for you, basically it calculates the shadows and creates real geometry for it, from which you can then get the area... Here is a link to the discussion https://forum.freecadweb.org/viewtopic. ... ow#p146408 and the link to his website with the script and an example model http://freecadbuch.de/doku.php?id=blog: ... bbildungen
The script can probably get improved but I guess the basic concept should be ok, here is something similar done in creo https://www.youtube.com/watch?v=oppjLDoToa4
aang89
Postby aang89 » Fri Sep 25, 2020 12:00 am
Thanks Kunda1 and saso!
This is quite similar to what I'm looking for. I'll have a look at these scripts. Thanks for all the help again!
obelisk79
Postby obelisk79 » Tue Sep 29, 2020 2:27 am
Was very excited (I know, its 'just' eye candy, but still) to try out the shadow shading.
I'm using the realthunder fork: https://github.com/realthunder/FreeCAD/tree/LinkMerge/
I don't have any shadows when I enable them from the pulldown icon.
Am I missing some kind of parameter to set in order for them to work properly?
I'm using an AMD R7950 video card if that makes a difference.
realthunder
Postby realthunder » Tue Sep 29, 2020 3:28 am
Are you using Windows? Maybe you can try some fix proposed here.
obelisk79
Postby obelisk79 » Tue Sep 29, 2020 3:41 am
Thanks, but I've already tried that without any luck. Maybe I need to make the jump to nvidia if I want the fancy graphics.
koin3D
Postby koin3D » Wed Sep 30, 2020 10:06 pm
Also using an AMD graphic card.
- Did a test, using glintercept NO_ERROR edition :
https://github.com/YvesBoyadjian/glinte ... ag/1.3.5.5
- With last version of realthunder FreeCAD compiled today, I have an error message in the console :
23:42:00 Coin info in SoGLSLShaderObject::printInfoLog(): GLSLfragmentShader log: 'Fragment shader failed to compile with the following errors:
ERROR: 0:67: error(#143) Undeclared identifier: DirectionalLight
ERROR: 0:67: error(#202) No matching overloaded function found: DirectionalLight
ERROR: error(#273) 2 compilation errors. No code generated
- And, effectively, if I also copy "gliConfig.ini" in the exe directory, I have logs and shaders dump, that shows that the "DirectionalLight" method is missing in the fragment shader.
@realthunder :
- In SoShadowGroupP::setFragmentShader(), there must be a missing call to
"gen.addNamedFunction(SbName("lights/DirectionalLight"), FALSE);"
realthunder
Postby realthunder » Fri Oct 02, 2020 12:24 am
@realthunder :
It's work on my laptop. Are you using the upstream Coin3D or my fork?
koin3D
Postby koin3D » Fri Oct 02, 2020 7:27 am
@realthunder :
I have used the link provided by obelisk79 :
Downloaded the sources, and done a full compilation, in debug mode
realthunder
Postby realthunder » Fri Oct 02, 2020 9:28 am
But the shader error is reported from within libCoin. It should work with my fork of coin.
