PartDesign Hole feature
m1cha1
Re: PartDesign Hole feature
Postby m1cha1 » Thu Apr 29, 2021 10:00 am
I have two cases with hole based on sketch:
1. If you make a sketch with slot or rectangle with rounded edges.
2. If you make a sketch with arc and then if you try to make a hole using this sketch the model will disappear
According to wiki "The Hole feature creates one or more holes from a selected sketch's circles"
OS: Windows 10 Version 2009
Version: 0.20.24787 (Git)
Hash: ea96f1860164ff8a6751b21b3fb4d425fc87f5e5
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Postby chrisb » Thu Apr 29, 2021 11:22 am
Please attach the file.
m1cha1
Postby m1cha1 » Thu Apr 29, 2021 12:39 pm
Below example
hole-example.FCStd
(17.16 KiB) Downloaded 6 times
Postby chrisb » Mon May 03, 2021 11:47 pm
I have checked your file (it looks different from <our screenshot). It works perfect here. Please note that the hole feature creates a circular hole in the center of each circle or arc. It doesn't create slots. Use pocket for those.
OS: macOS 10.16
Version: 0.20.24825 (Git)
Hash: ccc4151b3020969450325466e385850783795325
Python version: 3.9.2
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.1
Locale: C/Default (C)
