[SOLVED] Picking fails with "OpenInventor" navigation mode
maxlem
Post by maxlem »
Hello,
I get a picking failure with the OpenInventor nav mode
steps:
Open Freecad
New document
New Part
Create cude
(in CAD nav mode I can pick faces, edges, if I switch to OpenInventor I can't anymore)
[edit: building master to try out...]
OS: Ubuntu Core 20 (KDE/plasma)
Version: 0.19.24276 (Git)
Build type: Unknown
Branch: releases/FreeCAD-0-19
Python version: 3.8.5
Qt version: 5.12.8
Coin version: 4.0.0
OCC version: 7.5.0
maxlem
Re: Picking fails with "OpenInventor" navigation mode
Post by maxlem »
I tried to build master but the buil fails...
cmake -S ../freecad-source -B . -DBUILD_QT5=ON -DPYTHON_EXECUTABLE=/usr/bin/python3
In file included from /home/maxime/Downloads/freecad-source/src/Base/RotationPyImp.cpp:33:
/home/maxime/Downloads/freecad-source/src/Base/RotationPy.cpp:137:40: error: ‘staticCallback_toEuler’ was not declared in this scope; did you mean ‘staticCallback_slerp’?
  137 |         reinterpret_cast<PyCFunction>( staticCallback_toEuler ),
/home/maxime/Downloads/freecad-source/src/Base/RotationPy.cpp:641:12: error: no declaration matches ‘PyObject* Base::RotationPy::staticCallback_toEuler(PyObject*, PyObject*)’
  641 | PyObject * RotationPy::staticCallback_toEuler (PyObject *self, PyObject *args)
/home/maxime/Downloads/freecad-source/src/Base/RotationPy.cpp:641:12: note: no functions named ‘PyObject* Base::RotationPy::staticCallback_toEuler(PyObject*, PyObject*)’
[ 41%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/UnitsSchemaInternal.cpp.o
In file included from /home/maxime/Downloads/freecad-source/src/Base/GeometryPyCXX.h:34,
                 from /home/maxime/Downloads/freecad-source/src/Base/RotationPyImp.cpp:28:
/home/maxime/Downloads/freecad-build/src/Base/RotationPy.h:21:18: note: ‘class Base::RotationPy’ defined here
   21 | class BaseExport RotationPy : public Base::PyObjectBase
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp: In static member function ‘static Base::UnitsSchemaPtr Base::UnitsApi::createSchema(Base::UnitSystem)’:
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:115:21: error: ‘make_unique’ is not a member of ‘std’
  115 |         return std::make_unique<UnitsSchemaInternal>();
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:115:21: note: ‘std::make_unique’ is only available from C++14 onwards
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:115:52: error: expected primary-expression before ‘>’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:115:54: error: expected primary-expression before ‘)’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:117:21: error: ‘make_unique’ is not a member of ‘std’
  117 |         return std::make_unique<UnitsSchemaMKS>();
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:117:21: note: ‘std::make_unique’ is only available from C++14 onwards
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:117:47: error: expected primary-expression before ‘>’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:117:49: error: expected primary-expression before ‘)’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:119:21: error: ‘make_unique’ is not a member of ‘std’
  119 |         return std::make_unique<UnitsSchemaImperial1>();
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:119:21: note: ‘std::make_unique’ is only available from C++14 onwards
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:119:53: error: expected primary-expression before ‘>’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:119:55: error: expected primary-expression before ‘)’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:121:21: error: ‘make_unique’ is not a member of ‘std’
  121 |         return std::make_unique<UnitsSchemaImperialDecimal>();
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:121:21: note: ‘std::make_unique’ is only available from C++14 onwards
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:121:59: error: expected primary-expression before ‘>’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:121:61: error: expected primary-expression before ‘)’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:123:21: error: ‘make_unique’ is not a member of ‘std’
  123 |         return std::make_unique<UnitsSchemaCentimeters>();
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:123:21: note: ‘std::make_unique’ is only available from C++14 onwards
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:123:55: error: expected primary-expression before ‘>’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:123:57: error: expected primary-expression before ‘)’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:125:21: error: ‘make_unique’ is not a member of ‘std’
  125 |         return std::make_unique<UnitsSchemaImperialBuilding>();
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:125:21: note: ‘std::make_unique’ is only available from C++14 onwards
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:125:60: error: expected primary-expression before ‘>’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:125:62: error: expected primary-expression before ‘)’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:127:21: error: ‘make_unique’ is not a member of ‘std’
  127 |         return std::make_unique<UnitsSchemaMmMin>();
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:127:21: note: ‘std::make_unique’ is only available from C++14 onwards
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:127:49: error: expected primary-expression before ‘>’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:127:51: error: expected primary-expression before ‘)’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:129:21: error: ‘make_unique’ is not a member of ‘std’
  129 |         return std::make_unique<UnitsSchemaImperialCivil>();
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:129:21: note: ‘std::make_unique’ is only available from C++14 onwards
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:129:57: error: expected primary-expression before ‘>’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:129:59: error: expected primary-expression before ‘)’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:131:21: error: ‘make_unique’ is not a member of ‘std’
  131 |         return std::make_unique<UnitsSchemaFemMilliMeterNewton>();
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:131:21: note: ‘std::make_unique’ is only available from C++14 onwards
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:131:63: error: expected primary-expression before ‘>’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:131:65: error: expected primary-expression before ‘)’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp: In static member function ‘static void Base::UnitsApi::setSchema(Base::UnitSystem)’:
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:150:31: error: ‘make_unique’ is not a member of ‘std’
  150 |         UserPrefSystem = std::make_unique<UnitsSchemaInternal>();
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:150:31: note: ‘std::make_unique’ is only available from C++14 onwards
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:150:62: error: expected primary-expression before ‘>’ token
/home/maxime/Downloads/freecad-source/src/Base/UnitsApi.cpp:150:64: error: expected primary-expression before ‘)’ token
[ 41%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/UnitsSchemaMKS.cpp.o
make[2]: *** [src/Base/CMakeFiles/FreeCADBase.dir/build.make:930: src/Base/CMakeFiles/FreeCADBase.dir/UnitsApi.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [src/Base/CMakeFiles/FreeCADBase.dir/build.make:709: src/Base/CMakeFiles/FreeCADBase.dir/RotationPyImp.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:2591: src/Base/CMakeFiles/FreeCADBase.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 41%] Linking CXX shared library ../../../../Mod/Path/area.so
[ 41%] Built target area
make: *** [Makefile:130: all] Error 2
openBrain
Post by openBrain »
As indicated in Mouse navigation, OpenInventor needs a Ctrl+Click to pick. Is thiis what you're doing ?
maxlem
Re: [SOLVED] Picking fails with "OpenInventor" navigation mode
Post by maxlem »
Only two things to answer,
D'oh!
Thanks
Post by wmayer »
You seem to have done an in-source build in the past and now do an out-of-source build. With git status you get an overview of all files that are not part of the repository and that have been created with the in-source build. These files must be deleted.
For v0.19 the minimum C++ version was C++11 but with the development of v0.20 it's C++17. However, for older builds the old version is still cached by CMake and you should run cmake-gui to manually change the entry BUILD_ENABLE_CXX_STD in the drop-down box
