I think you need to make a PR (it can be a draft PR if you want) for a Snap to be generated.
[To be reworked] Sketcher Tool settings : testers welcome!
Re: Sketcher Tool settings : testers welcome!
My apologies for the delay in fixing this issue.
git commit 2326186428cfc3d59a9995de0f87a9c043a9f41f
Ok. Sorry for our misunderstanding.
This PR is just for snap creation:
https://github.com/FreeCAD/FreeCAD/pull/7118
Thank you for your support
- adrianinsaval
isn't paddle routinely building on windows? or did he see the light and join the penguin tribe
We need to setup a little experimental build guild.
We have Linux (Snap) covered (but it would be awesome if we could automate it and use keywords to trigger builds from github).
Please some guidance for testing in linux with snap method.
When a build is ready, i'll post how to test it. But in general read the Snap wiki page for more context
Heads up, Snap is ready!
Install info is in the GH issue comments: https://github.com/FreeCAD/FreeCAD/pull ... 1173129954
I post here my testing results:
- input boxes not admit operations like 12+1 or 3*4
- circle tool: how to enter diameter?
- There are not tooltips to help understand functionality.
- when enter radius or line length, I cannot view the result before apply the desired restriction. (limitation apply to all input boxes).
I like a list in a post of things to test or a guide to concrete features to test for referencing my suggestions with a searchable title, for example:
Sketcher Tool Settings to test 2022 07 04 sketchertst (sketchertst is an example unique keyword to search)
To test:
Sketcher Tools
DSH Line
DSH Rectangle
DSH Circle
DSH Ellipse
DSH Polygon
Thank you.
To test:
Sketcher Tools
DSH Line
DSH Rectangle
DSH Circle
DSH Ellipse
DSH Polygon
Thank you.
