Low hanging fruits
mandeep7
Re: Low hanging fruits
Postby mandeep7 » Sun Apr 03, 2016 12:27 pm
ian.rees wrote:Last night, I gave a small talk on using FreeCAD at our local maker space. One of the audience pointed out that the capitalisation in the tooltips (specifically in Part Design) is inconsistent eg "Pad a.." vs "create a pocket...". I think the right way to go is capitalising the first letter, as most of the tooltips do. Perhaps finding/fixing these through FreeCAD would be a good starter project? -Ian-
I edited the Part design ones.
Also, there was extra "please" in some cases and hence seemed inconsistent.
e.g. "Please create a subtractive or additive feature first, please"
Created the pull request at: https://github.com/FreeCAD/FreeCAD/pull/131
Please review and if this is acceptable then I can look further into other workbenches to make it perfect.
ian.rees
Postby ian.rees » Mon Apr 04, 2016 3:08 am
mandeep7 wrote:Please review and if this is acceptable then I can look further into other workbenches to make it perfect.
Your changes look good to me, thanks!
We usually make a forum post in the "Pull Requests" section at the same time as the github pull request for changes to merge to master. -Ian-
mandeep7
Postby mandeep7 » Mon Apr 04, 2016 9:27 am
ian.rees wrote: Your changes look good to me, thanks!
Thanks ian,
I just added a new post there.
NormandC
Postby NormandC » Wed Apr 06, 2016 3:17 am
I'm wondering if this long standing feature request of mine would qualify in your list of "low hanging fruits".
issue #494 Objects names in Label & Attributes Tree View should be translatable
(Come on, say it: most of you weren't even aware of FreeCAD back then :D )
Right now, when you create a Part primitive, their labels are automatically written in the system language. To prove it, I changed FreeCAD's language settings to French, German and Spanish and went crazy with primitives:
But primitives are the only objects with translated labels. All FreeCAD objects labels should be translatable. I'm guessing this should not be so hard to code in? If it's a simple repetitive task that anyone could do once they know what to add and where, I'd even be willing to help out, in a separate branch of course.
Thanks.
PrzemoF
Postby PrzemoF » Wed Apr 06, 2016 8:01 am
It doesn't seem to hard. I'd translate only when an object is created and leave it like that. No translatione when the language changes.
NormandC
Postby NormandC » Wed Apr 06, 2016 12:26 pm
Agreed, forget that comment I made in the report, it's not necessary IMHO and that's how the translated primitive labels currently work, that is they are translated once at creation.
Postby Kunda1 » Tue Jan 17, 2017 12:00 pm
What FC objects are left to translate beside Part Primitive ?
FYI, i notated issue #494 specifically note: (http://www.freecadweb.org/tracker/view.php?id=494#c7837)
PrzemoF
Postby PrzemoF » Wed Jan 18, 2017 6:08 pm
Another easy task: add material properties from sculpteo webpage [1] to FreeCAD library.
[1] https://www.sculpteo.com/en/materials/m ... fications/
Postby Kunda1 » Wed Jan 18, 2017 7:43 pm
FYI there is a tag on the bugtracker called: #lowhangingfruit to keep track of these issues
If it's OK with the devs, we could move proposed issues to the tracker
PrzemoF
Postby PrzemoF » Wed Jan 18, 2017 9:43 pm
Thanks! I ddn't know that!
