- Please add a license notice to QListWidgetWithDragging.h
- This can be removed from DlgWorkbenches as it is of no use there.
enum Type { Toolbar, Toolboxbar };
- You don't need the extra class DlgWorkbenches. Just move the relevant stuff to DlgWorkbenchesImp
- Build failure in DlgWorkbenchesImp::renameCustomToolbar because of the missing curly brace
Workbench drop down list is long, too long.
Re: Workbench drop down list is long, too long.
Thanks, I'll add the licence. There a a lot of empty/spare definitions, but I'm not sure what can be safely removed.
Found a bug: From the list of enabled workbenches you can drag an item to another instance of FreeCAD. This way it's possible to have a duplicate workbench.
Here is a list of what can be removed:
- addCustomToolbar
- removeCustomToolbar (2x)
- addCustomCommand
- removeCustomCommand
- moveUpCustomCommand
- moveDownCustomCommand
- enum Type
void DlgWorkbenchesImp::changeEvent(QEvent *e)
if (e->type() == QEvent::LanguageChange) {
retranslateUi(this);
else {
QWidget::changeEvent(e);
Thanks for the review and the fixes! I got it all problems solved, but I'm not happy with the quality of the code - there are some repetitive code sections that I'd like to remove, but I'm struggling with C++ classes. Can you take a look at the comments that I left in-line and let me know if what I want to do makes sense?
A new version: https://github.com/PrzemoF/FreeCAD_sf_m ... benches_v4
A fully functional version: https://github.com/PrzemoF/FreeCAD_sf_m ... benches_v5
Demo: http://firszt.eu/FreeCAD/FreeCAD_workbenches_v5.webm
Supported:
- adding, removing or changing order with buttons
- adding, removing or changing order by dragging, but only within one FreeCAD instance
- adding all workbenches to "enabled" group with one button click
- sorting "enabled" group with one button click
- saving/restoring workbenches to Preferences
-"disabled" group is always sorted and user cannot change the order
Do we need a button to "remove all from enabled"? It would be trivial change, but I don't want to overload the Gui with useless features.
Potential pitfalls:
- Leaving None as only active workbench or removing all workbenches as it sets None wb as the only active workbench.Activating None wb removes Tools menu, so there is no easy way back. There are 2 ways to recover: setting start workbench in Preferences to something else not "None" - this restores Tools menu. Another way is to remove "Workbenches" group from Preferences file (user.cfg), so all workbenches are added to "enabled" group.
Supported:
Potential pitfalls:
You can also add a method to QListWidgetCustom.make function set_list_properites(QListWidgetCustom)?
You can make this a member of DlgWorkbenchesImp which you then set in the constructor to "ALL"."ALL" should be a "magic" string defined in class, but I don't know yet how to do it
Thanks! So I have to extend QListWidgetCustom into a proper class with constructor, destructor in separate .cpp file and so on?
I'll add "ALL" string as suggested - it's used in a few places, so it's better to have one definition to avoid future problems.
I'll have to rethink how to use load_enabled_workbenches in src/Gui/Actions.cpp - I was getting some missing object error. Currently there are identical code in 2 places to get the workbenches from preferences. I src/Gui/Action.cpp
and in src/Gui/DlgWorkbenchesIp.cpp:
with the call:
QStringList items = Application::Instance->workbenches();
hGrp = App::GetApplication().GetParameterGroupByPath("User parameter:BaseApp/Workbenches");
enabled_wbs = QString::fromStdString(hGrp->GetASCII("Enabled", "ALL").c_str());
enabled_wbs_list = enabled_wbs.split(QLatin1String(","), QString::SkipEmptyParts);
const QString all_workbenches = QString::fromAscii("ALL");
if (enabled_wbs_list.at(0) == all_workbenches) {
items.removeFirst();
for (QStringList::Iterator it = items.begin(); it != items.end(); ++it) {
enabled_wbs_list.append(*it);
enabled_wbs_list.sort();
QStringList DlgWorkbenchesImp::load_enabled_workbenches()
QString enabled_wbs;
QStringList enabled_wbs_list;
ParameterGrp::handle hGrp;
return enabled_wbs_list;
QStringList enabled_wbs_list = load_enabled_workbenches();
QStringList workbenches = Application::Instance->workbenches();
int i = 0;
QPixmap px;
QString mt;
if (enabled_wbs_list.at(0) == QString::fromAscii("ALL")) {
enabled_wbs_list.removeFirst();
for (QStringList::Iterator it = workbenches.begin(); it != workbenches.end(); ++it) {
Yes.So I have to extend QListWidgetCustom into a proper class with constructor, destructor in separate .cpp file and so on?
@wmayer: thanks for being so patient with my C++ and for all the tests, coments and hints!
The final version is here: https://github.com/PrzemoF/FreeCAD_sf_m ... benches_v6
I'm not going to make any changes unless there is something wrong, broken or missing.
I'll send a pull request after a few days to give some time for tests.
@all, thanks again for your input!
