Lego bricks in FreeCAD
People of FreeCAD
SO.... What about to create a LEGO BRICK libary for FreeCAD
The aim for this projekt is learning useful stuff:
[*] get use to with freecad
[*] improving my english
[*] get use to git (maintaining the libary)
[*] And MAYBE create addon for adding the lego bricks and to put them together.
Help is very much appreciated. I would be happy to have some feedback about my drawings.
[*] right measurements about the bricks
[*] opinion about the constructions ( how they are made)
[*] opinion about the construction is properly draw. (I read that in an .fcstd u can verify how the construction is drawn)
Here is the url of the legolib https://github.com/mase-tech/FreeCAD-LEGO
Feel free to suggest, help and correct me
kindly greetings from germany
mase
mase
- microelly2
Re: Lego bricks in FreeCAD
schöne idee
maybe that you want to improve my ideas of a brick factory
http://freecadbuch.de/doku.php?id=blog: ... _bausteine
I think this kind of toys is a good way to learn parametric modeling and the benefits of FreeCAD
another interesting project is a tool for wood connections:
starting here
http://www.selbst.de/moebel-holz-artike ... 41509.html
starting here
find ich auch . ich habe mir gestern nacht noch deine seite angeschaut und deine youtube videos. gefällt mir!schöne idee
There may be a lot of people, who have played with lego-bricks including me. Are you aware of leocad?: http://www.leocad.org/trac
There exists already a large library of lego-bricks. Allthough this library states, it does not have exact dimensions of the lego-bricks. This would of course be necessary for FreeCAD. And it would be fun, if one day the 3D-printers, you can afford to buy, are exact enough to print usable leo-bricks.
If one would write an importer to FreeCAD for this library, you will have more bricks, than you ever had as real parts.
Ulrich
Ulrich
Very good idea. But I aim to use freecad to draw the lego pieces. Btw thanks for the link leocad.If one would write an importer to FreeCAD for this library, you will have more bricks, than you ever had as real parts.
The first step is to measure the bricks and draw them. Then the community should correct them. At the point we have enough stones I will try to modify the assembly module for fast lego contructions.
- wandererfan
http://www.forum.freecadweb.org/viewtop ... ego#p56816
http://www.thingiverse.com/thing:20778
Somebody once made a "Lego.py". I found this in my files, but I can't find the original post. It's very slow.
import FreeCAD,Part,math
class Lego:
'''return a lego brick'''
def __init__(self,obj, unitsX=4, unitsY=2,unitsZ=1,modifier=0):
obj.addProperty("App::PropertyInteger","unitsX","Lego","Size in knobs in X direction.").unitsX = unitsX
obj.addProperty("App::PropertyInteger","unitsY","Lego","Size in knobs in Y direction.").unitsY = unitsY
obj.addProperty("App::PropertyInteger","unitsZ","Lego","Size in knobs in Z direction.").unitsZ = unitsZ
obj.addProperty("App::PropertyInteger","modifier","Lego","Variant No ").modifier = modifier
obj.Proxy = self
def onChanged(self, fp, prop):
"Do something when a property has changed"
pass
def execute(self, fp):
fp.Shape=Lego.buildshape(fp.unitsX, fp.unitsY, fp.unitsZ,fp.modifier)
@staticmethod
def buildshape(unitsX, unitsY,unitsZ,modifier):
gap=0.1
gaps=2*gap
unitSize = 8
height=9.6
knobHeight=1.8
knobRadius=4.8/2
wall=1.5
upWall=5.5 #// guessed
supportthickness=0.6 # 0.15x4 or 0.20x3
maxsupportlayerthickness=0.15
supportdistance=4 # 4x4=16mm^2, printer option
cylRadius = (unitSize*math.sqrt(2)-2*knobRadius)/2 #0000003,2568542494923801952067548968388
cylWall = round(3.25685,5)
l=unitSize*unitsX-gaps
w= unitSize*unitsY-gaps
c1=Part.makeBox(l, w, height,FreeCAD.Vector(-l/2.0,-w/2.0,0))
c2=Part.makeBox(l-gaps-2*wall, w-gaps-2*wall, height,FreeCAD.Vector(-(l-gaps-2*wall)/2.0,-(w-gaps-2*wall)/2.0,-1*upWall))
d1=c1.cut(c2)
shape1=d1 # box
knobs=Part.Shape()
# shape1=Part.Shape()#makeBox(1,1,1)
knob=Part.makeCylinder(knobRadius,knobHeight+upWall/2,FreeCAD.Vector(0,0,height-upWall/2.0))
for x in range(unitsX):
for y in range(unitsY):
newknob=knob.copy()
newknob.translate((x*unitSize, y*unitSize, 0))
if knobs.isNull():
knobs=newknob
else:
knobs=knobs.fuse(newknob)
knobs.translate(((1-unitsX)*unitSize/2, (1-unitsY)*unitSize/2, 0))
if (unitsX > 1 and unitsY > 1)or(modifier==-1):
cyl=Part.makeCylinder(cylRadius,height-upWall/2 ).cut(Part.makeCylinder(cylRadius-cylWall,height))
cyl.translate((0,0,upWall/8))
cyls=Part.Shape()
for x in range(unitsX-1):
for y in range(unitsY-1):
newcyl=cyl.copy()
newcyl.translate((x*unitSize, y*unitSize, 0))
if cyls.isNull():
cyls=newcyl
else:
cyls=cyls.fuse(newcyl)
cyls.translate(((2-unitsX)*unitSize/2, (2-unitsY)*unitSize/2, 0))
if modifier==2: #
newknobs=knobs.copy() #
newknobs.translate((0,0,height*unitsZ-height)) #
shape1=shape1.fuse(newknobs) #
# return shape1 #
for x in my_range(1,unitsX,2):
zmodifier=0
if modifier<=0:
zmodifier=0
else:
zmodifier=1
carrycy =Part.makeCylinder(unitSize/2,height*unitsZ-height ) # height+ # *(1-zmodifier)
carrycy.translate((unitSize*unitsX/2-x*unitSize,-unitSize/2-wall,height))
wallnearwallbase=Part.makeBox(l, w, height,FreeCAD.Vector(-l/2.0,-w/2.0+unitSize*unitsY,0)) #-wall*(1-zmodifier)
wallnearwall=Part.makeBox(l-gaps-2*wall, w-gaps-2*wall, height,FreeCAD.Vector(-(l-gaps-2*wall)/2.0,-(w-gaps-2*wall)/2.0+unitSize*unitsY,-1*upWall))
shape1=shape1.fuse(carrycy) # carry cylynder
wallnearwallbase=wallnearwallbase.cut(wallnearwall)#knobs=knobs.cut(wallnearwall)
wallnearwallbase.translate((0,-unitSize*unitsY,height*unitsZ-height))
if zmodifier==0:
shape1=shape1.cut(wallnearwallbase)#knobs=knobs.cut(wallnearwall)
else:
shape1=shape1.fuse(wallnearwallbase)#knobs=knobs.cut(wallnearwall)
# else:
c1_=Part.makeBox(l, wall, height*unitsZ,FreeCAD.Vector(-l/2.0,-w/2.0-wall*2,0))
c2_=Part.makeBox(l, wall, height,FreeCAD.Vector(-l/2.0,-w/2.0-wall,0))
shape1=shape1.fuse(c2_) # side panel base
shape1=shape1.fuse(c1_) # side panel
#.fuse(c1_)
shape1=shape1.fuse(knobs)#
shape1=shape1.fuse(cyls)#.removeSplitter() #
# shape=shape.fuse(shape1)
# shape=knobs.fuse(d1).removeSplitter()
else:
shape1=knobs.fuse(d1).removeSplitter()
#Part.show(d1.common(cyls))
for x in my_range(1,unitsX*unitSize,supportdistance): #
origvector=FreeCAD.Vector(-l/2.0+x,-w/2.0-1,-2*supportthickness)
support=Part.makeBox(supportthickness,w+2,height-upWall-maxsupportlayerthickness+2*supportthickness,origvector)
support1=Part.makeBox(supportthickness/2,w+2,height-upWall+2*supportthickness,origvector)
xoffset=0
yoffset=0
for ttranslation in range(1,9): # [1,2,3,4,5,6,7,8]
if ttranslation==1:
xoffset=0
yoffset=1
elif ttranslation==2:
xoffset=1
yoffset=0
elif ttranslation==3:
xoffset=1
yoffset=1
elif ttranslation==4:
xoffset=-1
yoffset=1
elif ttranslation==5:
xoffset=-1
yoffset=-1
elif ttranslation==6:
xoffset=-1
yoffset=0
elif ttranslation==7:
xoffset=0
yoffset=-1
elif ttranslation==8:
xoffset=1
yoffset=-1
# elif ttranslation==2:
# xoffset=1
# xoffset=1
zOffset = 0.0001
support.translate((+xoffset,+yoffset,zOffset)) ########################## here
support1.translate((+xoffset,+yoffset,zOffset)) #
support=support.cut(shape1)
support1=support1.cut(shape1)
support.translate((-xoffset,-yoffset,zOffset)) #
support1.translate((-xoffset,-yoffset,zOffset)) #
shape1=shape1.fuse(support)
shape1=shape1.fuse(support1)
return shape1
def my_range(start, end, step):
while start <= end:
yield start
start += step
def makeLego(x,y,z,modifier,doc=None):
doc = doc or FreeCAD.ActiveDocument
obj=doc.addObject("Part::FeaturePython","Lego")
Lego(obj)
obj.unitsX=x
obj.unitsY=y
obj.unitsZ=z
obj.modifier=modifier
obj.ViewObject.Proxy=0 # just set it to something different from None (this assignment is needed to run an internal notification)
return obj
if __name__ == '__main__':
#nonparametric
#Part.show(Lego.buildshape(4,2))
#parametric
# modifier -1 - mono rail
# modifier 0 - -1 wall
# modifier 1 - full mono wall, upper solid
makeLego(8,2,6,2)
# makeLego(8,2)
# makeLego(16,2)
hey people in need help, in terms of which liscence should I use for the "lego-brick" libary projekt.
Because the name lego is a trademarke, so I don't know which liscence I should use.
Is it legal to draw the lego bricks and get them online. And what about if I develop a lego WB for FreeCAD.
I am not sure and what you could do is to ask them. In general i think you shouldn't use Lego name and bricks you provide should be different.mase wrote:hey people in need help, in terms of which liscence should I use for the "lego-brick" libary projekt.
Hello.
Perhaps you should first have a look at Ldraw.org.
For english people Lugnet.com is a good place to start LEGO Exploration ...
German speaking people may consider to pay 1000Steine.de a visit.
You could also have a look at the different CAD's for Lego like
> LeoCAD
> MLCAD
> and more
how they handle these things ...
Roland
> LeoCAD
> MLCAD
> and more
Roland
My GrabCAD FreeCAD-Projects
Native german speaker - so apologies for my english, no offense intended
Yes probably adding support:
viewtopic.php?t=5637
To import already existing work could work. But as @r-frank suggested it might make sense to get in touch with that community first to get more info.
