A toggle button in the toolbar
shaise
Re: A toggle button in the toolbar
Post by shaise »
wmayer wrote:git commit cda9bf9
If GetDefaultCommand is not there the first command is toggled, otherwise you can control which other command to toggle. And if you want to have an exclusive group but no toggled command then GetDefaultCommand must be implemented to return a number out of range, e.g. -1.
Great!
Thanks for the fast response.
shai
ebrahim raeyat
Post by ebrahim raeyat »
Thanks. I have some commands for view the objects. How can I check other icons status when user clicks on any icon?
how can I set last state of each icon when restart FreeCAD? is there and easy way?
when I change the WB and select it (activate it) again, only first icon appears and others did not shown. there is no icon in there.
wmayer wrote: pinged by pinger macro
Founder
Post by wmayer »
If there should be only one button checked at a time then you can use a QButtonGroup
If you need the status of other buttons for internal calculations then put the buttons into a data structure where you can easily access them.
I guess you have a Workbench class. Re-implement the Activated() and Deactivated() functions where you restore and save the current status of the buttons, e.g. in a suitable parameter group.
ebrahim raeyat
Thanks @wmayer
No, each icon can act individually.
Thank you so much. I implemented it as below:
class OSAFEViewGroupCommand:
    def __init__(self):
        self.icon_status = {}
        for command in self.GetCommands():
            self.icon_status[command] = True
    def GetCommands(self):
        return (
            "OSAFE_wireframe_views",
            "OSAFE_view_basefoundation",
            "OSAFE_view_columns",
            "OSAFE_view_beams",
            "OSAFE_view_slabs",
            "OSAFE_view_foundations",
            "OSAFE_view_design_layer_a",
            "OSAFE_view_design_layer_b",
            "OSAFE_view_punch",
            "OSAFE_view_arch_wall",
        )  # a tuple of command names that you want to group
    def Activated(self, index):
        command = self.GetCommands()[index]
        self.icon_status[command] = not self.icon_status[command]
        wireframe = self.icon_status["OSAFE_wireframe_views"]
        show_base_foundation = self.icon_status["OSAFE_view_basefoundation"]
        show_column = self.icon_status["OSAFE_view_columns"]
        show_beam = self.icon_status["OSAFE_view_beams"]
        show_slab = self.icon_status["OSAFE_view_slabs"]
        show_foundation = self.icon_status["OSAFE_view_foundations"]
        show_design_layer_a = self.icon_status["OSAFE_view_design_layer_a"]
        show_design_layer_b = self.icon_status["OSAFE_view_design_layer_b"]
        show_punch = self.icon_status["OSAFE_view_punch"]
        show_arch_wall = self.icon_status["OSAFE_view_arch_wall"]
I will examine this if I understand you!
