Porting to python3
looo
Re: Porting to python3
Postby looo » Tue Dec 27, 2016 1:21 pm
qt5 didn't introduce any conflicts by now. Geom2d and extensions made some problems. And there is this stupid generator problem, which already was there in the py3-20 branch.
looo
Postby looo » Wed Dec 28, 2016 10:18 am
The problem with the generators is, that the ...PyImp.cpp is empty when generated with python3. This is only for files that do not exist in the src dir. eg PropertySheetPyImp.cpp in Mod/Spreadsheet/App. There must be anything wrong in the place where these files got generated.
looo
Postby looo » Wed Dec 28, 2016 11:27 am
looo
Postby looo » Wed Dec 28, 2016 1:17 pm
regarding the exec error on travis:
this seems to be a conflict only with a specific python version (2.7.6) My system uses 2.7.12 and there is no error with the exec() function.
Postby wmayer » Wed Dec 28, 2016 2:27 pm
The original line of generatetools.py is:
exec stat in self.globals,self.locals
which for the Python3 port turned into:
exec(stat, self.globals, self.locals)
IMO this is not what the original code is supposed to do. I think it should be set to
exec (stat) in self.globals,self.locals
looo
Postby looo » Wed Dec 28, 2016 2:48 pm
regarding this document it's fine like we have it right now:
http://www.diveintopython3.net/porting- ... .html#exec
but I will try if it solves the travis issue.
looo
Postby looo » Wed Dec 28, 2016 4:20 pm
python3 is building again! there was also a list of little python errors written at the end of the build-process. Maybe someone has the time to fix this. I think most of them can be fixed directly in the master.
compiling .pyc files...
  File "Mod/Fem/importZ88Mesh.py", line 389
    print elem_length
SyntaxError: Missing parentheses in call to 'print'
  File "Mod/Path/PathScripts/PathSanity.py", line 53
    print "Checking: " + item.Label
  File "Mod/Path/PathScripts/PathDressup.py", line 93
    print i.Group
  File "Mod/Path/PathScripts/PathPostProcessor.py", line 38
    exec "import %s as current_post" % postname
SyntaxError: Missing parentheses in call to 'exec'
  File "Mod/Path/PathScripts/dynapath_post.py", line 117
    print "the object " + obj.Name + " is not a path. Please select only path and Compounds."
  File "Mod/Path/PathScripts/PathUtils.py", line 622
    print form.cboProject.currentText()
SyntaxError: invalid syntax
  File "Mod/Path/PathScripts/generic_post.py", line 288
  File "Mod/Arch/ArchStructure.py", line 854
    print "got ",objName
  File "Mod/Spreadsheet/importXLSX.py", line 370
    print 'process Strings: '
  File "Mod/Path/PathScripts/dumper_post.py", line 55
  File "Mod/Path/PathScripts/linuxcnc_post.py", line 118
  File "Mod/Material/MaterialEditor.py", line 251
    print "DrawingPatterns not found"
  File "Mod/Part/BOPTools/GeneralFuseResult.py", line 113
    extractor = lambda(sh):(
  File "Mod/Path/PathScripts/PathToolLibraryManager.py", line 264
    print "Written ", filename[0]
  File "Mod/Arch/importIFC.py", line 618
    print "failed to compute placement ",
  File "Mod/Path/PathScripts/PathDressupDragknife.py", line 454
    print i.Group
  File "Mod/Arch/import3DS.py", line 109
    print "Skipping object without vertices array: ",d_nobj.obj
  File "Mod/Fem/FemMesh2Mesh.py", line 134
    print 'found a last Face: ', faceCodeList[actFaceIdx]
  File "Mod/Arch/ArchCommands.py", line 444
    print "getShapeFromMesh: error building face from polygon"
  File "Mod/Arch/ArchSite.py", line 409
    print "Error computing areas for ",obj.Label
  File "Mod/Path/PathScripts/example_post.py", line 45
    print "This script is unable to write more than one Path object"
  File "Mod/Path/PathScripts/PathDrilling.py", line 307
    print baselist
  File "Mod/Arch/ArchSchedule.py", line 351
    print "successfully exported ",filename[0]
  File "Mod/Path/PathScripts/PathCompoundExtended.py", line 60
    print 'check order'
  File "Mod/Arch/Dice3DS/dom3ds.py", line 297
    except (File3dsFormatError, FBufError), fe:
  File "Mod/Arch/importSH3D.py", line 123
    if DEBUG: print "Creating wall: ",name
  File "Mod/Arch/ArchSectionPlane.py", line 100
    print section.Label,": Skipping invalid object:",o.Label
  File "Mod/Path/PathScripts/PathSurface.py", line 148
    print "    loop ", nloop, " with ", len(loop), " points"
  File "Mod/Fem/FemToolsZ88.py", line 104
    print z88_std_location
  File "Mod/Path/PathScripts/opensbp_post.py", line 84
    print s
  File "Mod/Path/PathScripts/centroid_post.py", line 88
    print "No machine found in this selection"
  File "Mod/Path/PathScripts/PathMillFace.py", line 214
    print "in execute"
  File "Mod/Path/PathScripts/PathPost.py", line 193
    print "in activated %s" %(selected)
  File "Mod/Part/BOPTools/ShapeMerge.py", line 53
    1: (lambda(sh): sh.Vertexes),
  File "Mod/Path/PathScripts/PathDressupDogbone.py", line 947
    print i.Group
  File "Mod/Path/PathScripts/PathPocket.py", line 157
    print "this base is: " + str(baselist)
  File "Mod/Path/PathScripts/PathKurveUtils.py", line 144
    print "in profile: 151"
  File "Mod/Arch/ArchComponent.py", line 575
    print "Debug: Error computing areas for ",obj.Label,": normalAt() Face ",i
  File "Mod/Path/PathScripts/opensbp_pre.py", line 84
    print "preprocessing..."
looo
Postby looo » Wed Dec 28, 2016 4:51 pm
I should have listen to yorik. Once the rebase is done there are merge conflicts all over again... thats a bit frustrating.
looo
Postby looo » Thu Dec 29, 2016 12:17 pm
wmayer wrote:IMO this is not what the original code is supposed to do. I think it should be set to
This doesn't work with python3. I reset to the old method. To solve the travis-problem we should try to use a newer version of python2 on travis.
To make it possible to build the python3 branch on travis we need all the dependencies first available. Most of them should be available, but I think we have to make a ubuntu-package for python3-pivy. It should be also possible to make the package with pip. This is maybe the easier way. Maybe we can discuss this here.
The python3 branch needs tester. I will upload packages from this branch for python2 and python3 to anaconda in the next days. So testing is as easy as installing a conda package... (at least on linux64).
Once the python2 part of the branch works, I would vote for merging the branch. We can resolve all the little python3 errors (print) in the master branch.
(Only my opinion. Feel free to discuss this here)
Postby wmayer » Thu Dec 29, 2016 1:11 pm
Not? I tried it with a Python3.4 and it didn't complain.
Too many things have changed in the meantime so that a merge might be too troublesome. I would vote for an integration step-by-step. Therefore I would start with simple stuff like tabs to space conversions, parenthesis for print statements and so on, i.e. things that work with Python 2 and 3.
