Porting to python3
Re: Porting to python3
Post by yorik »
I can't reproduce that error either... Do you have the BIM WB installed twice?
Chris_G
Post by Chris_G »
I think this is related to Python 3, ActiveView doesn't display the list of available properties and methods in the python console
when typing the dot :
FreeCADGui.ActiveDocument.ActiveView
>>> FreeCADGui.ActiveDocument.ActiveView.__dir__()
AttributeError: __dir__
OS: Ubuntu 18.04.1 LTS
Version: 0.18.15548 (Git) AppImage
Hash: df3853738ebe5f91e3768c47c5db5594809ffeb7
Python version: 3.6.7
Qt version: 5.6.2
Locale: French/France (fr_FR)
bitacovir
Post by bitacovir »
bitacovir wrote: Mon Jan 21, 2019 7:02 pm
yorik wrote: Mon Jan 21, 2019 12:36 pm Fasteners works OK for me with python3... Can you try reinstalling it?
Yes. I reinstalled it and now the message with error of Fasteners has gone.
But now I have this message:
During initialization the error "'BIMWorkbench' already exists." occurred in C:\Users\Rafael\AppData\Roaming\FreeCAD\Mod\BIM.bak\InitGui.py
Please look into the log file for further informatio
n
Fixed.
I manually deleted all BIM Folders in AppData folder and reinstalled them via Addon Manager. No more messages about BIMWorkbench.
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Post by yorik »
Chris_G wrote: Wed Jan 23, 2019 4:40 pm I think this is related to Python 3, ActiveView doesn't display the list of available properties and methods in the python console
Yes I saw that too but couldn't nail down exactly what's happening. But it is only the rendering of the contents to the console, for ex.
FreeCAD.ActiveDocument.ActiveView.getSceneGraph()
still works
reox
Post by reox »
Just a general question: I build freecad from master with qt5 and py3 but it is unusable. Basically no geometry is shown and it can not made visible:
<class 'AttributeError'>: 'Gui.ViewProviderDocumentObject' object has no attribute 'Visibility'
Are such errors and behaviour to be expected when building with py3 or should it work but my build configuration is wrong?
looo
Post by looo »
Once we have finally moved to python3 we have to work on auto-completion anyway:
https://forum.freecadweb.org/viewtopic. ... 10#p206336
I have no idea why it is not working.
looo
Post by looo »
Maybe a hint from pycxx [1]:
Do not forget to add the call range::init_type() to some module's init function. You will want a method in some module that can create range objects, too.
searching for "View3DInventorViewerPy::init_type()" seems to give only one occurrence. So this is never called.
[1] http://cxx.sourceforge.net/PyCXX-Python ... nsion_type
looo
Post by looo »
btw: There are also crashes because of the way how freecad tries to autocomplete:
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f0c40663f20]
#1  0x7f0c42b36168 in Gui::CallTipsList::extractTipsFromObject(Py::Object&, Py::List&, QMap<QString, Gui::CallTip>&) const from /home/lo/conda/envs/freecad_gcc7/bin/../lib/libFreeCADGui.so+0x2d8
#2  0x7f0c42b38da6 in Gui::CallTipsList::extractTips(QString const&) const from /home/lo/conda/envs/freecad_gcc7/bin/../lib/libFreeCADGui.so+0xb26
#3  0x7f0c42b3961b in Gui::CallTipsList::showTips(QString const&) from /home/lo/conda/envs/freecad_gcc7/bin/../lib/libFreeCADGui.so+0x20b
#4  0x7f0c42b48084 in Gui::PythonConsole::keyPressEvent(QKeyEvent*) from /home/lo/conda/envs/freecad_gcc7/bin/../lib/libFreeCADGui.so+0x554
#5  0x7f0c4125af77 in QWidget::event(QEvent*) from /home/lo/conda/envs/freecad_gcc7/bin/../lib/libQt5Widgets.so.5+0x7e7
#6  0x7f0c413334ae in QFrame::event(QEvent*) from /home/lo/conda/envs/freecad_gcc7/bin/../lib/libQt5Widgets.so.5+0x1e
I guess this feature has to be aligned with the standard python way to do this. Maybe the easiest way is to rewrite the FreeCAD-console in python. There are some examples available: eg.: ipython-qt-console
btw.: auto-completing also doesn't work for activeView in jupyter-qt-console.
Post by wmayer »
looo wrote: Tue Feb 05, 2019 6:36 pm Maybe a hint from pycxx [1]:
https://github.com/FreeCAD/FreeCAD/blob ... n.cpp#L425
looo
Post by looo »
wmayer wrote: Tue Feb 12, 2019 2:36 pm
I see, thanks. Any ideas how to debug this behavior? (missing auto-completion)
