Is there a quick intro on how to "build" FC from source for python3 ?
Porting to python3
Re: Porting to python3
Are these environment variables to be set? Or does it need to compile FreeCAD?
python is a build and run dependency. Therefor you have to build freecad with a specific python version.chrisb wrote:Are these environment variables to be set? Or does it need to compile FreeCAD?
If you are not able to build FreeCAD there are some options to get builds:
windows:
- builds provided by sgrogan. Available on the github release page: https://github.com/FreeCAD/FreeCAD/releases
- install with conda
linux:
osx:
- conda: (waiting for this PR to be merged: https://github.com/conda-forge/staged-recipes/pull/5897)
Installation with conda is in principial the same for all 3 plattforms (64 bit only):
- Install miniconda (64bit /py36): https://conda.io/miniconda.html
conda config --add channels conda-forge
conda config --add channels freecad
conda create -n freecad freecad
And what is the glibc version on conda? Could creating AppImage and uploading it to releases page be automated? On a bit unrelated note. Could Windows builds be automated (less work for @sgrogan)?
conda packages depent on the system glibc on linux. So not all distros will work, but most. I test on ubuntu 14.04 - 18.04 and centos 6.triplus wrote:And what is the glibc version on conda?
Is possible, but as long as delta updates are not working this doesn't make much sense (too big filesize).triplus wrote:Could creating AppImage and uploading it to releases page be automated?
Installing a conda-env directly and using
conda update freecad
# conda update --all # update all packages
I am not sure a fully automated workflow is possible and makes sense. But my plan is to build weekly by increasing the build-number and pushing a PR. The rest is done by the ci's (circle for osx and linux, appveyor for windows)triplus wrote:On a bit unrelated note. Could Windows builds be automated (less work for @sgrogan)?
Hello looo,looo wrote:
I installed Freecad 0.18 PY3 QT5 via conda.
It works !
But, I don't know which is revision number:
Version: 0.18.Unknown
Python version: 3.6.5
Qt version: 5.6.2
OCC version: 7.2.0
Locale: French/France (fr_FR)
yes I know this problem. Maybe @sgrogan knows whats wrong here. Maybe it's to due some patching? Is git necessary in build and run environment?Opus wrote:But, I don't know which is revision number:
To be honest it's working out without the mentioned feature being available. Sure. It would be great to have that in the future. But highly likely we aren't talking about a deal breaker.
I see. Adding the Conda instructions here would therefore make some sense?Installing a conda-env directly and using
https://www.freecadweb.org/wiki/Download
P.S. We could i guess be more aggressive and flip the Py3 flags on for Trusty builds. And let that propagate to AppImage. If we decide and do that Py3 related reports will for sure start to come after.
