ebrahim raeyat wrote: ↑Sun Nov 04, 2018 12:17 am
2- dxf library: when i want to export to dxf it gives me this error:
What versions of FreeCAD are you using? I guess this problem shouldn't be there in recent versions as we test for syntax errors for every pull-request. If you using conda directly please try upding with:
ok, the problem is related to an add-on and not freecad itself. Please update the dxf-library. Most-likely you are using an old version of this library.
To do so:
- start FreeCAD
- tools->addon-manager
- select dxf-library and click on install/update
- close and restart FreeCAD
(fc_test) [ebi@manjaro bin]$ ./conda update freecad -c conda-forge -c freecad/lable/dev
Solving environment: failed
CondaHTTPError: HTTP 404 NOT FOUND for url <https://conda.anaconda.org/freecad/lable/dev/noarch/repodata.json>
Elapsed: 00:00.282347
CF-RAY: 47491d0b7e28274a-FRA
The remote server could not find the noarch directory for the
requested channel with url: https://conda.anaconda.org/freecad/lable/dev
As of conda 4.3, a valid channel must contain a `noarch/repodata.json` and
associated `noarch/repodata.json.bz2` file, even if `noarch/repodata.json` is
empty. please request that the channel administrator create
`noarch/repodata.json` and associated `noarch/repodata.json.bz2` files.
$ mkdir noarch
$ echo '{}' > noarch/repodata.json
$ bzip2 -k noarch/repodata.json
You will need to adjust your conda configuration to proceed.
Use `conda config --show channels` to view your configuration's current state.
Further configuration help can be found at <https://conda.io/docs/config.html>.
from this i also run this command but give same error:
looo wrote: ↑Sun Nov 04, 2018 11:26 am
To do so:
- start FreeCAD
File "/home/ebi/miniconda3/envs/fc_test/Mod/Arch/ArchAxis.py", line 399, in updateData
self.onChanged(obj.ViewObject,"ShowLabel")
File "/home/ebi/miniconda3/envs/fc_test/Mod/Arch/ArchAxis.py", line 545, in onChanged
if isinstance(t,unicode):
<class 'NameError'>: name 'unicode' is not defined
another question. what is customNumbering at all? how it works. I can't underestand.
thanks for reporting. I guess there is not much we can do about this. Most likely this problems are related to changes microsoft made to their system...
