Jee-Bee wrote: ↑Mon Jul 02, 2018 6:39 pm
Add just another build to travis.
On Travis we have this and the PY3 build passes all non-gui self-tests
https://travis-ci.org/FreeCAD/FreeCAD/b ... tification it is Build Job 5598.3 which equals 0.18.14001
The Travis build uses default Trusty 14.04 libs ie PY3.4
In addition I have a locally compiled PY3.4 build on my native Trusty system that works nearly perfect. PY3.4 is not the problem.
The problems are all with how I am packaging the freecad-testing PPA package.
1) It should be import area not import libarea. This doesn't work because I'm not building the Path WB for the freecad-testing package
. Should be and easy fix.
2) The sketch edit problem is due to me not installing the EXT directory in the freecad-testing package. Should also be an easy fix.
3) The desktop file problem needs to be fixed in freecad-testing . I think it should just require the same fixes applied to freecad-daily.
@triplus, if you agree, I think we should hammer a little more on 14.04, so we get as many older distros as possible. I'm pretty sure PY3.4 isn't the problem.
