Porting to python3
looo
Re: Porting to python3
Post by looo »
regarding the pyside problem: as it seems you have imstalled both pyside libs side by side, the abstraction layer in Ext/PySide is maybe hidden and the qt4 pyside is imported.
triplus
Post by triplus »
Hi @looo.
The reason on why i was getting crashes was related to this:
https://forum.freecadweb.org/viewtopic. ... 25#p208325
I have seen you already did some work in this area in the past. I reused your work to further improve things:
https://github.com/FreeCAD/FreeCAD/pull/1209
When using PYTHON_SUFFIX and PYTHON_BASENAME i can build both Py2/Qt5 and Py3/Qt5 without the need to result to symlinks. Both builds work after without crashes.
triplus
Post by triplus »
phpBB [video]
Chris_G
Post by Chris_G »
I gave a try at building FC with Python3 on Kubuntu 18.04 beta.
My build process has been quite a mess because I also tried to build coin / pyside2 etc ...
I finally gave up Qt5, and just built with Py3.
It seems I now have a working build.
However, I am getting an error with Vector2D.
The following script :
import Part
box = Part.makeBox(1,2,3)
face1 = box.Faces[0]
line1 = face1.curveOnSurface(face1.Edges[0])[0]
line2 = face1.curveOnSurface(face1.Edges[1])[0]
line1.intersectCC(line2)
Sends me this error :
AttributeError: module '__FreeCADBase__' has no attribute 'Vector2d'
Is my FC build messed up ? Or do you get the same error ?
Thanks.
OS: Ubuntu Bionic Beaver (development branch)
Version: 0.17.13391 (Git)
Build type: Unknown
Hash: c78a02e7824135e7bce5be4ff81a8b8fefb016bf
Python version: 3.6.4+
OCC version: 7.2.0
Locale: French/France (fr_FR)
sgrogan
Post by sgrogan »
Chris_G wrote: Wed Mar 14, 2018 11:44 am Is my FC build messed up ? Or do you get the same error ?
Same here.
Python 3.6.4 | packaged by conda-forge | (default, Dec 24 2017, 10:11:43) [MSC v.1900 64 bit (AMD64)] on win32
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> import Part
OS: Windows 7
Qt version: 5.6.2
OCC version: 7.2.0
"fight the good fight"
Founder
Post by wmayer »
This works for me.
Python 3.4.3 (default, Nov 28 2017, 16:44:58)
[GCC 4.8.4] on linux
>>> from FreeCAD import Base
>>> Base.Vector2d()
Vector2 (0.0, 0.0)
However, my Py3 build is a bit outdated:
OS: Ubuntu 14.04.5 LTS
Version: 0.17.12754 (Git)
Build type: Unknown
Hash: 1cfae464b4af12c5483c2495fae360bbf3b4c0cd
Python version: 3.4.3
Qt version: 4.8.6
OCC version: 6.7.0
looo
Post by looo »
Base.Vector2d()
works for py2 and py3
import __FreeCADBase__
__FreeCADBase__.Vector2d()
works only in py2. Maybe the second approach shouldn't be used?
https://github.com/FreeCAD/FreeCAD/blob ... p#L263L265
Chris_G
Post by Chris_G »
Thanks for testing.
wmayer wrote: Wed Mar 14, 2018 12:51 pm This works for me.
looo wrote: Wed Mar 14, 2018 1:07 pm
Base.Vector2d()
Indeed, this works for me too.
But I would be curious to know if the piece of script of my first post works for you.
Founder
Post by wmayer »
It fails with:
RuntimeError: Geom2dAPI_ExtremaCurveCurve:LowerDistance
Chris_G
Post by Chris_G »
wmayer wrote: Wed Mar 14, 2018 3:40 pm It fails with:
Thanks.
On my Python2 build, the script works :
import Part
# on my py2 build -> [Vector2 (3.0, 0.0)]
