Porting to python3
looo
Re: Porting to python3
Postby looo » Mon Jun 04, 2018 3:19 pm
I found a new problem:
>>> from FreeCAD import Units
>>> Units.Quantity()
TypeError: function takes exactly 2 arguments (0 given)
The above exception was the direct cause of the following exception:
SystemError: <class 'Base.Quantity'> returned a result with an error set
I don't see something obvious: https://github.com/FreeCAD/FreeCAD/blob ... mp.cpp#L58
Site Admin
Postby wmayer » Mon Jun 04, 2018 3:48 pm
But I do. There is a missing call of PyErr_Clear.
git commit 9ec4d8368
looo
Postby looo » Mon Jun 04, 2018 5:29 pm
looo
Postby looo » Mon Jun 04, 2018 7:08 pm
thanks for merging. Here is another problem which I found by trying to open this file:
https://github.com/uncreatednet/wikilab ... wren.FCStd
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7f44de16d4b0]
#1  /lib/libpython3.6m.so.1.0(PyObject_GetAttrString+0x9) [0x7f44df94dbb9]
#2  0x7f44e0302e3f in App::PropertyPythonObject::Restore(Base::XMLReader&) from /work/lib/libFreeCADApp.so+0x60f
#3  0x7f44e02d9e7d in App::DynamicProperty::Restore(Base::XMLReader&) from /work/lib/libFreeCADApp.so+0x1ad
#4  0x7f44e0247087 in App::Document::readObjects(Base::XMLReader&) from /work/lib/libFreeCADApp.so+0x2d7
#5  0x7f44e024d633 in App::Document::Restore(Base::XMLReader&) from /work/lib/libFreeCADApp.so+0x1c3
#6  0x7f44e024ee5d in App::Document::restore() from /work/lib/libFreeCADApp.so+0x1dd
#7  0x7f44e032e023 in App::Application::openDocument(char const*) from /work/lib/libFreeCADApp.so+0x243
#8  0x7f44e0343a2c in App::Application::sOpenDocument(_object*, _object*, _object*) from /work/lib/libFreeCADApp.so+0x5c
If I copy the objects in the file to another document and open this file with py3 everything loads fine.
sgrogan
Postby sgrogan » Mon Jun 04, 2018 9:21 pm
OS: Ubuntu 14.04.5 LTS
Version: 0.18.13905 (Git)
Build type: Unknown
Hash: e80b5678ccfa59a5222b91bdc7e748a53a468468
Python version: 3.4.3
Qt version: 4.8.6
OCC version: 7.3.0.beta
  File "/usr/lib/python3.4/unittest/case.py", line 58, in testPartExecutor
    yield
  File "/usr/lib/python3.4/unittest/case.py", line 577, in run
    testMethod()
  File "/home/sgrogan/freecad-py3-build/Mod/Test/TestPythonSyntax.py", line 44, in testAll
    test_python_syntax(mod_dir, self.whitelist)
  File "/home/sgrogan/freecad-py3-build/Mod/Test/TestPythonSyntax.py", line 27, in test_python_syntax
    raise RuntimeError("there are some files not parse-able with the used python-interpreter" + message)
RuntimeError: there are some files not parse-able with the used python-interpreter
2 python files are not parseable:
1 invalid syntax (/home/sgrogan/freecad-py3-build/Mod/Path/PathScripts/PathKurveUtils.py, line 164)
2 invalid syntax (/home/sgrogan/freecad-py3-build/Mod/Path/PathScripts/phillips_post.py, line 327)
looo
Postby looo » Mon Jun 04, 2018 9:37 pm
sgrogan wrote: 1 invalid syntax (/home/sgrogan/freecad-py3-build/Mod/Path/PathScripts/PathKurveUtils.py, line 164)
I think these files are not part of the current master.
sgrogan
Postby sgrogan » Mon Jun 04, 2018 9:50 pm
Thanks looo, I did make clean, scratch build compiling now.
EDIT: scratch build all self-tests pass from the gui. Thanks all for the effort.
Site Admin
Postby wmayer » Sat Jun 09, 2018 1:57 pm
git commit cb1337674
Postby Kunda1 » Mon Jun 11, 2018 12:32 am
Quick question: So this thread is pretty long, and therefore a little daunting to traverse to see if this question was already asked. Hence I apologize in advance if this was asked already: I'd like to know how volunteers could contribute to helping port FC to py3? (From finding bugs to actually developing)
Thanks
looo
Postby looo » Mon Jun 11, 2018 2:42 am
Quick question: So this thread is pretty long, and therefore a little daunting to traverse to see if this question was already n,asked. Hence I apologize in advance if this was asked already: I'd like to know how volunteers could contribute to helping port FC to py3? (From finding bugs to actually developing)
Thanks
simple install freecad with python 3 and use it. most things will work but there are still some issues. If you find a problem, first try to solve it by your own and make a Pr, if this is not possible post the problem here in this topic so others can try to solve it.
if that also doesn't work, create a bugreport.
I guess currently the most problematic workbench is Path. Maybe trying to do a path-tutorial with a py3 build would be a good start.
