Porting to python3
sgrogan
Re: Porting to python3
Postby sgrogan » Thu Jun 14, 2018 12:33 am
triplus wrote:
Tue Jun 12, 2018 9:37 pm
OK then i will try to create an AppImage from it (likely tomorrow) and see how that goes
Great! If you have problems please just post on the forum. It's a weird build. I'm using looo's pivy package that I have copied to my PPA, but I have enabled trusty backports to get swig3, and I have the official FreeCAD-daily as a dependency to get occt. I get many self-test errors when installing the FreeCAD-testing package on my machine, compared to a natively compiled version, that should be using the same dependencies.
triplus
Postby triplus » Fri Jun 15, 2018 12:28 am
Hi @sgrogan
I won't have time to further look into this before Sunday. As for the progress. I was able to produce AppImage and run it. It complains on things like not using print() ... The two issues i noticed that need fixing are desktop-file-validate freecad-testing.desktop doesn't pass ATM and under Exec line in desktop file it should only say freecad-testing. The second one is Sketcher workbench edit mode isn't working ATM (didn't run tests yet). The first issue should be easy to resolve. As for the second one i am guessing that the procedure used in PPA recipe to build FreeCAD would likely need some tweaking.
triplus
Postby triplus » Mon Jun 18, 2018 11:16 am
Did some more testing today. Both AppImage and the package from PPA suffer some issues (like the mentioned Sketcher edit mode issue). I read this thread for clues and i guess:
https://forum.freecadweb.org/viewtopic. ... 99#p207813
The easiest thing to try out next would be to create an Ubuntu 16.04 PPA build with the same recipe. And to see if the issue persist. If Python 3.4 ends up being too old i guess we can base the AppImage on Ubuntu 16.04. In addition in the following days i can try out building FreeCAD (Py3) on Ubuntu 14.04 and see how that goes.
sgrogan
Postby sgrogan » Mon Jun 18, 2018 8:46 pm
Thanks for testing. I should have some time in a few hours to test my local 14.04 PY3 build. In the past I have had more problems when installing the PY3 PPA than I had with my local build.
triplus
Postby triplus » Tue Jun 19, 2018 8:47 am
Take your time. For the next 2 days likely i will have minimum amount of free time.
sgrogan
Postby sgrogan » Mon Jun 25, 2018 11:08 pm
I will also need some more time. If you need something post here and I will try.
I will try to post a link to a 16.04 package in the next week.
triplus
Postby triplus » Wed Jun 27, 2018 11:05 am
I had some free time over the weekend and first tried to create a FreeCAD Py3 build on Ubuntu 14.04. Satisfying dependencies took the most time and CMake still returns some errors but all in all it builds. I have just tested the produced build and i can enter the sketcher edit mode successfully. Therefore i am guessing the PPA builds should work too. And likely some tweaking of the recipe would be needed. Can you post a link to the PPA recipe you are using?
P.S. I didn't have to create any Boost related links and didn't tried to provide Pivy Py3 package for now.
sgrogan
Postby sgrogan » Thu Jun 28, 2018 9:45 pm
I'm using this debian folder https://git.launchpad.net/~freecad-main ... ?h=testing
I'm using looo's pivy package, hosted on my PPA, and swig3 from trusty-backports.
import libarea
Will reveal the problem if it exists. It relates specifically to boost-python. On my native build FreeCAD compiled fine without the links but would fail when trying to import the libarea module. Not sure if you have to switch to the Path WB.
I hope to have some time soon, sorry for the intermittent effort, but time is short for me at the moment.
I will try to build a 16.04 FreeCAD-testing on my PPA tomorrow.
looo
Postby looo » Fri Jun 29, 2018 6:06 am
sgrogan wrote:On my native build FreeCAD compiled fine without the links but would fail when trying to import the libarea module.
Can you post the error?
It would be nice if we can switch to pybind11. as pybind11 is header-only it should be possible to simple copy some existing packages for other ubuntu-releases: https://launchpad.net/~fenics-packages/ ... es_filter= Isn't there a simple way to copy some packages from another ppa to the freecad-ppa?
I guess avoiding python < 3.5 is a good idea.
sgrogan
Postby sgrogan » Fri Jun 29, 2018 9:20 pm
I don't remember if libarea.so didn't build at all or if there was a python mis-match, due to libboost-python. CMake found the PY2 version of libboost-python unless the PY3 path was set w/ CMake. Setting the path fixed the problem. The python paths are different for Trusty(14.04) vs newer versions, so this may only apply to 14.04
