Porting to python3
triplus
Re: Porting to python3
Postby triplus » Sun Aug 12, 2018 10:56 pm
"... issue after latest update of python (3.6 > 3.7) ..."
I guess the easiest solution would be to just bump this to lets say 2030:
https://pythonclock.org/
And we wouldn't have all this problems anymore. In addition we could focus on things like what to do when Coin3D will reach EOL in a couple of years. :lol:
Grawp
Postby Grawp » Tue Aug 14, 2018 9:01 pm
bartus wrote:
Sun Aug 12, 2018 8:48 pm
Have some issue after latest update of python (3.6 > 3.7) on my Arch-Linux machine.
 42     cmake -DCMAKE_BUILD_TYPE=Release \
 43           -DCMAKE_INSTALL_PREFIX="/opt/${_appname}" \
 44           -DFREECAD_USE_OCC_VARIANT="Community Edition" \
 45           -DPYTHON_EXECUTABLE="/usr/bin/python3" \
 46           -DBUILD_QT5=ON
 47     make
make error log:
[ 32%] Built target StdMeshers
/home/bartus/.cache/aursync/freecad-python3-git/src/freecad-python3/src/App/Application.cpp: In constructor ‘App::Application::Application(std::map<std::__cxx11::basic_string<char>, std::__cxx11::basic_string<char> >&)’:
/home/bartus/.cache/aursync/freecad-python3-git/src/freecad-python3/src/App/Application.cpp:233:49: error: too few arguments to function ‘int _PyImport_FixupBuiltin(PyObject*, const char*, PyObject*)’
     _PyImport_FixupBuiltin(pAppModule, "FreeCAD");
In file included from /usr/include/python3.7m/Python.h:126,
                 from /home/bartus/.cache/aursync/freecad-python3-git/src/freecad-python3/src/Base/PyObjectBase.h:38,
                 from /home/bartus/.cache/aursync/freecad-python3-git/src/freecad-python3/src/App/Application.h:32,
                 from /home/bartus/.cache/aursync/freecad-python3-git/src/freecad-python3/src/App/Application.cpp:56:
/usr/include/python3.7m/import.h:115:17: note: declared here
 PyAPI_FUNC(int) _PyImport_FixupBuiltin(
/home/bartus/.cache/aursync/freecad-python3-git/src/freecad-python3/src/App/Application.cpp:274:58: error: too few arguments to function ‘int _PyImport_FixupBuiltin(PyObject*, const char*, PyObject*)’
     _PyImport_FixupBuiltin(pBaseModule, "__FreeCADBase__");
Current python implementation call `_PyImport_FixupBuiltin` which is an interal function, correct way of handling this could be found in gdb bugtracker https://sourceware.org/bugzilla/show_bug.cgi?id=23252
I'm working on the fix right now using the way from gdb and also changing char* to const char*. After it's done I'll publish it as a temporary patch in my AUR package freecad-python3-git and I'll also do a pull request to FreeCAD git.
Cheers
triplus
Postby triplus » Wed Aug 15, 2018 3:37 pm
Good to hear that @Grawp and thanks for working on it.
sgrogan
Postby sgrogan » Wed Aug 15, 2018 8:57 pm
Actually, I prefer this option, too. The changes in my fork is substantial. Merging now will inevitably delay release of 0.18 for who knows how long. Splitting the changes cost time, and risk new bugs, and worse, incomplete features.
@realthunder
What are these implications for you? You have 50k lines of difficult to split code. In 3-4 mo is it 70k lines?
The idea was to make a "quick" FreeCAD 0.18 release that ports to QT5/PY3.
For the rest of us, we should start a NEW thread about working towards an accelerated release.
As packagers we need to support @realthunder's branch (I'm not willing to call it a fork). As testers we need to test @realthunder's branch.
I'll float again the idea of an "official" LinkStage3 branch. It would make it easier, but it won't happen overnight, to off load the test-build burden from @realthunder. Maybe @realthunder prefers more control over when there is a release?
PLEASE, PLEASE, PLEASE discuss a new release in a new topic.
fosselius
Postby fosselius » Thu Aug 16, 2018 5:59 am
Relevant post for this thread: https://hackaday.com/2018/08/15/stop-us ... -python-3/
Are you sure you wanted to post this on the python 3 porting thread? also the whole quote states that realthunder prefer to wait until 0.19 to merge LinkStage3.
realthunder wrote:
Mon Aug 13, 2018 11:52 pm
easyw-fc wrote:
Mon Aug 13, 2018 6:37 pm
I don't see any issue in publish a new stable release and then go to the wild in the next 0.19... that was a suggested option some time ago anyway...
realthunder
Postby realthunder » Thu Aug 16, 2018 6:16 am
@realthunder
My branch (and Assembly3 WB) is already working in Py3, with help from @looo. See instructions here.
fosselius
Postby fosselius » Thu Aug 16, 2018 6:36 am
I created this thread to have a common place to discuss the 0.18 release: https://forum.freecadweb.org/viewtopic.php?f=10&t=30340
sgrogan
Postby sgrogan » Thu Aug 16, 2018 10:57 am
Yes I meant to post this in the"Merging my Link branch thread"
Grawp
Postby Grawp » Sat Aug 18, 2018 2:49 pm
For anyone interested in running FreeCAD with Python 3.7:
https://github.com/Grawp/FreeCAD/tree/python3.7
It is not a proper fix yet. PyImport_AppendInittab should be called before Py_Initialize and I haven't had time to investigate where Py_Initialize is being called etc.. yet so I've just added the third parameter to _PyImport_FixupBuiltin calls.
triplus
Postby triplus » Sun Aug 19, 2018 3:48 pm
Take your time and thanks for working on it.
