Porting to python3
Site Admin
Re: Porting to python3
Postby wmayer » Sat Sep 01, 2018 3:21 pm
Grawp wrote:
Sat Aug 18, 2018 2:49 pm
For anyone interested in running FreeCAD with Python 3.7:
https://github.com/Grawp/FreeCAD/tree/python3.7
It is not a proper fix yet. PyImport_AppendInittab should be called before Py_Initialize and I haven't had time to investigate where Py_Initialize is being called etc.. yet so I've just added the third parameter to _PyImport_FixupBuiltin calls.
git commit 8c08635d3 shows how to use PyImport_AppendInittab. Unfortunately, this way has two major problems:
* it can't be used for the FreeCADGui module because Py_Initialize has been called long before
* there is also an extension module FreeCAD so that it can't be loaded from a normal Python session
So, PyImport_AppendInittab is not a real solution in our case.
Reason: Fix typo
Grawp
Postby Grawp » Sat Sep 01, 2018 4:11 pm
* there is also an extension module FreeCAD so that itcan be loaded from a normal Python session
Well, I had already known about PyImport_AppendInittab solution when I wrote that it wouldn't be completely trivial.. (at least that was my feeling).
I'll keep getting acquainted with FreeCAD code base so I could better understand the problem e.g. why FreeCAD* python modules have to be imported as builtins etc.. Meanwhile should I rebase my PR onto master?
Site Admin
Postby wmayer » Sat Sep 01, 2018 5:58 pm
I found a way to handle the case that the interpreter is already initialized. In this case PyImport_ImportModule returns a null pointer and then PyModule_Create can be used again and the module added directly to sys.modules. The PythonQt project does it this way and it seems to work nicely.
git commit b79e1bfee
Yes, this would be great.
triplus
Postby triplus » Mon Sep 03, 2018 11:22 pm
kkremitzki wrote:
Fri Aug 31, 2018 9:27 pm
kkremitzki wrote:
Mon Aug 27, 2018 11:59 pm
yorik wrote:
Mon Aug 27, 2018 3:32 pm
I suppose another one is needed for py37 too. Is it possible to make a PR somewhere, Kurt? Or can you take care of this?
I filed a bug for this: https://bugs.debian.org/cgi-bin/bugrepo ... bug=906020. The source repo for this package is at https://salsa.debian.org/qt-kde-team/qt/pyside2. It's on my list of things to try to figure out but the list is definitely not short, unfortunately.
This bug is fixed now, just gotta redo the builds for the PPA.
If i look at the fix applied by them. Without investment in gaining in-depth (Debian) packaging knowledge. It just ain't going to work. Over time i guess we can try to attract more people interested in this. But we likely should avoid undertaking such effort as properly packaging PySide2 as much as we can. And i guess becoming maintainers of the libraries FreeCAD depends on. This can quickly end up going over our heads. And instead of FreeCAD development packaging other software and maintaining some of it can quickly drain the resources available.
Jee-Bee
Postby Jee-Bee » Wed Sep 05, 2018 1:21 pm
Is it True that the python 3 Qt5 packages (pre compiled) aren't ready for FEM(windows)?
Both Calculix, gmsh arent included...
( i'm not sure about nedgen... i think it is included but i'm not sure!!)
looo
Postby looo » Wed Sep 05, 2018 2:19 pm
It's not necessary to have binary-compatible gmsh and calculix. So I guess you should be able to install anything working on windows. But I think a binary compatible gmsh will (hopefully) come soon: a first step towards this goal
netgen should be included.
easyw-fc
Postby easyw-fc » Sat Sep 08, 2018 7:44 am
I've started to use regularly the Py3Qt5 release to force myself in catching the incompatibilities...
I was trying to import/export a DXF file and I got this error:
  File "<string>", line 4, in <module>
  File "D:\FreeCAD-PY36-QT5\Mod\Draft\importDXF.py", line 1920, in export
    getDXFlibs()
  File "D:\FreeCAD-PY36-QT5\Mod\Draft\importDXF.py", line 157, in getDXFlibs
    import dxfReader
<class 'SyntaxError'>: invalid syntax (dxfReader.py, line 88)
I get the error always in exporting and only if 'legacy' importer is selected when importing.
here my FC info:
Version: 0.18.14570 (Git)
Hash: 233ed49b23ee14a9978a0aa78c67396115b1582c
Python version: 3.6.6
Qt version: 5.6.2
looo
Postby looo » Sat Sep 08, 2018 11:12 am
I think this PR should solve it: https://github.com/yorikvanhavre/Draft- ... er/pull/18 No idea why it wasn't merged yet.
yorik wrote:
easyw-fc
Postby easyw-fc » Tue Sep 11, 2018 2:02 pm
yorik wrote:
This PR is fixing it and it is back compatible as far as I tested.
EDIT:
OOps: there is a minor fix to apply, I'm going to PR...
PR done
sgrogan
Postby sgrogan » Thu Sep 13, 2018 11:35 pm
Maybe this should be in Install/Compile but it is PY3 specific.
This doesn't work for me anymore https://forum.freecadweb.org/viewtopic. ... 90#p182647
If I set PYTHON_BASENAME CMake cannot find Pyside. If I leave it empty CMake succeeds and I can make but I get a segfault on FreeCAD start.
FreeCAD 0.18, Libs: 0.18R14715 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x36cb0) [0x7f192beafcb0]
#1  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(Py_InitModule4_64+0x2b) [0x7f191f1bdeab]
#2  /usr/lib/python3/dist-packages/PySide/QtCore.cpython-34m-x86_64-linux-gnu.so(PyInit_QtCore+0x40) [0x7f1910b30320]
#3  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(_PyImport_LoadDynamicModule+0x13c) [0x7f192dae418c]
#4  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0x1f0323) [0x7f192dae4323]
#5  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x654b) [0x7f192daf9fbb]
#6  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#7  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6742) [0x7f192dafa1b2]
#8  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#9  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0x20a083) [0x7f192dafe083]
#10  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyObject_Call+0x68) [0x7f192da5f758]
#11  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x2c94) [0x7f192daf6704]
#12  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#13  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6742) [0x7f192dafa1b2]
#14  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#15  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#16  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#17  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#18  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0x209fa6) [0x7f192dafdfa6]
#19  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyObject_Call+0x68) [0x7f192da5f758]
#20  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(_PyObject_CallMethodIdObjArgs+0x181) [0x7f192da2aad1]
#21  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyImport_ImportModuleLevelObject+0x763) [0x7f192dad3a43]
#22  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0xf594f) [0x7f192d9e994f]
#23  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x654b) [0x7f192daf9fbb]
#24  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#25  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6742) [0x7f192dafa1b2]
#26  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#27  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0x209fa6) [0x7f192dafdfa6]
#28  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyObject_Call+0x68) [0x7f192da5f758]
#29  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(_PyObject_CallMethodIdObjArgs+0x181) [0x7f192da2aad1]
#30  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyImport_ImportModuleLevelObject+0x61c) [0x7f192dad38fc]
#31  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0xf594f) [0x7f192d9e994f]
#32  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyObject_Call+0x68) [0x7f192da5f758]
#33  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_CallObjectWithKeywords+0x47) [0x7f192dad59b7]
#34  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x3fa1) [0x7f192daf7a11]
#35  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#36  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#37  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#38  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCode+0x3b) [0x7f192dafe10b]
#39  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0x24d6ed) [0x7f192db416ed]
#40  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x654b) [0x7f192daf9fbb]
#41  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#42  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6742) [0x7f192dafa1b2]
#43  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#44  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#45  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#46  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#47  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#48  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0x209fa6) [0x7f192dafdfa6]
#49  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyObject_Call+0x68) [0x7f192da5f758]
#50  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(_PyObject_CallMethodIdObjArgs+0x181) [0x7f192da2aad1]
#51  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyImport_ImportModuleLevelObject+0x763) [0x7f192dad3a43]
#52  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0xf594f) [0x7f192d9e994f]
#53  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyObject_Call+0x68) [0x7f192da5f758]
#54  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_CallObjectWithKeywords+0x47) [0x7f192dad59b7]
#55  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x3fa1) [0x7f192daf7a11]
#56  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#57  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCode+0x3b) [0x7f192dafe10b]
#58  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0x24d6ed) [0x7f192db416ed]
#59  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x654b) [0x7f192daf9fbb]
#60  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#61  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6742) [0x7f192dafa1b2]
#62  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#63  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#64  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#65  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#66  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#67  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0x209fa6) [0x7f192dafdfa6]
#68  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyObject_Call+0x68) [0x7f192da5f758]
#69  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(_PyObject_CallMethodIdObjArgs+0x181) [0x7f192da2aad1]
#70  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyImport_ImportModuleLevelObject+0x763) [0x7f192dad3a43]
#71  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0xf594f) [0x7f192d9e994f]
#72  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyObject_Call+0x68) [0x7f192da5f758]
#73  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_CallObjectWithKeywords+0x47) [0x7f192dad59b7]
#74  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x3fa1) [0x7f192daf7a11]
#75  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#76  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCode+0x3b) [0x7f192dafe10b]
#77  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0x24d6ed) [0x7f192db416ed]
#78  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x654b) [0x7f192daf9fbb]
#79  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#80  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6742) [0x7f192dafa1b2]
#81  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#82  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#83  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#84  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#85  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#86  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0x209fa6) [0x7f192dafdfa6]
#87  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyObject_Call+0x68) [0x7f192da5f758]
#88  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(_PyObject_CallMethodIdObjArgs+0x181) [0x7f192da2aad1]
#89  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyImport_ImportModuleLevelObject+0x763) [0x7f192dad3a43]
#90  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0xf594f) [0x7f192d9e994f]
#91  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyObject_Call+0x68) [0x7f192da5f758]
#92  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_CallObjectWithKeywords+0x47) [0x7f192dad59b7]
#93  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x3fa1) [0x7f192daf7a11]
#94  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#95  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCode+0x3b) [0x7f192dafe10b]
#96  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyRun_StringFlags+0x92) [0x7f192db414a2]
#97  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(+0x24d641) [0x7f192db41641]
#98  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6d79) [0x7f192dafa7e9]
#99  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalFrameEx+0x6c5c) [0x7f192dafa6cc]
#100  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCodeEx+0x886) [0x7f192dafd976]
#101  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyEval_EvalCode+0x3b) [0x7f192dafe10b]
#102  /usr/lib/x86_64-linux-gnu/libpython3.4m.so.1.0(PyRun_StringFlags+0x92) [0x7f192db414a2]
#103  0x7f192e07fa02 in Base::InterpreterSingleton::runString(char const*) from /home/sgrogan/freecad-py3-build/lib/libFreeCADBase.so+0xd8
#104  0x7f192f3d7eb0 in Gui::Application::runInitGuiScript() from /home/sgrogan/freecad-py3-build/lib/libFreeCADGui.so+0x3a
#105  0x7f192f3d99eb in Gui::Application::runApplication() from /home/sgrogan/freecad-py3-build/lib/libFreeCADGui.so+0x1b27
#106  /home/sgrogan/freecad-py3-build/bin/FreeCAD(main+0x94d) [0x4076b0]
#107  /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f192be9af45]
#108  /home/sgrogan/freecad-py3-build/bin/FreeCAD() [0x406c29]
#1 seems the problem?
Kubuntu 14.04, w/ @looos pivy package, and swig3 from Trusty backports, default QT4.
Is PYTHON_CONFIG_SUFFIX the same as PYTHON_SUFFIX?
It's PY3.4 on Ubuntu 14.04 if it matters.
"fight the good fight"
