Porting to python3
Lvaskz
Re: Porting to python3
Postby Lvaskz » Wed Sep 19, 2018 11:14 am
Hello, I am using ubuntu 18.04, 64 bit and downloaded freecad conda to test it and I came across these issues
Menus are missing
looo
Postby looo » Wed Sep 19, 2018 12:20 pm
Menus are missing
Thanks for testing. Please have a look here for a workaround: https://github.com/FreeCAD/FreeCAD_Conda/issues/17
Should be fixed with the next qt update (qt5.12) which hopefully comes at the end of 2018.
easyw-fc
Postby easyw-fc » Fri Sep 28, 2018 9:22 am
A Draft.makeText issue for py3 migration:
App.newDocument("Unnamed")
App.setActiveDocument("Unnamed")
App.ActiveDocument=App.getDocument("Unnamed")
Gui.ActiveDocument=Gui.getDocument("Unnamed")
import Draft
text = (["b'Test'"],point=FreeCAD.Vector(0.0,0.0,0.0))
Draft.autogroup(text)
Error code:
  File "C:\FreeCAD-0.18-dev_PY3_QT5-x64\Mod\Draft\Draft.py", line 7297, in attach
    self.onChanged(vobj,"Justification")
  File "C:\FreeCAD-0.18-dev_PY3_QT5-x64\Mod\Draft\Draft.py", line 7330, in onChanged
    if hasattr(vobj,"Justification"):
<class 'AssertionError'>: The enum is empty
tested with:
Version: 0.18.14825 (Git)
Hash: a0ff629747d5d73567075821852a8cdaadcf51c5
Python version: 3.6.6
Qt version: 5.6.2
Tandini
Postby Tandini » Mon Oct 01, 2018 8:35 am
I'm using Win10 Pro 64Bit version 1803 build 17134.285
On startpage/documents/Recent Files previews are not shown.
Same behaviour on computer at work as well as on computer at home (same OS builds)
FreeCAD 018. Conda preview issue.png (140.6 KiB) Viewed 728 times
looo
Postby looo » Mon Oct 01, 2018 8:58 am
This is a known issue. I think it's a problem of the qtwebkit of conda-forge. There is not much we can do about it right now. Maybe if someone has the time, create an issue for conda-forge qt-feedstock [1], but I think this feedstock needs to be reworked for qt5.12 anyway.
[1] https://github.com/conda-forge/qt-feedstock/issues
Tandini
Postby Tandini » Mon Oct 01, 2018 6:46 pm
chrisb wrote:
Mon Oct 01, 2018 4:12 pm
The dialog looks rather like a system dialog. Do you have a german environment on your computer?
Well, I'm German ... ;)
I installed and use 0.18 non-Conda and Conda parallel. So I just crosschecked: In non-Conda the dialog displays correct - completely translated in german ...
Sorry, I simply found a different behavior between the non-Conda and the Conda flavor ...
And I followed this advice:
Note on Python 3
Please test Python 3 (Conda) builds in your FreeCAD daily routine and report issues.
:? I apologize if it still isn't the right place - - - and please feel free to direct it to the right place.
yorik
Site Admin
Postby yorik » Mon Oct 01, 2018 8:13 pm
Out of curiosity, do other images and icons (in the "Help" tab) appear correctly?
Tandini
Postby Tandini » Mon Oct 01, 2018 10:05 pm
No, they don't - but in non-Conda they appear corectly ...
sgrogan
Postby sgrogan » Mon Oct 01, 2018 10:35 pm
With the AppImage the "Help" tab from Start WB works
OS: Ubuntu 14.04.5 LTS
Version: 0.18.14859 (Git) AppImage
Hash: c3a8348861372b055c2446a09f0fc49a6cd7a2ef
Qt version: 5.6.2
Will Test on Win
EDIT: Doesn't work on win
OS: Windows 7
Qt version: 5.6.2
"fight the good fight"
yorik
Site Admin
Postby yorik » Tue Oct 02, 2018 1:25 pm
Hm indeed this is most likely a qt problem, but just in case there is a problem with icon paths, here is another thing to test: In the python console, type this:
from StartPage import StartPage
StartPage.exportTestFile()
In your user's home directory, you should find a "startpage.html" file, that you can open in your web browser. Can someone check on windows if the icons appear?
