Porting to python3
ebrahim raeyat
Re: Porting to python3
Postby ebrahim raeyat » Tue Dec 11, 2018 8:26 pm
triplus wrote:
Tue Dec 11, 2018 8:20 pm
That is try out this option again, only this time install pandas from Conda.
I examined that, but it also gives me that error. I guess it's related to lic6, isn't that? it works on old manjaro. I also wanted to update hole of my system, but it told me that's every thing is up to date :D
triplus
Postby triplus » Tue Dec 11, 2018 8:37 pm
Today i don't have more time, but for the future reference, can you describe the procedure more in detail? Procedure leading to crash. I am guessing crash happens when using some command from your module/workbench?
P.S. Ideally you would narrow it down to a code snippet.
ebrahim raeyat
Postby ebrahim raeyat » Tue Dec 11, 2018 9:02 pm
yes. in interactive python consol in FreeCAD type this:
import pandas as pd
df = pd.DataFrame()
df.to_excel('/home/ebi/df1.xlsx')
looo
Postby looo » Tue Dec 11, 2018 9:52 pm
if you have installed pandas with pip-tools it is installed in a local directory. So maybe this package hides the conda-package which is installed in another location. You can check this with:
import pandas as pd
pd.__file__
For me your code-snippet worked after installing pandas and xlwt from conda. So I still believe your problem is related to an incompatible pandas.
ebrahim raeyat
Postby ebrahim raeyat » Wed Dec 12, 2018 6:33 am
import pandas as pd
pd.__file__
in both miniconda and AppImage pandas's path is:
'/home/ebi/.local/lib/python3.6/site-packages/pandas/__init__.py'
my pythons in manjaro linux are pyhton2.7 and python3.7 and when i type $python in bash it runs python3.7.
python 3.6 is for conda and AppImage. it is my site-package in AppImage:
looo
Postby looo » Wed Dec 12, 2018 7:00 am
Exactly this is the problem. This local Install of pandas hides the system/ conda package. Simple remove the pandas in .local/lib/python3.6 and test again.
ebrahim raeyat
Postby ebrahim raeyat » Wed Dec 12, 2018 1:14 pm
when I moved site-packages in loacal and run miniconda FreeCAD, pandas's path is:
'/home/ebi/miniconda3/envs/fc_test/lib/python3.6/site-packages/pandas/__init__.py'
but same problem still exist. in AppImage it not recognize pandas at all. how can i install pandas? I extract AppImage and go to the bin folder and run:
./python
it gives me Python 3.6.7 | packaged by conda-forge.
is it true if i install package in below manner:
./python -m pip install PACKAGENAME
thanks
triplus
Postby triplus » Wed Dec 12, 2018 1:21 pm
Yes, to get you started, a solution and explanation from @looo makes sense. That is to remove the pip pandas version altogether and use (install) FreeCAD and pandas from Conda channels.
As for the bigger problem involved. I guess this shows on just how problematic FreeCAD module dependencies can be. We can not always rely on pip. Libraries available by default (AppImage, macOS and Windows binaries) is what FreeCAD module developer can more or less rely on. Everything else can represent a problem. And likely we will never pack all the dependencies FreeCAD module developers might use in the binaries. Therefore different possible solutions for specific use case problems will i guess need to be explored. As for the AppImage. On how to make it work. I can do some tests but likely not before next week. And there is another problem. If the solution won't be straightforward. Potential end users will have issues when trying to use your module. And therefore packing pandas in AppImage is one solution. But what about other platforms?
ebrahim raeyat
Postby ebrahim raeyat » Wed Dec 12, 2018 1:30 pm
in AppImage i install dependency for pandas and the path is:
'/home/ebi/Applications/squashfs-root/usr/lib/python3.6/site-packages/pandas/__init__.py'
but still error occured. I will examin the path in old manjaro and my new ubuntu.
triplus
Postby triplus » Wed Dec 12, 2018 1:42 pm
Yes exactly. AppImage and pandas installed with pip (in your use case and environment won't work). We can try to find a solution in the future.
For now therefore removing the pandas installed with pip altogether and after installing and using FreeCAD and pandas from Conda, should work.
