Porting to python3
looo
Re: Porting to python3
Postby looo » Thu Jan 03, 2019 9:45 am
peterl94 wrote:
Thu Jan 03, 2019 6:39 am
Found the problem. Not sure why it is not a problem for other platforms.
I think linux uses utf8 by default.
Checking the last-circle (osx) build I found this leftover-patch:
Applying patch: '/Users/distiller/test/recipe/win_unicode.patch'
patching file src/Mod/Test/TestPythonSyntax.py
Which basically add some additional files to the whitelist. But I guess with your fix this is solved now and the patch can be removed. Also we should try to remove the whitelist. I never understood why some files where not parse-able on windows, so I added this whitelist. But maybe now it's possible to parse them all...
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
dcapeletti
Postby dcapeletti » Thu Jan 03, 2019 10:38 pm
When I started freecad I got the following error:
'ascii' codec can't decode byte 0xc3 in position 9036: ordinal not in range(128)
I think it appears because the home page has an accent in Spanish and does not decipher the character well.
OS: Debian GNU/Linux 9.6 (stretch)
Version: 0.18.15513 (Git) AppImage
Hash: 42e6650ac0e6c6e53ebb7f2bb83a07a555ea51b0
Python version: 2.7.6
Qt version: 4.8.6
Locale: Spanish/Argentina (es_AR)
NormandC
Postby NormandC » Thu Jan 03, 2019 11:05 pm
This has already been fixed, your AppImage is almost 40 commits behind master.
Edit: also, you're not even using Python 3, which this topic is about.
Syres
Postby Syres » Sat Jan 05, 2019 1:09 pm
Clicking on a macro for example FCStairs or FCCircularText (both of which have an alternative storage url due to their size) in the AddOnManager > Macros tab using:
OS: Windows 7
Version: 0.18.15536 (Git)
Hash: 98ebeaa198df945ba666c15912c6caf95920f0ef
Python version: 3.6.6
Qt version: 5.6.2
results in the following output in Report View:
  File "E:\Data\FreeCAD_0.18.15536_Conda_Py3QT5-WinVS2015_x64\FreeCAD_0.18.15536_Conda_Py3QT5-WinVS2015_x64\Mod\AddonManager\AddonManager.py", line 815, in run
    self.macro.fill_details_from_wiki(url)
  File "E:\Data\FreeCAD_0.18.15536_Conda_Py3QT5-WinVS2015_x64\FreeCAD_0.18.15536_Conda_Py3QT5-WinVS2015_x64\Mod\AddonManager\addonmanager_macro.py", line 124, in fill_details_from_wiki
    response += data
TypeError: must be str, not bytes
After some testing back and forth in both Py3Qt5 and Py2Qt4, I propose the change as per https://forum.freecadweb.org/viewtopic. ... 10#p278156
If I'm looking at this from the wrong angle and the macro authors need to amend their side then please let me know.
looo
Postby looo » Sat Jan 05, 2019 1:54 pm
Thanks for reporting: https://github.com/FreeCAD/FreeCAD/pull/1893
Btw. creating a PR on github is really easy. If you have an account it is up to browsing to the file clicking the edit symbol, make changes and propose via PR. In case you find any other issues like this one.
bernd
Postby bernd » Sun Jan 06, 2019 7:06 am
Qtgui import problem on Python3 ... https://forum.freecadweb.org/viewtopic.php?f=4&t=33252
looo
Postby looo » Tue Jan 08, 2019 9:29 am
Exporting as .obj file:
  File "<string>", line 4, in <module>
  File "/home/lo/conda/envs/dakota/Mod/Arch/importOBJ.py", line 159, in export
    vlist,elist,flist = getIndices(obj.Shape,offset)
  File "/home/lo/conda/envs/dakota/Mod/Arch/importOBJ.py", line 71, in getIndices
    FreeCAD.Console.PrintWarning(translate("Arch","Found a shape containing curves, triangulating").decode('utf8')+"\n")
<class 'AttributeError'>: 'str' object has no attribute 'decode'
Site Admin
Postby wmayer » Tue Jan 08, 2019 12:29 pm
Fixed with: git commit 1ebcb3654
This is also wrong for Py2 because translate() returns a unicode object which raises an error for invalid characters (like umlauts because they are not encoded there). Looks like in the past it returned a bytes object.
looo
Postby looo » Tue Jan 08, 2019 4:09 pm
thanks.
ztirffritz
Postby ztirffritz » Thu Jan 10, 2019 4:05 pm
Version: 0.18.15609 (Git)
Hash: a14af0f2bd26f980d71be80a799ee48127bc7619
Qt version: 5.6.2
I tried opening this version today and found all the file preview images are missing. It's just a "?" in place of the file preview. I'm obviously a FreeCAD newb, so forgive me if this is already reported or addressed elsewhere.
Good is the enemy of Excellent. Talent is not necessary for Excellence.
Persistence is necessary for Excellence. And Persistence is a Decision.
