Porting to python3
yorik
Site Admin
Re: Porting to python3
Postby yorik » Wed Jan 23, 2019 12:53 pm
I can't reproduce that error either... Do you have the BIM WB installed twice?
Chris_G
Postby Chris_G » Wed Jan 23, 2019 4:40 pm
I think this is related to Python 3, ActiveView doesn't display the list of available properties and methods in the python console
when typing the dot :
FreeCADGui.ActiveDocument.ActiveView
>>> FreeCADGui.ActiveDocument.ActiveView.__dir__()
AttributeError: __dir__
OS: Ubuntu 18.04.1 LTS
Version: 0.18.15548 (Git) AppImage
Hash: df3853738ebe5f91e3768c47c5db5594809ffeb7
Python version: 3.6.7
Qt version: 5.6.2
Locale: French/France (fr_FR)
bitacovir
Postby bitacovir » Wed Jan 23, 2019 4:50 pm
bitacovir wrote:
Mon Jan 21, 2019 7:02 pm
yorik wrote:
Mon Jan 21, 2019 12:36 pm
Fasteners works OK for me with python3... Can you try reinstalling it?
Yes. I reinstalled it and now the message with error of Fasteners has gone.
But now I have this message:
During initialization the error "'BIMWorkbench' already exists." occurred in C:\Users\Rafael\AppData\Roaming\FreeCAD\Mod\BIM.bak\InitGui.py
Please look into the log file for further informatio
n
Fixed.
I manually deleted all BIM Folders in AppData folder and reinstalled them via Addon Manager. No more messages about BIMWorkbench.
::bitacovir::
My Blog
Mini Airflow Tunnel Project
yorik
Site Admin
Postby yorik » Thu Jan 24, 2019 1:24 pm
Yes I saw that too but couldn't nail down exactly what's happening. But it is only the rendering of the contents to the console, for ex.
FreeCAD.ActiveDocument.ActiveView.getSceneGraph()
still works
reox
Postby reox » Sat Jan 26, 2019 5:41 pm
Just a general question: I build freecad from master with qt5 and py3 but it is unusable. Basically no geometry is shown and it can not made visible:
<class 'AttributeError'>: 'Gui.ViewProviderDocumentObject' object has no attribute 'Visibility'
Are such errors and behaviour to be expected when building with py3 or should it work but my build configuration is wrong?
looo
Postby looo » Tue Feb 05, 2019 5:45 pm
Once we have finally moved to python3 we have to work on auto-completion anyway:
https://forum.freecadweb.org/viewtopic. ... 10#p206336
I have no idea why it is not working.
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
looo
Postby looo » Tue Feb 05, 2019 6:36 pm
Maybe a hint from pycxx [1]:
Do not forget to add the call range::init_type() to some module's init function. You will want a method in some module that can create range objects, too.
searching for "View3DInventorViewerPy::init_type()" seems to give only one occurrence. So this is never called.
[1] http://cxx.sourceforge.net/PyCXX-Python ... nsion_type
looo
Postby looo » Wed Feb 06, 2019 9:52 am
btw: There are also crashes because of the way how freecad tries to autocomplete:
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f0c40663f20]
#1  0x7f0c42b36168 in Gui::CallTipsList::extractTipsFromObject(Py::Object&, Py::List&, QMap<QString, Gui::CallTip>&) const from /home/lo/conda/envs/freecad_gcc7/bin/../lib/libFreeCADGui.so+0x2d8
#2  0x7f0c42b38da6 in Gui::CallTipsList::extractTips(QString const&) const from /home/lo/conda/envs/freecad_gcc7/bin/../lib/libFreeCADGui.so+0xb26
#3  0x7f0c42b3961b in Gui::CallTipsList::showTips(QString const&) from /home/lo/conda/envs/freecad_gcc7/bin/../lib/libFreeCADGui.so+0x20b
#4  0x7f0c42b48084 in Gui::PythonConsole::keyPressEvent(QKeyEvent*) from /home/lo/conda/envs/freecad_gcc7/bin/../lib/libFreeCADGui.so+0x554
#5  0x7f0c4125af77 in QWidget::event(QEvent*) from /home/lo/conda/envs/freecad_gcc7/bin/../lib/libQt5Widgets.so.5+0x7e7
#6  0x7f0c413334ae in QFrame::event(QEvent*) from /home/lo/conda/envs/freecad_gcc7/bin/../lib/libQt5Widgets.so.5+0x1e
I guess this feature has to be aligned with the standard python way to do this. Maybe the easiest way is to rewrite the FreeCAD-console in python. There are some examples available: eg.: ipython-qt-console
btw.: auto-completing also doesn't work for activeView in jupyter-qt-console.
Site Admin
Postby wmayer » Tue Feb 12, 2019 2:36 pm
https://github.com/FreeCAD/FreeCAD/blob ... n.cpp#L425
looo
Postby looo » Wed Feb 13, 2019 7:31 am
I see, thanks. Any ideas how to debug this behavior? (missing auto-completion)
