Porting to python3
iplayfast
Re: Porting to python3
Postby iplayfast » Wed Jun 17, 2020 6:33 pm
It appears that I've got shiboken 1.2.2-5 and shiboken2 5.11.2-0ppa2~ub installed.
However, the python problem has been fixed. Another source was pulling it in. Uninstalling the old version and keeping the new one make it python3 only. (yeah! Thanks for the help!).
Next problem is pcl files seem to have a problem. I build pcl from source installed at /usr/local/include/pcl-1.11/pcl which seems to line up with the compile string(below).
error is:
make VERBOSE=1 >out.txt
/home/chris/github/freecad-source/src/Mod/ReverseEngineering/App/RegionGrowing.cpp: In member function ‘void Reen::RegionGrowing::perform(int)’:
/home/chris/github/freecad-source/src/Mod/ReverseEngineering/App/RegionGrowing.cpp:64:146: error: invalid use of incomplete type ‘class boost::shared_ptr<pcl::search::Search<pcl::PointXYZ> >’
 Z>::Ptr tree = boost::shared_ptr<pcl::search::Search<pcl::PointXYZ> > (new pcl::search::KdTree<pcl::PointXYZ>);
In file included from /usr/include/boost/throw_exception.hpp:73:0,
                 from /usr/include/boost/dynamic_bitset/dynamic_bitset.hpp:52,
                 from /usr/include/boost/dynamic_bitset.hpp:15,
                 from /home/chris/github/freecad-source/src/App/PropertyStandard.h:34,
                 from /home/chris/github/freecad-source/src/Mod/Points/App/Points.h:35,
                 from /home/chris/github/freecad-source/src/Mod/ReverseEngineering/App/RegionGrowing.cpp:27:
/usr/include/boost/exception/exception.hpp:15:44: note: declaration of ‘class boost::shared_ptr<pcl::search::Search<pcl::PointXYZ> >’
produced from:
[ 58%] Building CXX object src/Mod/ReverseEngineering/App/CMakeFiles/ReverseEngineering.dir/RegionGrowing.cpp.o
cd /home/chris/github/freecad-source/build/src/Mod/ReverseEngineering/App && /usr/bin/c++  -DDISABLE_LIBUSB_1_0 -DDISABLE_PCAP -DDISABLE_PNG -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DHAVE_PCL_FILTERS -DHAVE_PCL_SAMPLE_CONSENSUS -DHAVE_PCL_SEGMENTATION -DHAVE_PCL_SURFACE -DQT_CONCURRENT_LIB -DQT_CORE_LIB -DQT_NO_DEBUG -DQT_XML_LIB -DReverseEngineering_EXPORTS -D_OCC64 -Dqh_QHpointer -DvtkRenderingContext2D_AUTOINIT="1(vtkRenderingContextOpenGL2)" -DvtkRenderingCore_AUTOINIT="3(vtkInteractionStyle,vtkRenderingFreeType,vtkRenderingOpenGL2)" -I/home/chris/github/freecad-source/build -I/home/chris/github/freecad-source/build/src -I/home/chris/github/freecad-source/src -I/usr/include/opencascade -I/usr/include/python3.6m -I/usr/include/ni -I/usr/include/openni2 -isystem /usr/local/include/vtk-8.1 -isystem /usr/include/eigen3 -isystem /usr/local/include/pcl-1.11 -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -isystem /usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent  -Wall -Wextra -Wno-write-strings  -fPIC   -I/usr/include/openmpi -I/usr/include/hdf5/openmpi -pthread -I/usr/lib/x86_64-linux-gnu/openmpi/include -I/usr/lib/x86_64-linux-gnu/openmpi/include/openmpi -fPIC -march=native -msse4.2 -mfpmath=sse -std=gnu++14 -o CMakeFiles/ReverseEngineering.dir/RegionGrowing.cpp.o -c /home/chris/github/freecad-source/src/Mod/ReverseEngineering/App/RegionGrowing.cpp
src/Mod/ReverseEngineering/App/CMakeFiles/ReverseEngineering.dir/build.make:118: recipe for target 'src/Mod/ReverseEngineering/App/CMakeFiles/ReverseEngineering.dir/RegionGrowing.cpp.o' failed
Site Admin
Postby wmayer » Wed Jun 17, 2020 8:05 pm
This means a class declaration is missing: Now boost::shared_ptr<pcl::search::Search<pcl::PointXYZ> > is a rather complex type and it could be that boost::shared_ptr, pcl::search::Search or pcl::PointXYZ is not known.
However, the two pcl types are defined in pcl/search/search.h and pcl/point_types.h and both are included. So, it remains boost::shared_ptr. Try to include <boost/shared_ptr.hpp> and check if fixes the issue.
iplayfast
Postby iplayfast » Wed Jun 17, 2020 8:30 pm
This is the result.
/home/chris/github/freecad-source/src/Mod/ReverseEngineering/App/RegionGrowing.cpp:64:59: error: conversion from ‘boost::shared_ptr<pcl::search::Search<pcl::PointXYZ> >’ to non-scalar type ‘pcl::search::Search<pcl::PointXYZ>::Ptr {aka std::shared_ptr<pcl::search::Search<pcl::PointXYZ> >}’ requested
     pcl::search::Search<pcl::PointXYZ>::Ptr tree = boost::shared_ptr<pcl::search::Search<pcl::PointXYZ> > (new pcl::search::KdTree<pcl::PointXYZ>);
I tried rebuilding without PCL thinking that pcl was the only problem....
cmake .. -DBUILD_QT5=ON -DPYTHON_EXECUTABLE=/usr/bin/python3
Other problems showed up. Maybe a general clue?
with make VERBOSE=1
cd /home/chris/github/freecad-source/build/src/Main && /usr/bin/cmake -E cmake_link_script CMakeFiles/FreeCADMain.dir/link.txt --verbose=1
/usr/bin/c++  -Wall -Wextra -Wno-write-strings    CMakeFiles/FreeCADMain.dir/MainGui.cpp.o  -o ../../bin/FreeCAD   -L/usr/lib/x86_64-linux-gnu/hdf5/openmpi  -L/usr/lib/openmpi/lib  -L/usr/lib/x86_64-linux-gnu/openmpi/lib  -Wl,-rpath,/usr/lib/x86_64-linux-gnu/hdf5/openmpi:/usr/lib/openmpi/lib:/usr/lib/x86_64-linux-gnu/openmpi/lib:/home/chris/github/freecad-source/build/lib: -lhdf5 -lmpi -lmpi_cxx -lmpi ../../lib/libFreeCADGui.so ../../lib/libFreeCADApp.so ../../lib/libFreeCADBase.so -lhdf5 -lmpi -lmpi_cxx -lmpi -lmpi_cxx /usr/lib/x86_64-linux-gnu/libxerces-c.so /usr/lib/x86_64-linux-gnu/libz.so /usr/lib/x86_64-linux-gnu/libpython3.6m.so -lutil -ldl /usr/lib/x86_64-linux-gnu/libQt5Xml.so.5.9.5 /usr/lib/x86_64-linux-gnu/libCoin.so /usr/lib/libboost_filesystem.so.1.71.0 /usr/lib/libboost_program_options.so.1.71.0 /usr/lib/libboost_regex.so.1.71.0 /usr/lib/libboost_system.so.1.71.0 /usr/lib/libboost_thread.so.1.71.0 -lpthread -lpthread /usr/lib/x86_64-linux-gnu/libGL.so /usr/lib/x86_64-linux-gnu/libQt5OpenGL.so.5.9.5 /usr/lib/x86_64-linux-gnu/libQt5PrintSupport.so.5.9.5 /usr/lib/x86_64-linux-gnu/libQt5Svg.so.5.9.5 /usr/lib/x86_64-linux-gnu/libQt5Network.so.5.9.5 /usr/lib/x86_64-linux-gnu/libQt5UiTools.a /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5.9.5 /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5.9.5 /usr/lib/x86_64-linux-gnu/libQt5Core.so.5.9.5 /usr/lib/libspnav.so /usr/lib/x86_64-linux-gnu/libshiboken2.cpython-36m-x86_64-linux-gnu.so /usr/lib/x86_64-linux-gnu/libpyside2.cpython-36m-x86_64-linux-gnu.so
../../lib/libFreeCADApp.so: undefined reference to `boost::re_detail_107300::perl_matcher<char const*, std::allocator<boost::sub_match<char const*> >, boost::regex_traits<char, boost::cpp_regex_traits<char> > >::match()'
../../lib/libFreeCADGui.so: undefined reference to `boost::re_detail_107300::perl_matcher<char const*, std::allocator<boost::sub_match<char const*> >, boost::regex_traits<char, boost::cpp_regex_traits<char> > >::construct_init(boost::basic_regex<char, boost::regex_traits<char, boost::cpp_regex_traits<char> > > const&, boost::regex_constants::_match_flags)'
../../lib/libFreeCADGui.so: undefined reference to `boost::re_detail_107300::perl_matcher<__gnu_cxx::__normal_iterator<char const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<boost::sub_match<__gnu_cxx::__normal_iterator<char const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::regex_traits<char, boost::cpp_regex_traits<char> > >::construct_init(boost::basic_regex<char, boost::regex_traits<char, boost::cpp_regex_traits<char> > > const&, boost::regex_constants::_match_flags)'
../../lib/libFreeCADGui.so: undefined reference to `boost::re_detail_107300::perl_matcher<char const*, std::allocator<boost::sub_match<char const*> >, boost::regex_traits<char, boost::cpp_regex_traits<char> > >::find()'
../../lib/libFreeCADGui.so: undefined reference to `boost::re_detail_107300::perl_matcher<__gnu_cxx::__normal_iterator<char const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<boost::sub_match<__gnu_cxx::__normal_iterator<char const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::regex_traits<char, boost::cpp_regex_traits<char> > >::find()'
src/Main/CMakeFiles/FreeCADMain.dir/build.make:125: recipe for target 'bin/FreeCAD' failed
make[2]: *** [bin/FreeCAD] Error 1
make[2]: Leaving directory '/home/chris/github/freecad-source/build'
CMakeFiles/Makefile2:2602: recipe for target 'src/Main/CMakeFiles/FreeCADMain.dir/all' failed
make[1]: *** [src/Main/CMakeFiles/FreeCADMain.dir/all] Error 2
make[1]: Leaving directory '/home/chris/github/freecad-source/build'
Makefile:146: recipe for target 'all' failed
make: *** [all] Error 2
Site Admin
Postby wmayer » Thu Jun 18, 2020 7:55 am
Summary report
-- Build type:
-- Compiler: /usr/bin/c++ (7.5.0)
-- Flags: -Wall -Wextra -Wno-write-strings
-- Standard: Requires C++11
-- Python: [/usr/bin/python3] [.cpython-36m-x86_64-linux-gnu]
-- PCL: 1.8.1
-- pybind11: not enabled
-- Boost: 107300
Recently I have built FreeCAD using boost 1.73 which currently is the very latest release and there everything went fine.
Now when you check your linking options then it uses boost 1.71 instead of 1.73.
No idea how this can happen.
iplayfast
Postby iplayfast » Fri Jun 19, 2020 3:48 pm
you've got a good eye.
Turns out it was a bad boost install. Didn't fix all the problems but at least it's getting further.
In file included from /usr/local/include/boost/variant/apply_visitor.hpp:17:0,
                 from /usr/local/include/boost/geometry/algorithms/append.hpp:26,
                 from /usr/local/include/boost/geometry/algorithms/detail/assign_values.hpp:33,
                 from /usr/local/include/boost/geometry/algorithms/detail/assign_indexed_point.hpp:21,
                 from /usr/local/include/boost/geometry/policies/relate/intersection_points.hpp:20,
                 from /usr/local/include/boost/geometry/strategies/intersection_strategies.hpp:20,
                 from /usr/local/include/boost/geometry/strategies/strategies.hpp:39,
                 from /usr/local/include/boost/geometry/geometry.hpp:58,
                 from /usr/local/include/boost/geometry.hpp:17,
                 from /home/chris/github/freecad-source/src/Mod/Path/App/Area.cpp:36:
/usr/local/include/boost/geometry/index/detail/rtree/node/variant_visitor.hpp: In instantiation of ‘void boost::geometry::index::detail::rtree::apply_visitor(Visitor&, boost::variant<boost::geometry::index::detail::rtree::variant_leaf<Value, Parameters, Box, Allocators, Tag>, boost::geometry::index::detail::rtree::variant_internal_node<Value, Parameters, Box, Allocators, Tag> >&) [with Visitor = boost::geometry::index::detail::rtree::visitors::insert<boost::geometry::index::detail::rtree::ptr_pair<boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::variant<boost::geometry::index::detail::rtree::variant_leaf<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::allocators<boost::container::new_allocator<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >, std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::node_variant_static_tag>, boost::geometry::index::detail::rtree::node_variant_static_tag>, boost::geometry::index::detail::rtree::variant_internal_node<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16, 4>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::allocators<boost::container::new_allocator<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >, std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16, 4>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::node_variant_static_tag>, boost::geometry::index::detail::rtree::node_variant_static_tag> >*>, boost::geometry::index::rtree<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, RGetter>::members_holder, boost::geometry::index::detail::rtree::insert_default_tag>; Value = std::pair<std::_List_iterator<WireInfo>, long unsigned int>; Parameters = boost::geometry::index::linear<16>; Box = boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >; Allocators = boost::geometry::index::detail::rtree::allocators<boost::container::new_allocator<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >, std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::node_variant_static_tag>; Tag = boost::geometry::index::detail::rtree::node_variant_static_tag]’:
/usr/local/include/boost/geometry/index/detail/rtree/visitors/remove.hpp:313:37:   required from ‘void boost::geometry::index::detail::rtree::visitors::remove<MembersHolder>::reinsert_node_elements(Node&, boost::geometry::index::detail::rtree::visitors::remove<MembersHolder>::size_type) [with Node = boost::geometry::index::detail::rtree::variant_internal_node<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::allocators<boost::container::new_allocator<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >, std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::node_variant_static_tag>, boost::geometry::index::detail::rtree::node_variant_static_tag>; MembersHolder = boost::geometry::index::rtree<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, RGetter>::members_holder; boost::geometry::index::detail::rtree::visitors::remove<MembersHolder>::size_type = long unsigned int]’
/usr/local/include/boost/geometry/index/detail/rtree/visitors/remove.hpp:274:43:   required from ‘void boost::geometry::index::detail::rtree::visitors::remove<MembersHolder>::reinsert_removed_nodes_elements() [with MembersHolder = boost::geometry::index::rtree<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, RGetter>::members_holder]’
/usr/local/include/boost/geometry/index/detail/rtree/visitors/remove.hpp:133:48:   required from ‘void boost::geometry::index::detail::rtree::visitors::remove<MembersHolder>::operator()(boost::geometry::index::detail::rtree::visitors::remove<MembersHolder>::internal_node&) [with MembersHolder = boost::geometry::index::rtree<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, RGetter>::members_holder; boost::geometry::index::detail::rtree::visitors::remove<MembersHolder>::internal_node = boost::geometry::index::detail::rtree::variant_internal_node<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::allocators<boost::container::new_allocator<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >, std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::node_variant_static_tag>, boost::geometry::index::detail::rtree::node_variant_static_tag>]’
/usr/local/include/boost/variant/variant.hpp:1028:24:   required from ‘typename boost::disable_if_c<(MoveSemantics && boost::is_same<Value2, Value2>::value), typename Visitor::result_type>::type boost::detail::variant::invoke_visitor<Visitor, MoveSemantics>::internal_visit(T&&, int) [with T = boost::geometry::index::detail::rtree::variant_internal_node<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::allocators<boost::container::new_allocator<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >, std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::node_variant_static_tag>, boost::geometry::index::detail::rtree::node_variant_static_tag>&; Visitor = boost::geometry::index::detail::rtree::visitors::remove<boost::geometry::index::rtree<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, RGetter>::members_holder>; bool MoveSemantics = false; typename boost::disable_if_c<(MoveSemantics && boost::is_same<Value2, Value2>::value), typename Visitor::result_type>::type = void]’
/usr/local/include/boost/variant/detail/visitation_impl.hpp:133:13:   required from ‘typename Visitor::result_type boost::detail::variant::visitation_impl_invoke_impl(int, Visitor&, VoidPtrCV, T*, mpl_::false_) [with Visitor = boost::detail::variant::invoke_visitor<boost::geometry::index::detail::rtree::visitors::remove<boost::geometry::index::rtree<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, RGetter>::members_holder>, false>; VoidPtrCV = void*; T = boost::geometry::index::detail::rtree::variant_internal_node<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::allocators<boost::container::new_allocator<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >, std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::node_variant_static_tag>, boost::geometry::index::detail::rtree::node_variant_static_tag>; typename Visitor::result_type = void; mpl_::false_ = mpl_::bool_<false>]’
/usr/local/include/boost/variant/detail/visitation_impl.hpp:157:41:   [ skipping 4 instantiation contexts, use -ftemplate-backtrace-limit=0 to disable ]
/usr/local/include/boost/variant/variant.hpp:2393:52:   required from ‘typename Visitor::result_type boost::variant<T0, TN>::apply_visitor(Visitor&) & [with Visitor = boost::geometry::index::detail::rtree::visitors::remove<boost::geometry::index::rtree<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, RGetter>::members_holder>; T0_ = boost::geometry::index::detail::rtree::variant_leaf<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::allocators<boost::container::new_allocator<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >, std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::node_variant_static_tag>, boost::geometry::index::detail::rtree::node_variant_static_tag>; TN = {boost::geometry::index::detail::rtree::variant_internal_node<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16, 4>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::allocators<boost::container::new_allocator<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >, std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16, 4>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::node_variant_static_tag>, boost::geometry::index::detail::rtree::node_variant_static_tag>}; typename Visitor::result_type = void]’
/usr/local/include/boost/variant/detail/apply_visitor_unary.hpp:48:72:   required from ‘typename Visitor::result_type boost::apply_visitor(Visitor&, Visitable&&) [with Visitor = boost::geometry::index::detail::rtree::visitors::remove<boost::geometry::index::rtree<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, RGetter>::members_holder>; Visitable = boost::variant<boost::geometry::index::detail::rtree::variant_leaf<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::allocators<boost::container::new_allocator<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >, std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::node_variant_static_tag>, boost::geometry::index::detail::rtree::node_variant_static_tag>, boost::geometry::index::detail::rtree::variant_internal_node<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16, 4>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::allocators<boost::container::new_allocator<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >, std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16, 4>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::node_variant_static_tag>, boost::geometry::index::detail::rtree::node_variant_static_tag> >&; typename Visitor::result_type = void]’
/usr/local/include/boost/geometry/index/detail/rtree/node/variant_visitor.hpp:51:25:   required from ‘void boost::geometry::index::detail::rtree::apply_visitor(Visitor&, boost::variant<boost::geometry::index::detail::rtree::variant_leaf<Value, Parameters, Box, Allocators, Tag>, boost::geometry::index::detail::rtree::variant_internal_node<Value, Parameters, Box, Allocators, Tag> >&) [with Visitor = boost::geometry::index::detail::rtree::visitors::remove<boost::geometry::index::rtree<std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, RGetter>::members_holder>; Value = std::pair<std::_List_iterator<WireInfo>, long unsigned int>; Parameters = boost::geometry::index::linear<16>; Box = boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >; Allocators = boost::geometry::index::detail::rtree::allocators<boost::container::new_allocator<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >, std::pair<std::_List_iterator<WireInfo>, long unsigned int>, boost::geometry::index::linear<16>, boost::geometry::model::box<boost::geometry::model::point<double, 3, boost::geometry::cs::cartesian> >, boost::geometry::index::detail::rtree::node_variant_static_tag>; Tag = boost::geometry::index::detail::rtree::node_variant_static_tag]’
/usr/local/include/boost/geometry/index/rtree.hpp:1573:37:   required from ‘boost::geometry::index::rtree<Value, Options, IndexableGetter, EqualTo, Allocator>::size_type boost::geometry::index::rtree<Value, Options, IndexableGetter, EqualTo, Allocator>::raw_remove(const value_type&) [with Value = std::pair<std::_List_iterator<WireInfo>, long unsigned int>; Parameters = boost::geometry::index::linear<16>; IndexableGetter = RGetter; EqualTo = boost::geometry::index::equal_to<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >; Allocator = boost::container::new_allocator<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >; boost::geometry::index::rtree<Value, Options, IndexableGetter, EqualTo, Allocator>::size_type = long unsigned int; boost::geometry::index::rtree<Value, Options, IndexableGetter, EqualTo, Allocator>::value_type = std::pair<std::_List_iterator<WireInfo>, long unsigned int>]’
/usr/local/include/boost/geometry/index/rtree.hpp:771:22:   required from ‘boost::geometry::index::rtree<Value, Options, IndexableGetter, EqualTo, Allocator>::size_type boost::geometry::index::rtree<Value, Options, IndexableGetter, EqualTo, Allocator>::remove(const value_type&) [with Value = std::pair<std::_List_iterator<WireInfo>, long unsigned int>; Parameters = boost::geometry::index::linear<16>; IndexableGetter = RGetter; EqualTo = boost::geometry::index::equal_to<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >; Allocator = boost::container::new_allocator<std::pair<std::_List_iterator<WireInfo>, long unsigned int> >; boost::geometry::index::rtree<Value, Options, IndexableGetter, EqualTo, Allocator>::size_type = long unsigned int; boost::geometry::index::rtree<Value, Options, IndexableGetter, EqualTo, Allocator>::value_type = std::pair<std::_List_iterator<WireInfo>, long unsigned int>]’
/home/chris/github/freecad-source/src/Mod/Path/App/Area.cpp:2743:52:   required from here
/usr/local/include/boost/variant/detail/apply_visitor_binary.hpp:180:1: note: candidate: template<class Visitor, class Visitable1, class Visitable2> typename Visitor::result_type boost::apply_visitor(Visitor&, Visitable1&&, Visitable2&&)
 apply_visitor( Visitor& visitor, Visitable1&& visitable1, Visitable2&& visitable2)
/usr/local/include/boost/variant/detail/apply_visitor_binary.hpp:180:1: note:   template argument deduction/substitution failed:
and it goes on and on. (I hate template error messages, just next to useless).
Any thoughts? (Perhaps I should continue this thread on the install/compile forum as it seems to have moved beyond python3 problems).
*edit* started thread in install/compile forum so please reply there https://forum.freecadweb.org/viewtopic.php?f=4&t=47797
