Uh, I'm getting religious about little things. 10 posts after I've signed up. Please stop me if I'm getting into the habit.
ian.rees wrote:jan wrote:And it's not at all targeting "sneakily different platforms", we'd just take Boost up on its promise not to change its API when we tell it not to use C++11 (or parts thereof) internally on older distros.
Well, I guess that's subjective. The point of that #define is to remove a move constructor, which is an API change which I wouldn't expect to see on a C++11 project using a version of Boost that nominally supports C++11.
In boost::any, you mean? Yes, good example: A move constructor that
wrongly kicks in when you don't want it to. The official fix is to exclude that case. You don't even want that ctor to run in the crash's case, so it could just as well get lost in the first place, AFAICS
BTW: you could also have your FC-private any-class, derived from the original, add the same precaution to the ctor as in the official fix, and be done with it.
Strictly speaking I'm not the biggest Boost fanboy around - but it does support C++11. Turns out that there's a bug in that support. Honestly, Ian, why do you care? It can be disabled. It has worked inside FreeCAD this way for a long time now. Boost may not use all move ctors where it could, so performance is a little worse than it could be. But it's source-code compatible. All C++11 code you write should still compile. Also new syntax that is unique to C++11, a thing you'd have to #ifdef out all over the place in FC if you wanted to maintain a codebase optionally supporting strict non-C++11 builds as well. Why precisely does that help unleash C++11 integration into FC? Or C++14 later on, for that matter?
That said: All this applies only to distros not having a libboost-dev / boost-devel 1.55+ installed. Distros that are already slashed off the list currently. All others would remain unaffected, so certainly no workbenches lost or anything. What's wrong with just giving the oldies a chance? You can always declare their support end of life if it doesn't work. On my machine, it does work. Not thoroughly tested, granted.
ian.rees wrote:I just think that it's better to keep things as simple as possible - have personally spent a lot of time trying to track down bugs caused by this sort of thing.
Yeah, maybe some bugs will pop up here and there, but I currently don't understand where that could possibly be. And most importantly: incrementally phasing stuff out does help to understand things better in my experience. Steps as small as possible to a tested code path give problems that tend to be more understandable and helpful to find bugs. That's why you should always use an old engine in a newly constructed aircraft and vice versa. Not both new, ideally. Might be a matter of development habits, but I found my software's stability improving on all platforms if I compile it on as many as possible. So I tend to
keep support for what I have as long as possible instead of removing it. Also keeping things does feel as if I've accomplished something meaningful.
ian.rees wrote:jan wrote:Anyway, I feel I'm starting to annoy, so I better shut up. Thanks for the explanations so far!
Sorry if I gave you that impression - I think the OpenSUSE issue you brought up is exactly what this thread had been lacking!
Nah, ya didn't. I'm just being a sissy, I suppose. But I wasn't referring to packaging preferences, more to C++, and that case seems closed. I don't want to look like I'm filibustering decision-making processes I didn't attend early enough to make my case.
