appimage
Re: appimage
since webm is not being enabled on wiki for the time being...
I just made a very compressed gif that I will add to the appimage wiki page.
- kkremitzki
Re: appimage
I can try to knock that out this afternoon, do you happen to know if there was an issue created or discussion on this previously I can take a look at in case anything important was mentioned?
Re: appimage
Haven't found anything yet. If I do, will post here.kkremitzki wrote: ↑Sat Nov 10, 2018 6:24 pm I can try to knock that out this afternoon, do you happen to know if there was an issue created or discussion on this previously I can take a look at in case anything important was mentioned?
Thanks mate!
Re: appimage
What wiki page are you speaking of? There is no AppImage page on our wiki.
Please ask yourself this: what is it that this animated gif will tell that actual text wouldn't ? I've said it enough times now: an animated GIF that lasts more than 10 seconds is basically unwatchable because you don't know when it starts, you cannot pause it, etc.
Re: appimage
Hmm... i could of swore i thought there was an appImage page on the wiki... <head scratch>
I guess if there isn't one it needs to be made with an explanation of what it is....or it can be a collapsed <div> on the Download page?
To me it gives people the confidence/incentive to use the update methodology, it "demystifies" it if you will. That's what it does for me at least and I'm for sure not alone.
This is true but to be fair I tried to offer a webm version at first and then when I made this gif I attempted to shorten it but have not succeeded in doing so (when I try to edit out frames in GIMP, it will crashes). So in the meantime I felt that at least something is good to have publicly. If you notice the gif does have a timer per se at the bottom (it shows the download progress) so for people that get disoriented by the lack of this, there is that
Re: appimage
2 issues:
- When using the gui AppImageUpdate, it complains that AppImage is not signed. This is a minor thing for veteran users but folks without any knowledge of what an appImage is might find this a dealbreaker.
- Can we submit our FC appimages to https://appimage.github.io/apps/ ?
- Is there a way we can make static links that point to the most up-to-date stable and development appImages ? This would really come in handy on both the Download and Appimage page.
Re: appimage
Funny, to me it's just a wall of meaningless characters scrolling on a dark background.
On the opposite, that last screenshot you posted of a GUI dialog labelled "Updating FreeCAD_0" tells me all I need to know... in one single static image.
Once again, what you're trying to convey with an animated GIF would be much more efficiently communicated with detailed textual instructions, along with commands formatted with the code tag. With the added bonus that people can actually copy-paste the command in their console - try doing that with an animated GIF.
And, I'll remind you not for the first time: please think about other languages. A proper page with textual instructions can be translated. An animated GIF can't.
Re: appimage
There seems to be a bug with appimage dialogs not resizing and it truncates the title of the dialog. I opened a ticket upstream: https://github.com/AppImage/AppImageUpdate/issues/106
Normand, I hear you. You make valid points. I have different perspectives and perceptual biases then yourself and that's OK. I've started working on Appimage. I won't include the gif per your request.
Re: appimage
@sgrogan is there a way we can make static links that point to the most up-to-date stable and development appImages ?
Re: appimage
You may be making this too difficult. A static link to the download page(s) with a small amount of text at the top explaining what the various versions are for should be sufficient.
Clearly there should be emphasis on new user friendliness, but any user of FreeCAD must be at least a little bit comfortable with simple instructions.
The actual versions can change daily as required, but the links to the download page remain stable.
Gene
