appimage
Re: appimage
actually calculix is available from freecad-channel [1], and looking at it's size it's pretty small. So maybe @triplus can make a small modification to the appimage to include calculix.
In the long run I am working towards getting calculix into conda-forge. There is still missing one dependency (spooles) [2]. (Windows for sure makes more problems and needs some more love...)
[1] https://anaconda.org/freecad/calculix/files
[2] https://github.com/conda-forge/staged-recipes/pull/6661
Re: appimage
CalculiX has been added to the PPA based AppImage in the past. But it turned out it hasn't been used by the AppImage (due to some issue involved):
https://forum.freecadweb.org/viewtopic. ... 70#p154219
In addition if i remember correctly available CalculiX version was old and therefore it was considered best if CalculiX isn't added to the AppImage at all and to leave it to the end user (system) to provide one. We had to further tweak the AppImage for the system provided version to work in all reported use cases:
https://forum.freecadweb.org/viewtopic. ... 19#p231708
But i guess things changed a bit as @kkremitzki was active on the FreeCAD Community Extras PPA:
https://forum.freecadweb.org/viewtopic. ... 10#p260488
And now latest CalculiX (v2.14) is available from it for Trusty:
https://launchpad.net/~freecad-communit ... ter=trusty
I did a quick test and got:
P.S. Note that if desired some other packages could be added from the FreeCAD Community Extras PPA to the PPA based AppImage. For Python based workbenches and macros. I don't see much point in doing that. End users can do that with ease. But i see some recently updated packages such as calculix-ccx, ifcopenshell, ifcplusplus and opencamlib. If any of this packages is hard to get on other Linux distributions. Work done on the PPA can propagate to such Linux distributions through AppImage (if the size isn't a problem and it gets confirmed it works in some basic testing).
Therefore yes i guess we can add CalculiX (from the FreeCAD Community Extras PPA) to the PPA based AppImage if that is desired? As for the Conda based one. Sure. I see CalculiX (v2.12) should be available (as i guess you packed it and added it). Are you interested in updating CalculiX to v2.14? Anyway i need to test if it works and if that is desired it can be added. I should have the time to do this in the following week.CalculiX done!
Re: appimage
We could consider a "super Bundle", Graphviz, OpenSCAD, Calculix, GMesh, ifcOpenShell, opencamlib, FreeCAD-doc.
With delta-updates this doesn't sound so crazy. ifcOpenShell and opencamlib need to match Python, but the calculix PPA package should work with the conda AppImage.
It all depends on how big we are willing to let the package get.
"fight the good fight"
Re: appimage
Good idea to have a BigPack, at least as long as a small Appimage exists as well. To keep efforts small it coul be sufficient to update the BigPack only from time to time; in the future perhaps only for the stable release.
- kkremitzki
Re: appimage
Netgen too once we get support for it working again.sgrogan wrote: ↑Mon Oct 08, 2018 10:01 pmWe could consider a "super Bundle", Graphviz, OpenSCAD, Calculix, GMesh, ifcOpenShell, opencamlib, FreeCAD-doc.
Re: appimage
This will be included automatically once it's working for the PPA based AppImage, it's already included with the Conda based AppImage (including the python bindings). Netgen is different than the other referenced packages because it is linked at compile time.
Re: appimage
Created a screencast showing appimageupdatetool in action
https://peertube.mastodon.host/videos/w ... 7241095ad4
Maybe we can add this to the wiki whenever .webm is permitted on the wiki
Re: appimage
Always nice to see informative FreeCAD related content being created.
Re: appimage
I noticed in the past two days there is currently a glitch involved in the AppImage deployment:
https://github.com/FreeCAD/FreeCAD/releases
Randomly Conda/PPA AppImage not getting deployed successfully. Don't have time to look into this today (will have time and try to find a solution in next 2 days) but decided to mention it here. That is if somebody is trying to download/update the AppImage and not being able to find one. Based on the build logs and after taking a quick look at the current setup for Travis i have a clue on what to try out next. And hopefully to make deployment more reliable.
Re: appimage
Note that i restructured the Travis deploy procedure a bit and the mentioned issue should be resolved now. In addition @looo suggested to remove the empty menus related workaround for Conda based AppImage. Due to that working correctly now on Ubuntu 18.04. As a result Conda based AppImage should use native style now.
