appimage
Re: appimage
Let me know if I should include/exclude other deb ingredients in the yml files. You can also play with them yourself if you like.
Re: appimage
Thanks triplus, It will take me some time to understand it all. What is the output of "About FreeCAD"? Yeah "read the .yml" but you will save me timetriplus wrote:@sgrogan
How long does it take to build the package? Again because you are far ahead of me, do we just need to deploy the file, then the user would download it and make it executable? If so we could compress it and deploy to github.
"fight the good fight"
Re: appimage
sgrogan wrote:Thanks triplus, It will take me some time to understand it all. What is the output of "About FreeCAD"? Yeah "read the .yml" but you will save me time
OS: Ubuntu 16.04.1 LTS
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
It shouldn't take long as AFAIK there isn't any "real compiling" going on. Estimation is 10 to 15 minutes.How long does it take to build the package?
Yes. The output is a single portable file. It could i guess be uploaded as is or it could be compressed first.Again because you are far ahead of me, do we just need to deploy the file, then the user would download it and make it executable? If so we could compress it and deploy to github.
@probono
I tested on different DE the last time as on stock Ubuntu 16.04 i don't have menu integrated in global menu. Only for FreeCAD 0.16 version as FreeCAD 0.17 version works OK. I am guessing as you reduced the size of the created AppImage for FreeCAD 0.16 some library responsible for this was left out.
Re: appimage
Note that i will check this again tomorrow on a different PC.triplus wrote:@probono
Re: appimage
Love ittriplus wrote:Double click on the file and do some test or just use FreeCAD in the way as you usually do.
OS: "Arch Linux"
Build type: None
Qt version: 4.8.6
Re: appimage
Damn, I wasted your time. 16.04 doesn't need PPA versions of the packages. I think the .yml uses Ubuntu repo for the packages and we need newer versions on 14.04, that's why we have them on the PPA. 16.04 has everything in universe. This is only important if building on Travis which is 14.04. I know it's possible to install packages from PPA's on Travis. Now we use the default so the Travis uses old oce and eigen3, I think netgen is fixed upstream and the PPA package for netgen is redundant.triplus wrote: Code: Select all
Build type: None
Qt version: 4.8.6
EDIT: cox posted while I was typing. Cool
Re: appimage
No time wasted and small issue with global menu (if confirmed) was spotted. And i enabled the extended desktop support for FreeCAD 0.16 AppImage and it adds the launcher but the icon doesn't look good (plain without the logo). Will test all this tomorrow on another Ubuntu PC.sgrogan wrote:Damn, I wasted your time.
I have a feeling if we remove netgen from the AppImage it could cause issues for some. As the AppImage is based on Ubuntu 14.04 packages. But then again once we will have AppImage to download i do imagine users from different Linux distributions will provide more feedback over time. And from that i guess we will learn what makes sense or doesn't make sense to provide in AppImage. As we have them on PPA i guess providing calculix/netgen in AppImage should result in working FEM WB. Instead of relying on different Linux distribution default packages for calculix/netgen. As i do imagine on some Linux distributions that could cause issues.16.04 doesn't need PPA versions of the packages. I think the .yml uses Ubuntu repo for the packages and we need newer versions on 14.04, that's why we have them on the PPA. 16.04 has everything in universe. This is only important if building on Travis which is 14.04. I know it's possible to install packages from PPA's on Travis. Now we use the default so the Travis uses old oce and eigen3, I think netgen is fixed upstream and the PPA package for netgen is redundant.
Re: appimage
I tested all packages:
https://bintray.com/probono/AppImages/FreeCAD/#files
Application menu isn't integrated in the global menu on Ubuntu 14.04 and Ubuntu 16.04.
Application menu is integrated in the global menu on Ubuntu 14.04 and Ubuntu 16.04. This AppImage adds icon to the desktop launcher.
FreeCAD-0.16.6707.glibc2.17-x86_64.AppImage 5 days ago
FreeCAD-0.17.git201612261451.glibc2.17-x86_64.AppImage 12 days ago
FreeCAD-0.17.glibc2.15-x86_64.AppImage 5 months ago
Re: appimage
Where can I find the .yml for the daily version?And if you run this command:
wget https://raw.githubusercontent.com/probo ... eta/Recipe
bash Recipe FreeCAD-nightly
AppImage will be made for FreeCAD 0.17. Currently based on Ubuntu 14.04 daily PPA without calculix-ccx/netgen included.
Also I don't understand the numpy issue with the release version I didn't think it was a dependency for 0.16.160x
Re: appimage
https://github.com/probonopd/AppImages/ ... ightly.ymlsgrogan wrote:Where can I find the .yml for the daily version?
As for the numpy dependency it was added as when i did some tests Assembly 2 module complained it's missing.
