Creating a dependency loop of containers crashes FreeCAD
DeepSOIC
Postby DeepSOIC » Sat May 28, 2016 7:47 pm
Hi!
I found an interesting way to crash FreeCAD.
Run this:
if App.ActiveDocument is None:
    App.newDocument()
part1 = App.ActiveDocument.addObject("App::Part", "Part1")
part1.Group = [part1]
This itself doesn't cause a crash, but adding another object after doing this does.
Doing a part1->part2->part1 dependency loop causes an out-of-memory exception, and then crashes FreeCAD too.
This problem situation happened when I was modeling with Part-o-magic enabled, and Part-o-magic made such a dependency loop. Of course it is Part-o-magic problem, but it is a FreeCAD problem too, I think.
I lost quite a bit of progress on my model, unfortunately.
Version: 0.17.7668 (Git)
Branch: BodyBase3
Hash: ef872d37a8a365aeb04567d80616b28a826ed41c
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
microelly2
Re: Creating a dependency loop of containers crashes FreeCAD
Postby microelly2 » Sat May 28, 2016 9:31 pm
It makes sense to think about a FreeCAD-Database connection, where dependency structures can be stored.
For some reasons databases are faster and can bring more comfort than the FreeCAD DAG model.
I think using the FreeCAd webserver interface can be an opportunity.
I have played with networkx. Storing Data in FreeCAD and sending them with tasks to specialized servers is for me a good way.
But how to prevent users(programmers) to run into a stackoverflow?
Maybe there is a way to analyse scripts to detect recursive call sequences.
But I'm afraid this is not computable.
ickby
Postby ickby » Sun May 29, 2016 12:42 pm
DeepSOIC wrote: Doing a part1->part2->part1 dependency loop causes an out-of-memory exception, and then crashes FreeCAD too.
I think the problem is not that it does not work, as I don't know of any way that it should work, but the crash instead of a warning. Am I getting you right here?
How does that relate to the given problem?
DeepSOIC
Postby DeepSOIC » Sun May 29, 2016 1:07 pm
ickby wrote:I think the problem is not that it does not work, as I don't know of any way that it should work, but the crash instead of a warning. Am I getting you right here?
Yes, it should not crash, so that the situation can be fixed if it happens to arise because of whatever error in coding (think add-on workbenches and macros, especially).
ickby
Postby ickby » Sun May 29, 2016 1:22 pm
yes definitely something to take care of. Could you add a ticket, so that it is not forgotten?
DeepSOIC
Postby DeepSOIC » Sun May 29, 2016 2:07 pm
ickby wrote:Could you add a ticket, so that it is not forgotten?
Done ;) issue #2567
Site Admin
Postby wmayer » Mon May 30, 2016 1:59 pm
bool DocumentObjectGroup::hasObject(const DocumentObject* obj, bool recursive) const
    const std::vector<DocumentObject*>& grp = Group.getValues();
    for (std::vector<DocumentObject*>::const_iterator it = grp.begin(); it != grp.end(); ++it) {
        if (*it == obj) {
            return true;
        } else if ( recursive && (*it)->isDerivedFrom (App::DocumentObjectGroup::getTypeId()) ) {
            App::DocumentObjectGroup *subGroup = static_cast<App::DocumentObjectGroup *> (*it);
            if (subGroup->hasObject (obj, recursive)) {  // <<<<==============    This causes the overflow
                return true;
    return false;
In this case 'SubGroup' is identical to 'this'. So, the problematic line must be changed to:
if (subGroup != this && subGroup->hasObject (obj, recursive)) {
DeepSOIC
Postby DeepSOIC » Mon May 30, 2016 2:20 pm
wmayer wrote:In this case 'SubGroup' is identical to 'this'. So, the problematic line must be changed to:
Feels like this won't stop the recursion in case of part1->part2->part1 loop.
Site Admin
Postby wmayer » Mon May 30, 2016 3:02 pm
Then a private overloaded method
bool DocumentObjectGroup::hasObject(const DocumentObject* obj, bool recursive, std::set<DocumentObject*>&) const
can be implemented. Internally it adds 'this' and for recursive calls it checks whether 'subGroup' is already. The public method hasObject has to use the private version.
Postby Kunda1 » Sat Jan 28, 2017 12:12 pm
Soft bump to check the status of issue #2567
