Ubuntu snap: A quick try
triplus
Re: Ubuntu snap: A quick try
Postby triplus » Sun Jun 05, 2016 6:25 pm
I wanted to test the snap package update process and after your changes but it seems the snap package updates are not published yet?
vejmarie
Postby vejmarie » Sun Jun 05, 2016 6:47 pm
triplus wrote:I wanted to test the snap package update process and after your changes but it seems the snap package updates are not published yet?
Yes it needs manual ubuntu approval as it is requiring user home directory interfaces :(.
It shall come up within 1 day or 2 ...
vejmarie
ps: if you follow the link you can't get it ?
vejmarie
Postby vejmarie » Mon Jun 06, 2016 1:30 pm
@triplus: I just received a mail from ubuntu telling me that the update is online. So you might give it a try.
triplus
Postby triplus » Tue Jun 07, 2016 8:43 pm
vejmarie wrote:@triplus: I just received a mail from ubuntu telling me that the update is online. So you might give it a try.
I can confirm the update works as advertised.
vejmarie
Postby vejmarie » Tue Jun 07, 2016 8:59 pm
Thanks for the try ! And happy that it worked ;). Still need to wait for wmayer and ickby to make work the SMESH7 on windows to resync everything. I do not really know where to put the vagrant build instruction. I pushed for a PR, but without any success up to now (the code is dirty, but wanted to get feedbacks). Loved to see SMESH 7 moving forward.
looo
Postby looo » Wed Jun 15, 2016 8:54 am
Although I do not like these snaps, I gave it a try. The installation worked great (ubuntu 16.04). Running this version gave me some small errors. Maybe you can have a look:
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
Draft workbench activated
FreeCAD: gl.cpp:2354: const cc_glglue* cc_glglue_instance(int): Assertion `current_ctx && "Must have a current GL context when instantiating cc_glglue!! (Note: if you are using an old Mesa GL version, set the environment variable COIN_GL_NO_CURRENT_CONTEXT_CHECK to get around what may be a Mesa bug.)"' failed.
But I don't like this:
>>> import numpy
>>> numpy.__file__
'/snap/freecad/4/usr/lib/python2.7/dist-packages/numpy/__init__.pyc'
such a good solution. ;)
Ps.: maybe you have a look at conda. It has similar features like snaps, but 1: has smaller app-sizes, 2: not every app is in it's own enviroment (instead one can create environments to run different versions, where dependencies are simple links), 3: works on linux/ mac / windows. So it's a different approach to solve a similar problem.
triplus
Postby triplus » Wed Jun 15, 2016 10:42 am
http://snapcraft.io/
Note that we are listed under Popular snaps category!
triplus
Postby triplus » Thu Jul 07, 2016 12:56 am
It looks like better desktop integration support just landed:
https://developer.ubuntu.com/en/blog/20 ... launchers/
jacquesclouseau
Postby jacquesclouseau » Sun Jul 10, 2016 5:20 pm
:~$ freecad.FreeCAD
mkdir: cannot create directory '/home/username :) /snap/freecad/4/.config': File exists
FreeCAD 0.17, Libs: 0.17R7744 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015
:~$ gnome-panel --version
gnome-panel 3.18.2
ubuntu-gnome 16.04 64 with proposed updates active.
My graphic card is a nvidia gtx750ti
I can provide extra sudo lshw if needed
I thougt it works, but I have just click on new button and program crash, terminal says:
Abortado (`core' generado)
vejmarie
Postby vejmarie » Sun Jul 10, 2016 7:58 pm
jacquesclouseau wrote::~$ freecad.FreeCAD
gnome-panel 3.18.2
Thanks for the feedback and sorry for the issue you are facing. the GL error are really strange to me. Are you running ubuntu Desktop ? Can you provide me the output of lsmod command ?
vejmarie
