vejmarie wrote:Which commit is your build using ? Probably not the latest one (sgrogan is going to "kick me")
OS: Windows 7
Version: 0.17.9842 +15 (Git)
Branch: step
Hash: 304a2622474311d990a3fe99be233e78af612d4f
Python version: 2.7.8
OCC version: 7.0.0
No worries, what is the best to build, the HEAD of step on your fork? It's trivial to do the test builds, now that I have built your OCCT patch.
ickby wrote:just call the addObject() function or add the object to the Group property manually.
something like that?
(image)
but with groups is it possible to assign placement to all the group's parts?
Groups are just a container without a placement, aren't they?
Maurice
ickby was not talking about Groups, which have been in FreeCAD for a long time, but about the Part container introduced in 0.17 with PartDesignNext. It seems that the Part container has a "Group" property. It also has a placement.
Then again maybe he's talking about a different thing.
O/T: the Part container has the same icon as Group, this will need to be addressed at some point to avoid confusion...
Normand is right, i'm talking about App::Part. In the GUI it is currently only accessible from PartDesign, but it is a General object which represents a local coordinate System.
OS: Windows 7
Branch: step
OCC version: 7.0.0
Yep the HEAD of my step branch is the code to build. I'll be curious to have @easyw-fc testing the latest patch and publishing new results. I am pretty sure that it fixed the long read time
thx that is interesting
+1
may be @agrison may find some nice ico
agryson wrote:
- Aligns Workbenchs to guidelines
ickby wrote:Normand is right, i'm talking about App::Part. In the GUI it is currently only accessible from PartDesign, but it is a General object which represents a local coordinate System.
is it possible to create a hierarchy of App::Part?
It seems there is some issue with Axis when manual assembling subParts
ickby wrote:It should not crash The moving should actually work, but again, still working on it. It is rather rough at the moment. However, as you are working on this now it may be good to use the Parts to not need to make the switch later.
And the reason is that you cannot iterate over a vector and modify its size at the same time. As soon as the insert method enlarges the array all iterators become invalid and still using them leads to undefined behaviour. See also: http://www.cplusplus.com/reference/vect ... or/insert/
git commit 5d21eb6 fixes the crash. However, the method still suffers from a second problem: in case the graph is not a DAG then it may run into an infinite loop.
ickby wrote:
I'm curerntly working on fixing some bugs that are in stacking parts, should work soon.
thx
ATM I can assembly root Parts and leafs with python and apply a placement to roots EDIT
is it possible to create a simple copy of the all Part assembly? (also may be with a python macro?)
In debug mode I always get a crash here, too. Looking at the code it became clear very quickly:
it crashes at this line: https://github.com/FreeCAD/FreeCAD/comm ... 40e832R125
Yes noticed this too in my local branch, stupid mistake. Thnaks for fixing.
thx
EDIT
Please open a new topic for such discussions, this has nothing to do with this thread.
the Part structure I posted is exactly the structure that would be probably in the new @vejmarie STEP importer, so I was trying to preview the result before the code changing, testing some user case...
(i.e. compound allows to have a mux of the assembly, but I cannot find a way to have the same with App::Part)
anyway if you think this is out of topic, feel free to move it to the right category...
Maurice
