Sketches that are placed on a part will not show in sketch edit mode.
When i go into part design, create a part, body and then create a sketch, x,y plane, then the sketch will be invisible in edit mode. when i exit edit mode the sketch will be visible again.
have also tried to open an old file with part, body, sketch hierarchy and the sketch is invisible in edit mode there as well.
if i only crates a sketch it works fine.
if i create a body then a sketch it works fine.
if i create a part then a sketch it does not show!
if i create a part and drag and drop the body above to the part, sketch stops showing in edit mode.
if i create a new sketch in a body belonging to a part, sketch will not show in edit mode.
if i open a file containing a part - body - sketch relation, the sketch will not show in edit mode.
OS: Ubuntu 16.10
Version: 0.17.8855 (Git)
Build type: Unknown
Hash: 69517058357f859586909314d3c484864d7a37af
Python version: 2.7.12+
OCC version: 6.8.0.oce-0.17
Part Design/Sketcher issues latest build (git)
Re: Part Design/Sketcher issues latest build (git)
I can confirm this very debilitating bug. It's been there for a little while, but I can't say when it appeared.
Can you please create an issue in the bug tracker? The link is just besides the search box at the top of the forum (bug icon).
commit 60e6ad2e523ebfb44b05e7dba9579d14c04af208
Author: wmayer <wmayer@users.sourceforge.net>
Date: Sun Nov 6 11:21:11 2016 +0100
issue #0002757: sketch editing not visible when it is in a part
src/Mod/Show/DepGraphTools.py | 2 ++
1 file changed, 2 insertions(+)
(for those confused by the text above, this means "problem solved")
<3
<3
