Part Line: Infinit/Finite 2d vs 3d
Re: Part Line: Infinit/Finite 2d vs 3d
Thanks Werner!
@mlampert go into Tools->Edit Parameters and in Preferences/Mod/Part/General, add a new boolean key named "LineOld" and set it to false. Then you'll have the new behaviour, and no more warning. Then it'll be easier to debug.
As for DraftGeomUtils.geomType, I'll fix that right now...
Thanks yorik, I would have fixed it but wasn't sure what the proper fix is (without breaking something that's not covered by the self test).
I guess there is somewhere a bug in the Part module which makes the Draft issues unfixable.mlampert wrote:Thanks yorik, I would have fixed it but wasn't sure what the proper fix is (without breaking something that's not covered by the self test).
When I run this code snippet with the old behaviour I get the expected results:
edge=Part.makeLine((1,2,3),(4,5,6))
isinstance(edge.Curve,(Part.LineSegment,Part.Line)) # True
isinstance(edge.Curve,Part.Line) # False
isinstance(edge.Curve,Part.LineSegment) # True
isinstance(edge.Curve,(Part.LineSegment,Part.Line)) # False but True is expected
isinstance(edge.Curve,Part.Line) # False but True is expected
isinstance(edge.Curve,Part.LineSegment) # False
One way would be to modify TopoShapeEdgePy::getCurve() and after setting the exception add this line:What would be really great is if the deprecation warning would include where it comes from, but I guess it's rather tricky to investigate/print the stack trace.
throw Py::Exception();
Yorik here is a patch which fixes the issues with the unit tests:
diff --git a/src/Mod/Draft/Draft.py b/src/Mod/Draft/Draft.py
index a6ad690..89a3b70 100644
--- a/src/Mod/Draft/Draft.py
+++ b/src/Mod/Draft/Draft.py
@@ -3140,7 +3140,7 @@ def upgrade(objects,delete=False,force=None):
else:
# turn to Draft line
e = objects[0].Shape.Edges[0]
- if isinstance(e.Curve,Part.LineSegment):
+ if isinstance(e.Curve,(Part.LineSegment,Part.Line)):
result = turnToLine(objects[0])
if result: msg(translate("draft", "Found 1 linear object: converting to line\n"))
diff --git a/src/Mod/Draft/DraftGeomUtils.py b/src/Mod/Draft/DraftGeomUtils.py
index f5cb2f7..02d900f 100755
--- a/src/Mod/Draft/DraftGeomUtils.py
+++ b/src/Mod/Draft/DraftGeomUtils.py
@@ -105,7 +105,7 @@ def isPtOnEdge(pt,edge) :
def hasCurves(shape):
"hasCurve(shape): checks if the given shape has curves"
for e in shape.Edges:
- if not isinstance(e.Curve,Part.LineSegment):
+ if not isinstance(e.Curve,(Part.LineSegment,Part.Line)):
return True
return False
@@ -159,9 +159,9 @@ def getQuad(face):
def areColinear(e1,e2):
"""areColinear(e1,e2): returns True if both edges are colinear"""
- if not isinstance(e1.Curve,Part.LineSegment):
+ if not isinstance(e1.Curve,(Part.LineSegment,Part.Line)):
return False
- if not isinstance(e2.Curve,Part.LineSegment):
+ if not isinstance(e2.Curve,(Part.LineSegment,Part.Line)):
return False
v1 = vec(e1)
v2 = vec(e2)
@@ -188,7 +188,7 @@ def hasOnlyWires(shape):
def geomType(edge):
"returns the type of geom this edge is based on"
try:
- if isinstance(edge.Curve,Part.LineSegment):
+ if isinstance(edge.Curve,(Part.LineSegment,Part.Line)):
return "Line"
elif isinstance(edge.Curve,Part.Circle):
return "Circle"
Unfortunately I can throw whatever I want but something catches the exception and suppresses the stack trace.wmayer wrote:One way would be to modify TopoShapeEdgePy::getCurve() and after setting the exception add this line:What would be really great is if the deprecation warning would include where it comes from, but I guess it's rather tricky to investigate/print the stack trace.Then the Python interpreter itself will print the stack trace.Code: Select all
I'm sure I'm doing something wrong and I'm stuck at the moment. I switched to the new LineSegment behaviour, create a Part.Box and then run:
The reason you see all these <type 'Part.GeomLine'> as output of the for comprehension is because I replaced the 'else' case in DraftGeomUtils.geomType(edge) with "return type(edge.Curve)".
It seems that somehow Part.Line is a Part.GeomLine, but when run through DraftGeomUtils.geomType() it isn't.
If anybody could point me to the flaw in my logic I would very much appreciate it and move the Path WB further along switching to the new Line/LineSegment semantics.
>>> from DraftGeomUtils import geomType
>>> [geomType(e) for e in App.ActiveDocument.Box.Shape.Edges]
[<type 'Part.GeomLine'>, <type 'Part.GeomLine'>, <type 'Part.GeomLine'>, <type 'Part.GeomLine'>, <type 'Part.GeomLine'>, <type 'Part.GeomLine'>, <type 'Part.GeomLine'>, <type 'Part.GeomLine'>, <type 'Part.GeomLine'>, <type 'Part.GeomLine'>, <type 'Part.GeomLine'>, <type 'Part.GeomLine'>]
>>> Part.Line
this works for me, though:
>>> b = Part.makeBox(1,1,1)
>>> b.Edges[0].Curve
<Line object>
>>> isinstance(b.Edges[0].Curve,Part.Line)
True
Hey yorik, thanks for your confirmation - as it turned out I only changed the default value in one of the sources, and if you change the preferences you have to restart FC. It always takes me a while to follow instructions - but once you do it works
Part.GeomLine is just the string representation of the type Part.Line. Anyway, since this might be confusing I extended our generation framework to allow to explicitly set the Python type name in the xml files.If anybody could point me to the flaw in my logic I would very much appreciate it and move the Path WB further along switching to the new Line/LineSegment semantics.
