src/Gui/Placement.ui
436: <string>Rotation axis wih angle</string>
No. no . your wrong its an experienced coder's short cut, it stands "Werner Is Hip" or hang on was it "Wankers In Here", no no it "Wally Is Here" "Water Is Hot"momentumv5 wrote:should be "with".Code: Select all
src/Gui/Placement.ui 436: <string>Rotation axis wih angle</string>
