face union
tanderson69
face union
Postby tanderson69 » Sat Nov 26, 2011 12:49 am
I have attached a very simple, gui-less, demonstration application. It tries to merge two coplanar faces, of a solid, into one face. It appears to be working. The algorithm for finding the faces and building the replacement face make assumptions and it is only intended for this demonstration app. I welcome comments and I will be working on creating a "real" detection and replacement routine.
FaceUnion1.zip
this is a zip
(133.16 KiB) Downloaded 90 times
jriegel
Site Admin
Re: face union
Postby jriegel » Sat Nov 26, 2011 9:26 am
That would be great!
Stop whining - start coding!
Site Admin
Re: face union
Postby wmayer » Sat Nov 26, 2011 11:06 am
Just found some hints in the OCC forum. There seems to be already a class in OOC that does it.
http://www.opencascade.org/org/forum/?s ... 1&author=1
I'll make a feature request on Mantis and this link. So, we can look at it again when starting the 0.13 development.
tanderson69
Re: face union
Postby tanderson69 » Sat Nov 26, 2011 3:11 pm
I looked at the gluer class and got the impression that it was intended for "patching" (ug term) an open shell onto a solid. I could be out in left field, because what I know about opencascade probably wouldn't fill up a sticky note.
tanderson69
Re: face union
Postby tanderson69 » Sat Dec 03, 2011 10:12 pm
Making some progress. Successfully detected "equal", adjacent planar faces and replaced with one face.
FaceUnion2.zip
is a zip
(266.32 KiB) Downloaded 49 times
jmaustpc
Re: face union
Postby jmaustpc » Sun Dec 04, 2011 3:39 am
Hi Werner
I just clicked on the occ link, it reads at one point the link "3. Fusing and coplanar feces". Obviously this sounds like what you are talking about but can I just point out that the word "feces" in the illiterate American spelling for "faeces",
I think they meant "faces".
for those who doubt
http://en.wikipedia.org/wiki/Feces
does this mean that they are saying occ is a sh## product?? :lol:
For those who don't know what "faeces" means, an Australian could refer to it as
1) a blind mullet (a "mullet" is a type of fish, a "blind mullet" is the sort you don't want to find while swimming!)
2) a log (as in "I need to lay a log")
3) a "floater"
4) and of course the universal "number 2"
If anyone has a particular desire to see one "in the wild" while in Australia, one could expect to find some examples in their native habitat, commonly a
Dunny
Long Drop
Out House
Bog
Being "built like a brick sh## house" means being built very solidly, possibly overly so, but not necessarily. It is not necessarily derogatory, more likely to be used in a simply descriptive manner. To be describe so for a women, would most likely be not considered in a positive light, however for a bloke or an inanimate object, it could easily be meant as a compliment, or simply as a description of a matter of fact.
As fascinating a subject as it is, I think I shall leave it at that. :)
Jim
NormandC
Re: face union
Postby NormandC » Sun Dec 04, 2011 8:29 pm
jmaustpc wrote:as in "I need to lay a log"
LOL! :lol:
English is such an expressive language. :D
As for mullets, I thought they described these? :P
Site Admin
Re: face union
Postby wmayer » Mon Dec 05, 2011 1:10 pm
tanderson69 wrote:Making some progress. Successfully detected "equal", adjacent planar faces and replaced with one face.
The algorithm is it ready to use as is?
tanderson69
Re: face union
Postby tanderson69 » Mon Dec 05, 2011 3:12 pm
wmayer wrote:The algorithm is it ready to use as is?
Not quite yet. I needed to do some major cleanup. I had a mess of dynamically allocated arrays. I have that done. I need to do some more class work getting the face construction to the abstracted object and prove out the abstraction to another type of face other than planes. I need to do some more tests and try to bullet proof the code. I also was thinking of doing some profiling with a many faceted solid.
I will post code sometimes for 2 reasons: 1 if somebody is interested and wants to share an opinion and 2 if I decide to quit working on it, the code will be here to review if wanted.
I stole a function the jurgen wrote for ordering edges. I am wondering if that shouldn't be abstracted into a "freecad topology api" for ease of use throughtout the system. I am sure there is/will be more.
Is it not possible to import/export the OCC ".brep" format through the freecad GUI? I can do it through the python console, but that is not fast....for me.
FaceUnion3.zip
is a zip
(274.64 KiB) Downloaded 44 times
Site Admin
Re: face union
Postby wmayer » Mon Dec 05, 2011 4:02 pm
OK. I started to integrate your algorithm and it seems to work fine. The reason why I asked this is that how you use the algorithm inside the main function of your test application doesn't really make sense to me. It works basically this way:
solid=readSolid()
for (index=0; index<...;++index) {
   work = solid
   for (ind=0; ind<...;++ind) {
      // modify "work"
   writeShape(work)
As you can see you have one input shape but several output shapes. Actually I expect also only one output shape. My second question, does this only work on solids or also on shells?
It was me who wrote this function. But you're right we should this function to somewhere else and add the definition to a header file.
Sure! But I guess the point is that the file dialog on GNOME hides all the file extensions. So, export it with "CAD Formats" and type ".brep" as your extension.
