Bug #2729 False 'redundant constrains' message
Postby Kunda1 » Fri Jan 13, 2017 12:05 am
Participants in issue #2729 please continue the thread here. Thank you
DeepSOIC
Re: Bug #2729 False 'redundant constrains' message
Postby DeepSOIC » Fri Jan 13, 2017 12:53 am
The sketch in question contains tangent connection made by Tangent + Coincident constraint combination. This is very likely the cause of unstable behavior. Such combination is bad for solver, and should be replaced with tangent applied to endpoints (and no need for coincident).
cox
Postby cox » Sun Jan 15, 2017 11:43 am
DeepSOIC wrote:Such combination is bad for solver, and should be replaced with tangent applied to endpoints (and no need for coincident).
Could such a combination ever be useful, or is it always unwanted. If the latter case, could such a combination, when detected be converted automatically to equivalent working variety "tangent applied to endpoints"?
I understand that overriding user choices could be a slippery slope. But could there be situations when it could be valuable?
Postby chrisb » Sun Jan 15, 2017 5:36 pm
Every now and then I need both constraints. The attached file shows an existing tangential constraint which works as expected only if I add a coincident constraint as well. If I use polyline to create a sketch (as usual) the problem does not occur.
tangentWithoutCoincidence.FCStd
(4.64 KiB) Downloaded 27 times
sgrogan
Postby sgrogan » Sun Jan 15, 2017 5:58 pm
chrisb wrote:Every now and then I need both constraints. The attached file shows an existing tangential constraint which works as expected only if I add a coincident constraint as well. If I use polyline to create a sketch (as usual) the problem does not occur.
Isn't this expected. If tangent is applied to the line and arc. The extension of the line segment is tangent to the extension of the arc segment?
Delete the tangent and apply tangent at point works as expected.
Don't delete and apply tangent at point works. Shouldn't tangent be marked as redundant?
This reminds me of the false missing coincidence constraints when using the sketch validate tool if tangent at point or perpendicular are point are used. I thought I had made a feature request on the tracker but I can not find it.
Postby chrisb » Sun Jan 15, 2017 6:41 pm
sgrogan wrote:Isn't this expected. If tangent is applied to the line and arc. The extension of the line segment is tangent to the extension of the arc segment?
You are right, it was my fault applying tangent to arc/line and not to the points. I finally understood the concept of tangent-on-points :oops: . In fact it turned out, that until now I didn't get the concept, because I had missed that the tangent applies not only to the extension of the line but to the extension of the arc as well.
So I am sorry to have this turned somehow in a help topic but thank you very much for the explanations.
DeepSOIC
Postby DeepSOIC » Sun Jan 15, 2017 7:28 pm
Should be possible, I think. There might be unexpected complications, though.
Chukharev
Postby Chukharev » Sun Feb 12, 2017 11:33 am
DeepSOIC wrote:The sketch in question contains tangent connection made by Tangent + Coincident constraint combination. This is very likely the cause of unstable behavior. Such combination is bad for solver, and should be replaced with tangent applied to endpoints (and no need for coincident).
IMHO known combinations with unstable behaviour should at least be warned about, better yet if a warning suggests an alternative.
A possible way to somwhat improve the solver stability might be trying to reiterate with a small random displacement of points.
I see where a tangent on extension constrain is useful, and I could not find a situation when the combination in hand is different from a tangent on end points constrain.
Please do not forget a constrain on two arcs, and also arcs of ellipse, spline etc.
PS. I was asked to respond in this thread, so bear with me, please.
DeepSOIC
Postby DeepSOIC » Sun Feb 12, 2017 1:17 pm
Chukharev wrote:A possible way to somwhat improve the solver stability might be trying to reiterate with a small random displacement of points.
Unacceptable. This will cause creep with underconstrained sketches (typically, those are hand-tweaked sketches).
Chukharev wrote:and I could not find a situation when the combination in hand is different from a tangent on end points constrain
An abstract example. A circle tangent to an ellipse can intersect an ellipse at another point, not the point it is tangent at.
Postby Kunda1 » Wed May 10, 2017 12:03 pm
DeepSOIC wrote:ping
What is in your opinion the fate of issue #2729 then?
