PartDesign Hole feature
DeepSOIC
Re: PartDesign Hole feature
Postby DeepSOIC » Thu Jan 19, 2017 7:06 pm
chrisb wrote:At first glance I thought who the hell needs this, a circle defines a hole and that's enough. But with all these additional "features" it rather seems to be the other way round: Who needs circles any longer? Thanks!
I'd rather reorient the question. Is it possible to make a non-circular hole?
ickby wrote:1. Could this be made to also work with points in sketches? As the circle radius is ignored anyway, it is easier to get a fully constraint sketch with single points.
Points have two drawbacks compared to circle. 1. If you constrain a point to be coincident with an endpoint of a construction edge, that point is not distinguishable.
2. It is possible to toggle circles to construction mode. But not points. This means, I can't use points as construction geometry. Not big deal, but points are very useful when constraining to intersections.
eivindkvedalen
Postby eivindkvedalen » Thu Jan 19, 2017 8:47 pm
If one wants a non-circular hole, one should use the pocket feature. The hole feature is mainly there to be able to add holes for screws easily.
So we should stick to circles then. Should a hole feature add or update radius constraints, maybe?
Eivind
eivindkvedalen
Postby eivindkvedalen » Thu Jan 19, 2017 8:48 pm
ickby wrote:In Part Design there is a AddSub object from which also the subtracrive primitives derived that handle the Cut.
Yes, and the Hole feature inherits from this object.
Eivind
eivindkvedalen
Postby eivindkvedalen » Thu Jan 19, 2017 8:53 pm
Does this mean that it would need to inherit from PartDesign::FeaturePrimitive, and be listed among the other primitives?
No, not at all. Attachment code is implemented as extension, hence you can easily derive your current code from it. You can use the Primitives as example, where the extension is used. Same would work for your case. You could ad dit to the HoleFeature as it is now, or simple create a second version which includes this primitive. Also adding it in the GUI under primitives seems wrong, a standalone feature would be more suited.
Note that this are only ideas, if you deem the result not worth the effort simply ignore it. Your feature, your design and rules :)
raulshc
Postby raulshc » Mon Feb 06, 2017 8:14 pm
Hi guys,
Any news on this? this feature is essential for the new PartDesign workbench. All mid&full range parametric 3D modellers use it, we should have it integrated into the master ASAP ;) .
f3nix
Postby f3nix » Sun Feb 19, 2017 9:31 am
Hi.
Bumping this in hope it's going to be PR'd soon :)
Cheers,
Mateusz
Postby chrisb » Wed Mar 22, 2017 9:41 pm
The original post seemed to be pretty far advanced. Can we have this in master? (We just have a discussion about threads in the german forum).
NormandC
Postby NormandC » Thu Mar 23, 2017 1:30 am
Unfortunately 2 months have passed since, it surely won't be easy to rebase to master now...
eivindkvedalen
Postby eivindkvedalen » Thu Mar 23, 2017 11:08 am
NormandC wrote:Unfortunately 2 months have passed since, it surely won't be easy to rebase to master now...
I'm rebasing regularily on my computer, so it's still in good shape, I just haven't pushed it to github yet. I've been too busy lately to finish it, but I might get more time in a week or two.
Eivind
Postby chrisb » Fri Mar 24, 2017 1:02 am
Waiting for it! Holes could be very interesting for Path Workbench too.
