[SOLVED] Bug #2845: [Part] Part fusion fails when trying to fusion 10 offset parts into 1
Postby Kunda1 » Wed Jan 18, 2017 1:32 am
Please continue discussing issue #2845 below:
Re: Bug #2845: [Part] Part fusion fails when trying to fusion 10 offset parts into 1
Postby Kunda1 » Fri Oct 19, 2018 1:38 pm
Anyone care to weigh in on this ?
DeepSOIC
Postby DeepSOIC » Fri Oct 19, 2018 1:52 pm
No problem here:
OS: Windows 8
Version: 0.18.14495 (Git)
Hash: c717d1121d888fe6cfbd8971b5f59311a34b37bc
Python version: 2.7.14
OCC version: 7.2.0
Locale: Russian/RussianFederation (ru_RU)
(fusion successful, bopcheck of result passed)
I'd recommend adding a cylinder in the center, where all the interesting intersection stuff is happening. Then cut each blade with the cylinder, then fuse the cut blades to the cylinder. This should eliminate the intersection complexity at the center, and improve the odds of success.
Postby chrisb » Fri Oct 19, 2018 2:57 pm
Not reproducable on MacOS with rather current 0.18 either. I closed the ticket.
Postby Kunda1 » Fri Oct 19, 2018 3:04 pm
Thanks @chrisb!
Marked this thread [SOLVED].
