issue #1478: trim edge fails to maintain constraints
Please decide if this is a bug. Thank you.
Can others please weigh in to this issue? Thanks!jmaustpc wrote:I can't see why you think this is a bug?
You can't do as you have said because you can't trim any thing at 0,18,0 ...the top horizontal line is at (whatever, "16 point something", whatever). If I understand you correctly, you want to trim the top horizontal line in the sketch, this would then make the horizontal constrains invalid so they are automatically removed, so of course the sketch would become not fully constrained.
Done!Kunda1 wrote:@NormandC with these older bugs do you mind notating the ticket directly?
No sir, thank you for your tireless work on the bug tracker!Kunda1 wrote: Oh and thanks for your response as well!
Verdict on this ticket? issue #1478NormandC wrote:Done!Kunda1 wrote:@NormandC with these older bugs do you mind notating the ticket directly?
Should I merge this ticket with issue #1576 based on the feedback @Abdullah gave in:NormandC wrote:My verdict hasn't changed: IMHO it's a valid request. But it might take a while before someone is willing to tackle this...
Great job with the bug tracker!!Kunda1 wrote:Should I merge this ticket with issue #1576 based on the feedback @Abdullah gave in:NormandC wrote:My verdict hasn't changed: IMHO it's a valid request. But it might take a while before someone is willing to tackle this...
https://freecadweb.org/tracker/view.php?id=1576#c8924
Thanks! It's the way I contribute back to open-sourceabdullah wrote:Great job with the bug tracker!!
Currently there are 2 tags I'm using in conjunction to identify these types of tickets and they are 'Solver' and 'trim'abdullah wrote:I am not sure about the merge, but maybe tagging all these "trim does not work as expected, not trimming right, not respecting constraints, unexpected behaviour, a user expects it to maintain these constraints (e.g. vertical/horizontal), but not those (equality constraints)...." into a single "sketcher trimming" tag may be very useful.
#hangingfruitthatneedsaladderabdullah wrote: If somebody decides to work on the sketcher trimming support, given the high amount of issues involved, he should read every problem identified, so that the solution fulfills all user requirements. For this specific case, if somebody decides to tackle the problem, I think it is a good candidate for a thread in the forum and a lot of help/support with testing (bugs and user acceptance tests). I mean it is not a "very high hanging fruit", but it is the kind of fruit you think you can get just by jumping and you end up falling down to earth with empty hands after several tries unless you really decide to take your time to study the issue (i.e you take a ladder).
