Bug #2461: Crash when creating loft between two sketches
Postby Kunda1 » Thu Jan 26, 2017 9:54 pm
issue #2461: Crash when creating loft between two sketches
Please test if this is indeed an upstream OCC issue. Thanks!
Re: Bug #2461: Crash when creating loft between two sketches
Postby Kunda1 » Fri Jun 08, 2018 11:56 pm
Can still be reproduced with 0.17 OCC7.2
https://freecadweb.org/tracker/view.php?id=2461#c11373
hirnsalat
Postby hirnsalat » Sat Jun 09, 2018 12:29 am
Some additional information from testing:
  • It only happened to me with more than 2 sketches.
  • Doesn't happen with a ruled surface.
  • Both the additive loft in the Part Design workbench and the loft tool in the Part workbench produce the crash.
  • Interestingly, in the file I uploaded, setting Constraint43 in spline2 to 60mm fixes the crash for spline1/spline2/spline3. Adding spline4 to the loft still crashes.
  • Sketches in that file have the same number of points. They were actually created by duplicating the same sketch and just moving points.
  • I could only reproduce it with b-splines in the sketches. Unfortunately, I didn't manage to save more than one of these files.
Could be a bug in OCC, but it doesn't seem like the entire Application should crash ;)
I attached a stack trace, I was running the AppImage. Maybe that helps.
stacktrace.txt
(4.2 KiB) Downloaded 10 times
ghedger42
Postby ghedger42 » Sat Jun 09, 2018 1:41 am
I did a loft this morning, with three sketches actually. No crash. My system/build info:
OS: Ubuntu 16.04.4 LTS
Version: 0.18.13920 (Git)
Build type: None
Hash: 08910e71e423c02da46018c47e34002df4fde1f9
Python version: 2.7.12
OCC version: 7.2.0
NormandC
Postby NormandC » Sun Jun 10, 2018 5:10 am
Regarding OCC-related crashes, wmayer wrote that on the 7.x series, OCC disabled exception handling. We need to re-enable it when building OCC to reduce the crash occurrences which have raised a lot since we build FreeCAD with OCCT 7.x.
https://forum.freecadweb.org/viewtopic. ... 36#p229436
https://forum.freecadweb.org/viewtopic. ... 20#p238310
