OCC Bugs in the Bugtracker
user1234
Re: OCC Bugs in the Bugtracker
Post by user1234 »
issue #5619 or old tracker #2024
(No forum entry, it is maybe too old), no screenshot, no file in the tracker, no way to reproduce. Should it be closed and reopened, when it is necessary?
Greetings
user1234
Founder
Post by wmayer »
The OCC Mantis ticket is still open: http://tracker.dev.opencascade.org/view.php?id=25979
user1234
Post by user1234 »
wmayer wrote: Mon Apr 25, 2022 9:15 am The OCC Mantis ticket is still open: http://tracker.dev.opencascade.org/view.php?id=25979
Yes, but it was not touched around 5 years (even their tracker attachments are not downloadable more) and no way to reproduce in FreeCAD. This way i said, reopen if necessary (or make a new, no one will know about that later).
Greetings
user1234
Founder
Post by wmayer »
user1234 wrote: Mon Apr 25, 2022 2:35 pm even their tracker attachments are not downloadable more
They are but you must be logged in.
And you can still execute the TCL code and when doing so (tested with OCC 7.3) a fillet is broken. Attached is the saved BRep file.
But since it's an upstream issue we can close the FreeCAD ticket.
Fillet001.brep
(178.9 KiB) Downloaded 52 times
user1234
Post by user1234 »
wmayer wrote: Mon Apr 25, 2022 3:10 pm And you can still execute the TCL code and when doing so (tested with OCC 7.3) a fillet is broken. Attached is the saved BRep file.
I did not know that. Thanks for the file. I have recreated the case in FreeCAD, but the issue seems to be gone anyway, even with all extra edges (work on both sides, as it should).
issue6268.FCStd
(151.22 KiB) Downloaded 58 times
edit: it is issue #5619, not #6268
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.20.28753 (Git)
Hash: fe5ac277a017413a8646b621d5b993b0c606d551
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, OCC 7.6.2
Greetings
user1234
edit: red
Post by Kunda1 »
I let this thread get away from me. What needs to be updated ?
user1234
Post by user1234 »
Kunda1 wrote: Mon Apr 25, 2022 9:43 pm What needs to be updated?
At least someone should verify the results, before updating anything.
Greetings
user1234
Post by Kunda1 »
Some upstream OCC bugs are getting some traction and being addressed. I've updated the OP to reflect this. Thanks to all involved so far, you know who you are :D
xxxajk
Post by xxxajk »
YAY!!! :mrgreen:
Post by Kunda1 »
We do need more bugs reported or bumped upstream. Please see OP for which specific ones.
